Snmp nac (Clean access) and ISE on same switch
Jul 14th, 2013
Is it possible to run ISE ( radius nac) and Clean Access ( snmp nac) on the same switch ?
I meen that configuration Will coexist on switch in A migration face.
Is it doable and how ?
Regards Henrik
Tarik Admani Sun, 07/14/2013 - 18:05
  • Green, 3000 points or more
Hi this should be possible since these are port based controls. Just enable the dot1x on the port and then uncontrol the port from the cam.
Sent from Cisco Technical Support Android App
henrikj Sun, 07/14/2013 - 22:23
Hi Tarik
Thanks for your reply, i will try.
Renards Henrik
Eduardo Aliaga Sun, 07/14/2013 - 23:06
  • Silver, 250 points or more
Hello, yes you can have both SNMP for NAC and RADIUS for ISE in the same global configuration of the switch. But please remember there's also the switchport configuration. Each switchport must be controlled either by ISE or by NAC, only by one of them.
So you can have for example g1/0/1 authorized by ISE and g1/0/2 authorized by NAC and so on.
Please rate if this helps
