Vulnerability assessment on the Ironport Device ESA
Jul 15th, 2013
HI
There is penertation test done on ESA and below is detail
  • •1)       SSH Insecure HMAC Algorithms Enabled
SOLUTION
Disable any 96-bit HMAC  Algorithms.-------------- how we can disable this in ironport email
Disable any  MD5-based HMAC Algorithms
Rule:
EXECUTE { from  aspl_env import getContextVariable try: test_data =  getContextVariable('ssh_server_to_client_mac') +  getContextVariable('ssh_client_to_server_mac') except KeyError: rule.STOP(False)  for item in test_data: if item.endswith('-96'): rule.STOP(True) elif 'md5' in  item: rule.STOP(True) rule.STOP(False) }
Info:
GOT:  'ssh_server_to_client_mac' = ['hmac-md5', 'hmac-sha1', [email protected]',  'hmac-ripemd160', [email protected]', 'hmac-sha1-96',  'hmac-md5-96']
GOT:  'ssh_client_to_server_mac' = ['hmac-md5', 'hmac-sha1', [email protected]',  'hmac-ripemd160', [email protected]', 'hmac-sha1-96',  'hmac-md5-96']
  • •2)       SSH RC4 Cipher Enabled
SOLUTION
Disable the arcfour (RC4) cipher.
Rule:
EXECUTE { from  aspl_env import getContextVariable try: test_data =  getContextVariable('ssh_client_to_server_ciphers') +  getContextVariable('ssh_server_to_client_ciphers') except KeyError:  rule.STOP(False) if 'arcfour' in test_data: rule.STOP(True) rule.STOP(False)  }
Info:
GOT:  'ssh_client_to_server_ciphers' = ['aes128-ctr', 'aes192-ctr', 'aes256-ctr',  'arcfour256', 'arcfour128', 'aes128-cbc', '3des-cbc', 'blowfish-cbc',  'cast128-cbc', 'aes192-cbc', 'aes256-cbc', 'arcfour',  [email protected]']
GOT:  'ssh_server_to_client_ciphers' = ['aes128-ctr', 'aes192-ctr', 'aes256-ctr',  'arcfour256', 'arcfour128', 'aes128-cbc', '3des-cbc', 'blowfish-cbc',  'cast128-cbc', 'aes192-cbc', 'aes256-cbc', 'arcfour',  [email protected]']
  • •3)       CBC Mode Ciphers are enabled on the SSH Server
SOLUTION
Disable CBC Mode Ciphers and use CTR Mode  Ciphers
Rule:
EXECUTE { from  aspl_env import getContextVariable try: test_data =  getContextVariable('ssh_client_to_server_ciphers') +  getContextVariable('ssh_server_to_client_ciphers') except KeyError:  rule.STOP(False) for item in test_data: if item.endswith('-cbc'):  rule.STOP(True) rule.STOP(False) }
Info:
Please advise
Overall Rating: 1 (1 ratings)
Mathew Huynh Tue, 07/16/2013 - 20:21
  • Cisco Employee,
Hello Asim,
SSL protocols and ciphers advertised for incoming Graphical User Interface (GUI) connections can be configured with the sslconfig command the same for inbound and outbound connections
ironport.example.com> sslconfig
sslconfig settings:
  GUI HTTPS method:  sslv3
  GUI HTTPS ciphers: RC4-SHA
  Inbound SMTP method:  sslv3tlsv1
  Inbound SMTP ciphers: HIGH:MEDIUM:-SSLv2:-aNULL:@STRENGTH
  Outbound SMTP method:  sslv3tlsv1
  Outbound SMTP ciphers: HIGH:MEDIUM:-SSLv2:-aNULL:@STRENGTH
Choose the operation you want to perform:
- GUI - Edit GUI HTTPS ssl settings.
- INBOUND - Edit inbound SMTP ssl settings.
- OUTBOUND - Edit outbound SMTP ssl settings.
- VERIFY - Verify and show ssl cipher list.
[]> gui
Enter the GUI HTTPS ssl method you want to use.
1. SSL v2.
2. SSL v3
3. TLS v1
4. SSL v2 and v3
5. SSL v3 and TLS v1
6. SSL v2, v3 and TLS v1
[2]> 2
Enter the GUI HTTPS ssl cipher you want to use.
[RC4-SHA]>
You can then change the Ciphers to the one you would prefer(require)
For HIGH cipher list ->
- INBOUND - Edit Inbound SMTP ssl settings.
- OUTBOUND - Edit Outbound SMTP ssl settings.
[]> verify
Enter the ssl cipher you want to verify.
[]> RC4-SHA:RC4-MD5:HIGH
Gulam Siraj Arab Mon, 08/12/2013 - 23:40
Hello All,
Are there any fixes for above mentioned vulnerabilities on cisco IOS for routers and Switches ?
I dont see any configurable options on cisco routers and switches so far but do let me know if there is anything that could be done to fix them.
technics614 Wed, 10/26/2016 - 12:20
I realize this post is three years old but is one of few regarding SSH ciphers.  Why is it that it is mentioned to change SSL GUI settings to fix SSH ciphers?  Can SSH Ciphers be disabled through SSHD config via ESA CLI?
Mathew Huynh Wed, 10/26/2016 - 15:35
  • Cisco Employee,
You may choose which ciphers the ESA will use for SSH (CLI) access; whichever is defined will be the ciphers used from my knowledge- all others are disabled(inactive).
Mathew
