Change default password on LAP?
Answered Question
Jul 15th, 2013
I have several new 2602e access points configured on two 4408 WLCs. All went surprisiongly well with the installation and configuration. However, I want to change the default user and password, but I'm not sure where to do this from. There doesn't appear to be a configure command in enable mode on the APs and I can't find where the user accounts might be controlled from the controller.
Anyone know the answer?
Thanks!
Correct Answer by Scott Fella about 4 years 1 month ago
Here is where you would change it.  You would also have to enable ssh or telnet on each AP
Scott
Help out other by using the rating system and marking answered questions as "Answered"
Overall Rating: 5 (1 ratings)
Correct Answer
Scott Fella Mon, 07/15/2013 - 12:24
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Scott
Daniel Ordonez Mon, 07/15/2013 - 13:31
  • Gold, 750 points or more
  • Participante Destacado,
    El Favorito: Noviembre 2015
Hello Scott.
One questions when you set up an username & password the changes are apply to all AP's ?
kmkrause2 Mon, 07/15/2013 - 12:34
Worked like a charm. Thanks for the prompt reply. I must have passed over that page a dozen times. The light just never went on, I guess
Scott Fella Mon, 07/15/2013 - 12:36
  • Hall of Fame,
    2017 Wireless
Yeah or else its the default Cisco/Cisco.
Abhishek Abhishek Mon, 07/15/2013 - 15:21
Hello Sali,
As per your query i can suggest you the following solution-
To change the default user and password. It can be done under wireless tab then go to global configuration.
Hope this will help you.
