Warning message
Prime 1.3 Perf Mon Deploy Config doesn't work Invalid commands
Jul 16th, 2013
When I try to deploy configuration to my 6509 or 3750 the template creates the following code.  The job fails and when I try to manually input this, the system doesn't recognize it.  Is there a minimum ios requirement or another template that will work with my device ios versions?
6509    Version 12.2(33)SXJ4
3750   12.2(55)SE6
flow exporter Exporter1
destination 10.10.10.10
transport udp 9991
class-map match-all class-all
match any
flow monitor type performance-monitor Flow1
record default-rtp
export Exporter1
policy-map type performance-monitor Perf1
class class-all
flow monitor Flow1
interface Vlan 110
service-policy type performance-monitor input Perf1
service-policy type performance-monitor output Perf1
dustin.peterson Wed, 07/17/2013 - 06:20
I believe that you are missing the flow record command.
In flexible netflow you need to have 3 things, a flow exporter, a flow record, and a flow monitor.
In your config I see the flow exporter and the flow monitor, but no flow record.
Was the flow record configured previously and that's why its not in your template?
Here is an example of a flow record:
flow record standard
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
collect transport tcp flags
collect interface output
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
collect timestamp sys-uptime last
Timothy Chan Wed, 07/17/2013 - 09:16
Looks like only the SUP 2T supervisors support flexible netflow.  I have SUP 720s and those commands, "flow record standard" and "flow exporter" are not recognized.
