ASA 5505 (8.4) 192.168.1.1/16 Subnetting issues
garfieldgroup
I have an ASA 5505 and I would like to create two subnets on it, but I'm having trouble getting some resources on the second subnet exposed to the outside world.
The first subnet is located at the 192.168.1.x range, and the second is at the 192.168.50.x range.  I'm able to expose the Outlook Web Access server on the 192.168.1.x range just fine, I can't seem to expose the web server or VPN on the 192.168.50.x range.  I've tried fiddling with NAT and Access-Lists but I'm obviously missing something...here is my current config:
Result of the command: "show config"
: Saved
: Written by enable_15 at 12:20:13.608 UTC Tue Jul 16 2013
ASA Version 8.4(5)
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.1 255.255.0.0
interface Vlan2
nameif outside
security-level 0
ip address 173.15.x.202 255.255.255.0
ftp mode passive
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network DEV
host 192.168.50.13
object network ODM
host 192.168.50.11
object network PR
host 192.168.1.2
access-list acl_out extended permit tcp any object DEV eq www
access-list acl_out extended permit tcp any object ODM eq pptp
access-list acl_out extended permit tcp any object PR eq https
access-list acl_out extended permit tcp any object PR eq pop3
access-list acl_out extended permit tcp any object PR eq imap4
access-list acl_out extended permit tcp any object PR eq smtp
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
object network DEV
nat (inside,outside) static interface service tcp www www
object network ODM
nat (inside,outside) static interface service tcp pptp pptp
object network PR
nat (inside,outside) static interface service tcp https https
nat (inside,outside) after-auto source dynamic any interface
access-group acl_out in interface outside
route outside 0.0.0.0 0.0.0.0 173.15.x.206 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.5-192.168.1.254 inside
threat-detection basic-threat
threat-detection statistics host
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
class class-default
  user-statistics accounting
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:13d83266ce5b0f932d9b184cd176a7be
Any suggestions are greatly appreciated.  Thanks!
eddie.harmoush
Hi Adam,
I'm not seeing where you created the VLAN Interface for your the 192.168.50.x subnet.  Nor am I seeing a route to the 192.168.50.x subnet, so I'm assuming you simply forgot to create it.
Your Firewall currently doesn't know how to get to the 192.168.50.x subnet, it either needs the interface created or a route statement added.
Hope this helps.
-Eddie
Marvin Rhoads
In addition to Eddie's reply, your VLAN 1 has a /16 mask. Is that what you wanted?
That's a bit unusual (although it's the topic on the thread) and you have the http statement for ASDM management referring to the network as a /24.
