Warning message
UDP Flooding on Cisco 1810 router
Jul 17th, 2013
We are noticing lot of UDP packets on our Cisco 1810 router. This has choked our internet circuit at 100% utilization.
We  were able to find the Source IP address from where these packet are  coming and have denied access to the Source IP through an access list.
We  are seeing that the access-list is blocking that IP , but the has not  stopped the sender from sending the packet to our router and the router  interface is still experiencing high UDP packet from this IP address.
Any advice or help will be really appreciated.
Thanks.
rcIf         SrcIPaddress    DstIf         DstIPaddress    Pr SrcP DstP Bytes
Fa1           85.17.183.81    Fa0           200.201.Xxxx.xxx  11 6634 0035   931M
There are 3 top talkers:
IPV4 PROT       bytes        pkts       flows
      17   840413708    19544032         141
        1      295379        4416           7
        6      967448        1797         109
Extended IP access list 123
    10 deny ip host 85.17.183.81 any (3844997990 matches)
    11 deny udp host 85.17.183.81 any
    20 permit ip any any (219799308 matches)
FastEthernet1 is up, line protocol is up
  Hardware is PQ3_TSEC, address is xxxx
  Internet address is 21xxxxxxxxx/xx
  MTU 1500 bytes, BW 15000 Kbit, DLY 100 usec,
     reliability 255/255, txload 21/255, rxload 228/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 4d01h
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 13465000 bits/sec, 23375 packets/sec
  5 minute output rate 1256000 bits/sec, 631 packets/sec
     4157523768 packets input, 1494788431 bytes
     Received 293 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     96471423 packets output, 3912578832 bytes, 0 underruns
     0 lost carrier, 0 no carrier
interface FastEthernet1
description WAN to Internet
bandwidth 15000
ip address 2XXX.XXX.XXX XXX.XXX.XXX
ip access-group 123 in
ip flow ingress
ip virtual-reassembly
speed 100
full-duplex
Jouni Forss Wed, 07/17/2013 - 09:59
Naturally you are able to block the traffic but it will still consume your WAN links bandwith.
I would suggest perhaps contacting your ISP for help with this
RIPE gives the following information related to the public source IP address you are seeing
inetnum:        85.17.183.0 - 85.17.183.255
netname:        LEASEWEB
descr:          LeaseWeb
descr:          P.O. Box 93054
descr:          1090BB AMSTERDAM
descr:          Netherlands
descr:          www.leaseweb.com
remarks:        Please send email to "[email protected]" for complaints
remarks:        regarding portscans, DoS attacks and spam.
remarks:        INFRA-AW
country:        NL
admin-c:        LSW1-RIPE
tech-c:         LSW1-RIPE
status:         ASSIGNED PA
mnt-by:         OCOM-MNT
source:         RIPE #Filtered
There is also a contact email above. Maybe you could try that out also.
- Jouni
