Warning message
Call Park on a CUCM cluster with 3 node
Jul 18th, 2013
Hi to all.
I have a problem related to parking calls.
I developed an application that monitors a number of  IPPhones via CTI (jtapi). Scope of my application is toan provide a Phone Console where a user can see phone status end can do some action such as answer, make a call, place on hold and so on.
I have to monitor the call Park number too.
I know I can't monitor via CTI Call Park number so I implemented a solution based on phone and providers events, so I can store Call Park Status in my cache application.
CUCM vesrion is 8.6, cluster is made with 3 node.
Call Park numbers are registered, on Node 2.
Clusterwide callPark parameter is set to false.
IPPhones (all 7975) are registered half on Node2 and half on node 3 (both subscribers).
In the CDN  jtapi forum I found this answer:
Currently 'cluster-wide' call park DNs cannot be monitored by CTI applications (this is roadmapped for an upcoming release.)  If these are not cluster-wide CP DNs, then note that apps can only monitor CP DNs which are instanced on the same node as the Callmanager/CTI-Manager service instances that the app connects to.
Then scenario is the following:
If I park a call on the phones registered on Node 2 I receive correctly the events and  parking/unparking repeatly the same call, works well.
If I park a call placed on a phone registered on Node 3, the first time I park the call, I receive correctly the events, if I unpark  and then park for the second time, park fails and the message is that no CP numbers are available.
My app is connected to Node 2, so I don't understand what 's the problem.
Any idea ?
Thanks.
