Warning message
block all outgoing traffic on port 25 while still allowing only exchange traffic on port 25?
Jul 18th, 2013
this is probably an easy question for most..
It seems that my exchange server or a client on my network has been compromised and my exchange server or an outlook client being used to send spam. Our IP has landed on a couple blacklists. In an attempt to block these clients i want to create a rule to block outbound traffic on port 25 accept from the exchange server. My exchange servers IP is 192.168.7.200 what commands do i need to apply to this config to achieve this?
Thanks in advance..
Current configuration : 11313 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname router
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 4096
logging console critical
enable secret 5
--More--                           aaa new-model
aaa authentication login default local
aaa authentication login vpnclient local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authentication login userauth local
aaa authorization exec default local
aaa authorization network localgroups local
aaa authorization network vpnclient-group local
aaa session-id common
clock timezone PCTime -5
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-*****
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-********
revocation-check none
rsakeypair TP-self-sig-********
--More--                           crypto pki certificate chain TP-self-signed-********
certificate self-signed 01
   quit
dot11 syslog
no ip source-route
--More--                           !
no ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.7.1
ip dhcp pool ccp-pool1
   import all
   network 192.168.7.0 255.255.255.0
   dns-server 192.168.7.244
   default-router 192.168.7.1
no ip bootp server
ip name-server 192.168.7.197
ip name-server 68.237.161.12
ip inspect log drop-pkt
vpdn enable
vpdn-group 1
! Default PPTP VPDN group
--More--                            accept-dialin
  protocol pptp
  virtual-template 1
username ***************
username vpnclient password **************
crypto keyring dmvpnspokes
  pre-shared-key address 0.0.0.0 0.0.0.0 key **********
crypto isakmp policy 5
encr 3des
authentication pre-share
group 2
crypto isakmp policy 10
encr 3des
hash md5
group 2
--More--                           crypto isakmp client configuration group remoteusers
key remoteusers
dns 192.168.7.197
pool vpnpool
crypto isakmp client configuration group vpnclient-group
key cisco123
dns 192.168.7.197
pool vpnclientpool
acl 132
crypto isakmp profile vpnclient-profile
   match identity group vpnclient-group
   client authentication list userauth
   isakmp authorization list vpnclient-group
   client configuration address respond
crypto isakmp profile DMVPN
   keyring dmvpnspokes
   match identity address 0.0.0.0
crypto ipsec transform-set 3des-sha esp-3des esp-sha-hmac
crypto ipsec transform-set l2tpset esp-3des esp-md5-hmac
mode transport
--More--                           crypto ipsec df-bit clear
crypto ipsec profile myprofile
set transform-set 3des-sha
set isakmp-profile DMVPN
crypto dynamic-map dynmap 10
set isakmp-profile vpnclient-profile
crypto map mymap 50 ipsec-isakmp dynamic dynmap
archive
log config
  hidekeys
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
--More--                           class-map type inspect match-all TEST
match access-group 110
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol h323
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp extended
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
--More--                            match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
--More--                            class type inspect ccp-insp-traffic
  inspect
class class-default
class type inspect TEST
  inspect
class class-default
zone security out-zone
zone security in-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
interface Tunnel0
bandwidth 1000
ip address 10.10.5.1 255.255.255.0
no ip redirects
--More--                            ip mtu 1460
ip nhrp authentication cisco123
ip nhrp map multicast dynamic
ip nhrp network-id 1
ip nhrp holdtime 600
ip tcp adjust-mss 1400
ip ospf network broadcast
ip ospf priority 2
ip ospf mtu-ignore
delay 1000
tunnel source FastEthernet0
tunnel mode gre multipoint
tunnel protection ipsec profile myprofile
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation hdlc
ip route-cache flow
shutdown
--More--                           interface FastEthernet0
description $ES_WAN$$FW_OUTSIDE$
ip address x.x.x.x 255.255.255.0
no ip proxy-arp
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
crypto map mymap
interface FastEthernet1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
duplex auto
speed auto
interface FastEthernet2
--More--                           interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Virtual-Template1
ip unnumbered FastEthernet0
peer default ip address pool pptp-pool
no keepalive
ppp encrypt mppe auto
ppp authentication pap chap ms-chap
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 2$$ES_LAN$$FW_INSIDE$
--More--                            ip address 192.168.7.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1360
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1200
ip policy route-map clear-df
router ospf 10
log-adjacency-changes
network 10.10.5.0 0.0.0.255 area 0
network 192.168.7.0 0.0.0.255 area 0
ip local pool vpnpool 192.168.200.1 192.168.200.254
ip local pool vpnclientpool 192.168.8.160 192.168.8.200
ip local pool pptp-pool 192.168.9.160 192.168.9.200
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 x.x.x.x
--More--                           ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 194 interface FastEthernet0 overload
ip nat inside source static tcp 192.168.7.200 25 interface FastEthernet0 25
ip nat inside source static tcp 192.168.7.200 443 interface FastEthernet0 443
ip nat inside source static udp 192.168.7.200 443 interface FastEthernet0 443
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.7.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip 96.246.158.0 0.0.0.255 any
access-list 110 permit ip any host 96.246.158.15
access-list 132 permit ip 192.168.7.0 0.0.0.255 192.168.8.0 0.0.0.255
access-list 194 deny   ip 192.168.7.0 0.0.0.255 192.168.8.0 0.0.0.255
access-list 194 permit ip 192.168.7.0 0.0.0.255 any
access-list 199 permit ip host 192.168.7.197 192.168.9.0 0.0.0.255
access-list 199 permit ip host 192.168.7.197 192.168.6.0 0.0.0.255
access-list 199 permit ip host 192.168.7.97 192.168.11.0 0.0.0.255
access-list 199 permit ip host 192.168.7.197 192.168.201.0 0.0.0.255
access-list 199 permit ip host 192.168.7.197 192.168.12.0 0.0.0.255
no cdp run
route-map clear-df permit 10
match ip address 199
set ip df 0
control-plane
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
--More--                           already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you want to
use.
^C
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
transport output telnet
line aux 0
line vty 0 4
--More--                            exec-timeout 0 0
privilege level 15
transport input telnet ssh
line vty 5 7
privilege level 15
line vty 8 15
scheduler allocate 4000 1000
scheduler interval 500
webvpn gateway gateway_1
ip address x.x.x.x port 8443
http-redirect port 80
ssl trustpoint TP-self-signed-4273367397
inservice
webvpn context RemoteSSL
secondary-color white
title-color #CCCC66
text-color black
ssl authenticate verify all
--More--                            !
policy group policy_1
default-group-policy policy_1
aaa authentication list ciscocp_vpn_xauth_ml_1
gateway gateway_1
inservice
end
mvsheik123 Thu, 07/18/2013 - 09:17
  • Gold, 750 points or more
Looks like your exchange server is in Vlan1. Try this ACL (during maintenance window)..
access-list 102 permit tcp host 192.168.7.200 any eq smtp
access-list 102 deny   tcp any any eq smtp
access-list 102 permit ip any any
int vla1
ip access-group 102 in
This will let 192.168.7.200 allow to make any port 25 (SMTP) connections to outside, while deny from rest of the IPs. As you want rest of the traffic to go, you need 'ip any any' at the end.
hth
MS
