RADIUS Views
Answered Question
Jul 19th, 2013
Hi All,
Could any one please explain what RADIUS views are ?
any help will be much appriciated.
Many thanks.
Kamarn.
Correct Answer by Jatin Katyal about 4 years 3 weeks ago
I tried to check this in the feature navigator tool but couldn't find anything related to pareser view or RBAC.
http://tools.cisco.com/ITDIT/CFN/jsp/SearchBySoftware.jsp
Command reference says that The view keyword and view-name argument were integrated into Cisco IOS Release 12.2(33)SRB.
http://www.cisco.com/en/US/docs/ios/security/command/reference/sec_e1.html#wp1059941
Have you tried to enable the same fetaure on some other code/image?
~BR
Jatin Katyal
**Do rate helpful posts**
Correct Answer by Jatin Katyal about 4 years 4 weeks ago
awwh, parser view this is also called RBAC - Role based access control.
Here are few examples you may refer while configuring it. In case you have any issues, post your queries here.
IOS: Role-based Access Control with ACS
https://supportforums.cisco.com/docs/DOC-15765
http://www.cisco.com/en/US/docs/ios/sec_user_services/configuration/guide/sec_role_base_cli_ps6922_TSD_Products_Configuration_Guide_Chapter.html
~BR
Jatin Katyal
Overall Rating: 5 (4 ratings)
Jatin Katyal Fri, 07/19/2013 - 02:26
  • Cisco Employee,
Hi kamran,
I didn't understand your last web query. Could you please elaborate your question?
~BR
Jatin Katyal
kamrannaseem Fri, 07/19/2013 - 02:49
Hi Jatin,
I have been told to conifugre views in RADIUS. I dont know myself what it is.
Have you heard anything like that in RADIUS ?
Many thanks.
Correct Answer
Jatin Katyal Fri, 07/19/2013 - 05:05
  • Cisco Employee,
~BR
Jatin Katyal
kamrannaseem Mon, 07/22/2013 - 02:27
Hi Jatin,
I was just trying to enable view but seems like command doesnt exist in the IOS. Do you know the command to enable parser view. I am using cisco 2960 switch.
Many thanks.
Jatin Katyal Mon, 07/22/2013 - 04:08
  • Cisco Employee,
How are you enabling view through console or telnel/ssh session?
~BR
Jatin Katyal
kamrannaseem Mon, 07/22/2013 - 04:19
Hi Jatin,
I am enabling through cosole, and the IOS image I am using is c2960-lanbasek9-mz.122-35.SE5.bin
Do all IOS images support parser views or i need a specific image for that ?
many thanks.
Correct Answer
Jatin Katyal Mon, 07/22/2013 - 04:47
  • Cisco Employee,
~BR
Jatin Katyal
kamrannaseem Mon, 07/22/2013 - 06:49
Hi Jatin,
I did not try on any other relase this is the only available release I have.
Do you know where I could find which IOS image supports which feature set ?
many thanks.
