Warning message
mp-bgp leaking multiple equal cost routes from ospf
Jul 19th, 2013
I've the following config:
DC-CORE1-1.2.1#sh ip route vrf SERVICES 172.20.140.0
Routing entry for 172.20.140.0/24
  Known via "ospf 2", distance 110, metric 11, type intra area
  Redistributing via bgp 65001
  Advertised by bgp 65001 route-map SKIP_PEERING_NET
  Last update from 100.100.15.2 on FastEthernet1/11, 00:49:14 ago
  Routing Descriptor Blocks:
  * 100.100.18.2, from 1.3.2.2, 00:49:14 ago, via FastEthernet1/14
      Route metric is 11, traffic share count is 1
    100.100.15.2, from 1.3.1.2, 00:49:14 ago, via FastEthernet1/11
In vrf SERVICES there are 2 equal cost routes learned via ospf for the prefix 172.20.140/24.
In need to leak this prefix from vrf SERVICES and insert this prefix in another vrf named EXTRANET; I've configured mp bgp and the leaking is working, but what I need is to have both the equal cost routes on the vrf EXTRANET.
Actually, the process is importing only 1 route.
DC-CORE1-1.2.1#sh ip route vrf EXTRANET 172.20.140.0
  Known via "bgp 65001", distance 20, metric 11, type external
  Last update from 100.100.15.2 on FastEthernet1/11, 00:23:04 ago
  * 100.100.15.2 (SERVICES), from 0.0.0.0, 00:23:04 ago, via FastEthernet1/11
      AS Hops 0
That behavior could be fine if I had to redistribute via bgp that route but I don't have to do it; I instead have to use the vrf SERVICES for routing purposes, so I need both the routes for the prefix.
I think this behavior is because both the prefix have the same RD so in the vpnv4 tables they are the same route.
How could I do this?
Thank you.
Best Regards.
AM
