Nexus 5010 upgrade - Incompatible image
Jul 19th, 2013
I'm trying to upgrade a pair of 5010 running version 4.1(3)N2(1a) to at minimum 4.2(1)N1(1) to get VTP support. (also tryed 4.2(1)N2(1a) )
But after uploading the image (both kickstart and system) I ran a "show install all impact" and gets the following output:
nex5010# show install all impact kickstart bootflash:n5000-uk9-kickstart.4.2.1.N2.1a.bin
Verifying image bootflash:/n5000-uk9-kickstart.4.2.1.N2.1a.bin for boot variable "
kickstart".
[####################] 100% -- SUCCESS
Verifying image bootflash:/n5000-uk9.4.1.3.N2.1a.bin for boot variable "system".
Verifying image type.
[###########         ]  50%                                         [####################] 100% -- SUCCESS
Extracting "system" version from image bootflash:/n5000-uk9.4.1.3.N2.1a.bin.
Extracting "kickstart" version from image bootflash:/n5000-uk9-kickstart.4.2.1.N2.
1a.bin.
Extracting "bios" version from image bootflash:/n5000-uk9.4.1.3.N2.1a.bin.
Notifying services about system upgrade.
Compatibility check is done:
Module  bootable          Impact  Install-type  Reason
     1        no             n/a           n/a  Incompatible image
Images will be upgraded according to following table:
Module       Image         Running-Version             New-Version  Upg-Required
     1      system            4.1(3)N2(1a)            4.1(3)N2(1a)            no
     1   kickstart            4.1(3)N2(1a)            4.2(1)N2(1a)            no
     1        bios        v1.3.0(09/08/09)        v1.3.0(09/08/09)            no
     1   power-seq                    v1.0                    v1.1           yes
How do I upgrade the power-seq to v1.1?
Or is it done somehow otherwise?
Related Content
