Warning message
Cisco Prime LMS Dashboard/Portal Customization
Jul 19th, 2013
As I am new to Prime LMS 4.2, I would like to enquire if it may be possible for a administrator to define the dashboard/portlets that it is created for the users (Example helpdesk users accessing the Prime LMS)?
I have created a basic user role, however upon logging into the system, I see several "do not have permissions". I was wondering on how it may be possible to remove/add only required portlets/dashboards for non-administrators to see it?
Any suggestions is appreciated.
Thanks.
csco11773671 Fri, 07/26/2013 - 01:30
I have also recently setup LMS 4.2 and although I am no expert I have configured some defined user roles and allocated to users as you are trying to do.
Firstly go to "Admin>Syste,>User Mgmt>Role Mgmt Setup" define your roles here, if you want specific areas to be available create a new role based on one the those predefined and then edit for the functions you want.
Then go to "Admin>Syste,>User Mgmt>Local User Setup" and allocate the role to the user(s) you want to be able to access these task areas.
Hope this helps and good luck!
