Warning message
problem !!=>Need help about "police cir" in MLS cisco 7604
Jul 20th, 2013
hi  all ,
i have MLS cisco 7604  ,
i tried to use QOS to dedicate  cir for specific  subnet ,  but  it  failed , it seems that bandwidth command dont work on that platform !!!
my 1st  question eis  can i apply QOS  and use bandwidth command ??? is it impossible ????
my 2nd question is ,
i have 600 M as total download traffic ,
i want to limit the bw on the interface from 600M  to 520 M
i  configured the following :
Gateway7600#
sh ip access-lists drvirus
Extended IP access list drvirus
     10 deny ip any x.x.x.0 0.0.0.31 (1802 matches)
     20 permit ip any any (2507719 matches)
Gateway7600#
sh class-map drvirus
Class Map match-all drvirus (id 4)
    Match access-group name  drvirus
Gateway7600#
sh policy-map drvirus
   Policy Map drvirus
     Class drvirus
police cir 500000000 bc 93750000 be 187500000
    conform-action transmit
    exceed-action drop
    violate-action drop
Gateway7600#
sh running-config interface gigabitEthernet 1/5
Building configuration...
Current configuration : 258 bytes
interface GigabitEthernet1/5
description 7600to7200
mac-address 503d.e5af.9c45
ip address 172.30.40.2 255.255.255.252
ip wccp 70 redirect in
ip wccp 90 redirect in
load-interval 30
service-policy input drvirus
service-policy output rateupload
end
but  when i try to put under the interface level ,
it fails  and give me the error ===>
Gateway7600(config-if)#service-policy input drvirus
burst (bc)  must be between 1000 and 31250000 for this interface
Configuration failed on GigabitEthernet1/5
i tried another  trial ,
i changed police cir  from
  to ===>
police cir 500000000 bc 250000 be 1000
after that , it was accepted under the interface command.
but i dont see any limitation in bw !!!!!!!
wish to help me =============?
i have the following speifications :
Gateway7600#sh module
Mod Ports Card Type                                     Model                 Serial No.
   1    9  Supervisor Engine 32 8GE (Active)       WS-SUP32-GE-3B      SAD104204GX
Mod MAC addresses                            Hw   Fw              Sw             Status
   1  0018.bad2.2324 to 0018.bad2.232f  4.4   12.2(18r)SX   15.2(4)       Ok
Mod  Sub-Module                      Model                 Serial        Hw      Status
   1  Policy Feature Card 3        WS-F6K-PFC3B        SAD104201HK  2.3    Ok
   1  Cat6k MSFC 2A daughterboard WS-F6K-MSFC2A       SAD104004UC  3.1    Ok
Mod  Online Diag Status
   1  Pass
Gateway7600#sh version
Cisco IOS Software, c7600s3223_rp Software (c7600s3223_rp-ADVENTERPRISEK9-M), Version 15.2(4)S, RELEASE SOFTWARE (fc1)
Technical Support:
http://www.cisco.com/techsupport
Copyright © 1986-2012 by Cisco Systems, Inc.
Compiled Fri 20-Jul-12 18:18 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600s3223_rp Software (c7600s3223_rp-ADVENTERPRISEK9-M), Version 15.2(4)S, RELEASE SOFTWARE (fc1)
Gateway7600 uptime is 32 weeks, 7 hours, 6 minutes
Uptime for this control processor is 13 weeks, 7 hours, 10 minutes
System returned to ROM by power-on (SP by power-on)
System restarted at 06:26:11 UTC Sat Apr 20 2013
System image file is "sup-bootdisk:c7600s3223-adventerprisek9-mz.152-4.S.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco CISCO7604 (R7000) processor (revision 2.0) with 458752K/65536K bytes of memory.
Processor board ID FOX1509G2DK
R7000 CPU at 300MHz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
1 Virtual Ethernet interface
9 Gigabit Ethernet interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
