Warning message
Active/Standby And failover link configuration mode
Answered Question
Jul 20th, 2013
Hi everyone,
When config failover  link of ASA  in Active Standby mode.
When we config failover int say gi0/1
config t
int gi0/1
failover lan int gi0/1
Need to confirm we do this from interface config mode  only or we can do this from global config also ????????
Whe we assign IP to this int we do that from global config mode ????
Mahesh
Message was edited by: mahesh parmar
Correct Answer by Jouni Forss about 4 years 1 month ago
Actually the ASA lets you insert a lot of command what ever mode you are under.
In the output you posted is a very important thing to notice
configure mode commands/options:
  WORD  Specify the interface name
As you can see, the output lists only one option and before that it mentions that this is a "configure mode" command
So even if you entered the command under the interface configuration mode, it would still be entered as a global/configure command mode.
Take the following thing for example
I want to check what configuration options I have with the command "failover"
So I enter the following to my ASA
ASA(config)# failover ?
  interface              Configure the IP address to be used for failover and/or
                              stateful update information
  interface-policy    Set the policy for failover due to interface failures
  key                       Configure the failover shared secret or key
  lan                       Specify the unit as primary or secondary or configure the
                               interface and vlan to be used for failover communication
  mac                      Specify the virtual mac address for a dynamic interface
  polltime                Configure failover poll interval
  timeout                 Specify the failover reconnect timeout value for
                               asymmetrically routed sessions
exec mode commands/options:
  active          Make this system to be the active unit of the failover pair
  exec            Execute command on the designated unit
  reload-standby  Force standby unit to reboot
  reset           Force a unit or failover group to an unfailed state
As you can see, the ASA tells us that there are different additional command parameters after the "failover" command that can be used. Some of them can be used either in Exec or Configuration mode.
- Jouni
Your Failover configuration on the original ASA5500 Series firewalls might look something like this
Primary Unit
failover
failover lan unit primary
failover lan interface failover Management0/0
failover key
failover replication http
failover link failover Management0/0
failover interface ip failover 10.10.10.1 255.255.255.0 standby 10.10.10.2
Secondary Unit
failover
failover lan unit secondary
failover key
To my understanding the Management0/0 interface cant be used in Failover configuration in the new ASA5500-X series like it was typically used in the original ASA5500 Series (ASA5510 and forward)
- Jouni
All Failover configurations related to the interfaces are done from global configuration mode.
To my understanding when you originally choose the Failover link interface and use the "failover" configuration commands to name it and give it an IP address, the ASA will actually remove all configurations from interface used as the Failover interface. It will only add a description to the interface automatically.
You will be doing all Failover configurations on the global configuration mode.
- Jouni
Overall Rating: 5 (3 ratings)
Correct Answer
Jouni Forss Sat, 07/20/2013 - 09:45
- Jouni
Correct Answer
Jouni Forss Sat, 07/20/2013 - 09:48
Primary Unit
failover
failover key
Secondary Unit
failover
failover key
- Jouni
mahesh18 Sat, 07/20/2013 - 09:48
Hi Jouni,
I checked that failover config are also available under interface config also
ASA1(config-if)# failover lan  interface  ?
ASA1(config-if)# failover lan  interface  fail1 ?
  WORD  Specify dynamic interface
Do you know  why they are also available under interface config also?
Mahesh
Correct Answer
Jouni Forss Sat, 07/20/2013 - 09:55
- Jouni
mahesh18 Sat, 07/20/2013 - 10:02
Hi Jouni,
Seems you can also add config under interface config mode as shown below by my test
ASA1(config)# int ethernet 0/7
ASA1(config-if)# failover lan ?
  interface  Configure the interface and vlan to be used for failover
             communication
  unit       Configure the unit as primary or secondary
ASA1(config-if)# failover lan  interface  test1 ?
ASA1(config-if)# failover lan  interface  test1 vlan19
INFO: Non-failover interface config is cleared on Vlan19 and its sub-interfaces
ASA1(config)# end
ASA1# sh run int eth
ASA1# sh run int ethernet 0/7
interface Ethernet0/7
shutdown
ASA1# sh run fail
ASA1# sh run failover
failover
failover lan interface test1 Vlan19
But as you said when we do sh run it shows that under global config and not under inetrface config.
Many thanks  for helping on this.
Best regards
MAhesh
