Warning message
Cisco Prime Collaboration
Jul 22nd, 2013
Hi Folks,
Im currently configuring PRIME and have come across an issue:
To add devices to PRIME you need to configure:
Manage Credentials
Discover devices.
When i add a new profile to manage credentials Prime informs:
"This is a duplicate profile name. Please enter a different profile name" - this is not the case as Prime has only been built so there should be duplicate profiles.
Due to this error i have tried the option to mange VG using direct discovery by using IP but i get an error.
The firewalls rules are correct to the Prime server as i can run Getif and it obtains the snmp details.
Were do I view the logs to see what is failing the new profile add or direct discovery attempts.
Darryl
Hemalatha Kumarasamy Mon, 11/04/2013 - 11:46
  • Cisco Employee,
Hi Darryl,
When the devices are failed to register, you can look into the logs and figure out why it is failing.
Logs can be found in $EMSAM_HOME/log/Inventory/AccesslevelDiscovery.log
Hope it helps..
Hema
