Warning message
CCIE Voice lab question
Answered Question
Jul 22nd, 2013
        I am building my lab for the CCIE voice exam. I am currently working on my frame relay PSTN. I am able to get my PSTN ports to come up, but I am having issues with my framerelay.I thin is a cable issue because the ports are down/ down. I was wondering what type of cables are need for the frame relay ports. I am following the IPexpert and using vwics.
Thank you
Correct Answer by Carlo Poggiarelli about 4 years 3 weeks ago
Hi Curtis.
Now the problem is Frame Relay related I guess..
Try to set clock on the dce side and see if it works
Bye
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Overall Rating: 5 (1 ratings)
Carlo Poggiarelli Mon, 07/22/2013 - 10:18
  • Green, 3000 points or more
Hi.
You should use a DTE/DCE cable to achieve what you are trying.
Carlo
Curtis Fuentes Mon, 07/22/2013 - 12:34
       Keep in mind that I am using Vwic cards not WIC cards.
Thank you
Carlo Poggiarelli Mon, 07/22/2013 - 20:32
Ops..
Sorry Curtis.
In my case  worked an RJ45 with the following pinout:
1-2-3-4-5-6-7-8 ---> 4-5-3-1-2-6-7-8
You can try it and hope this helps.
If you can, please post your config.
Carlo
Carlo Poggiarelli Tue, 07/23/2013 - 05:43
Hi.
VWIC can also be configured as WAN interface  loosing Voice capability.
http://www.cisco.com/en/US/prod/collateral/routers/ps274/product_data_sheet09186a0080091b9c_ps259_Products_Data_Sheet.html
Curtin, you can  try to decrease speed on your channel-group
Carlo
Curtis Fuentes Tue, 07/23/2013 - 07:06
Thanks I will try it tonight when I get off work. Below is the config offered by IPexperts.
Branch office
controller T1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-3,24 service mgcp
controller T1 0/0/1
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/0/1:0
no ip address
encapsulation frame-relay IETF
no fair-queue
frame-relay lmi-type ansi
PSTN
controller T1 0/0/0
framing esf
clock source internal
linecode b8zs
controller T1 0/3/1
framing esf
linecode b8zs
pri-group timeslots 1-3,23-24
description ** T1 VOICE CONNECTION TO BR1-RTR ** description ** SERIAL DATA CONNECTION TO BR1-RTR **
interface Serial0/0/0:0
description ** T1 DATA CONNECTION TO BR1-RTR **
no ip address
frame-relay intf-type dce
frame-relay route 101 interface Serial0/1/0:0 201
interface Serial0/3/1:23
description ** T1 PRI D-CHANNEL TO BR1-RTR **
no ip address
encapsulation hdlc
isdn protocol-emulate network
no cdp enable
Curtis Fuentes Wed, 07/24/2013 - 06:06
Hi Carlo,
    I   used the pinout you gave me the ligh on the cards are green. The issue that I have now isthe interface is up but the protocol is down.
Correct Answer
Carlo Poggiarelli Wed, 07/24/2013 - 06:17
Hi Curtis.
Bye
Carlo
Carlo Poggiarelli Thu, 07/25/2013 - 11:18
Glad to help.
Regards.
Carlo
