Warning message
Can Local Speed Dials(System Speed dials) be configured on CUCM 7
Answered Question
Jul 23rd, 2013
Hello Everyone,
There is a 'local speed-dial' Cisco CME feature which provides a system-wide list of frequently called numbers (up to 32) accessible from the directory button on the phone. ( this is done by creating/uploading speeddial.xml file )
I wanted to know if this feature is availabe on CUCM  System version: 7.1.5.33900-10
Please help
Thank you!
Atul
Correct Answer by Jaime Valencia about 4 years 3 weeks ago
No, closest thing you get is to configure translation patterns to do the same.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
