Cisco ASA 5505 rebooting randomly
Answered Question
Jul 23rd, 2013
Hello Support . I have Cisco ASA 5505 rebooting
randomly i have this issue recently it was working fine . please help to correct or identify the issue .
Cisco Adaptive Security Appliance Software Version 8.2(1)
Device Manager Version 6.2(5)
Compiled on Tue 05-May-09 22:45 by builders
System image file is "disk0:/Asa821-k8.bin"
Config file at boot was "startup-config"
EscapeASA up 7 hours 20 mins
Hardware:   ASA5505, 256 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash Firmware Hub @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
                             Boot microcode   : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.04
0: Int: Internal-Data0/0    : address is 8843.e112.0863, irq 11
1: Ext: Ethernet0/0         : address is 8843.e112.085b, irq 255
2: Ext: Ethernet0/1         : address is 8843.e112.085c, irq 255
3: Ext: Ethernet0/2         : address is 8843.e112.085d, irq 255
4: Ext: Ethernet0/3         : address is 8843.e112.085e, irq 255
5: Ext: Ethernet0/4         : address is 8843.e112.085f, irq 255
6: Ext: Ethernet0/5         : address is 8843.e112.0860, irq 255
7: Ext: Ethernet0/6         : address is 8843.e112.0861, irq 255
8: Ext: Ethernet0/7         : address is 8843.e112.0862, irq 255
9: Int: Internal-Data0/1    : address is 0000.0003.0002, irq 255
10: Int: Not used            : irq 255
11: Int: Not used            : irq 255
Licensed features for this platform:
Maximum Physical Interfaces  : 8
VLANs                        : 3, DMZ Restricted
Inside Hosts                 : 50
Failover                     : Disabled
VPN-DES                      : Enabled
VPN-3DES-AES                 : Enabled
SSL VPN Peers                : 2
Total VPN Peers              : 10
Dual ISPs                    : Disabled
VLAN Trunk Ports             : 0
Shared License               : Disabled
AnyConnect for Mobile        : Disabled
AnyConnect for Linksys phone : Disabled
AnyConnect Essentials        : Disabled
Advanced Endpoint Assessment : Disabled
UC Phone Proxy Sessions      : 2
Total UC Proxy Sessions      : 2
Botnet Traffic Filter        : Disabled
This platform has a Base license.
Configuration register is 0x1
Configuration has not been modified since last system restart.
7/23/2013 12:00 PMEscapeASA rebooted at 23/07/2013 11:59:00
7/23/2013 11:18 AMEscapeASA rebooted at 23/07/2013 11:18:00
7/23/2013 11:12 AMEscapeASA rebooted at 23/07/2013 11:12:00
7/23/2013 1:54 AMEscapeASA rebooted at 23/07/2013 01:54:00
7/22/2013 10:10 AMEscapeASA rebooted at 22/07/2013 10:10:00
7/21/2013 3:21 PMEscapeASA rebooted at 21/07/2013 15:20:00
7/20/2013 8:48 PMEscapeASA rebooted at 20/07/2013 20:47:00
7/20/2013 8:26 PMEscapeASA rebooted at 20/07/2013 20:25:00
7/20/2013 7:16 PMEscapeASA rebooted at 20/07/2013 19:15:00
7/20/2013 3:39 PM
EscapeASA rebooted at 20/07/2013 15:39:00
Correct Answer by Favaloro. about 4 years 3 weeks ago
Here ya go.
http://jgit.ca/2d
Also, the problem seems to be related to logging, so, let's turn it off until the upgrade happens with a:
"no logging enable"
Overall Rating: 5 (2 ratings)
Favaloro. Tue, 07/23/2013 - 12:09
The firewall might be crashing. check the "show crash" and try to confirm it.
There might also be a problem with its power supply. try a different one.
Is there a pattern on the events?
How many people work on the ASA at any given time?
Haider Malik Wed, 07/24/2013 - 07:53
Thanks  i have included crash dumps . Firewall is rebooting intermittently ,
Please note i am the only person who has access to this firewall. I have arranged another power supply however i will have to post to the location as its remote site . i have included reboot history
sh crash
: Saved_Crash
Thread Name: logger_save
Abort: Assert failure
    vector 0x00000020
       edi 0x09e31fd0
       esi 0xd519d5b0
       ebp 0xd27ee998
       esp 0xd27eef30
       ebx 0x09e31d60
       edx 0x095958c0
       ecx 0x000002e7
       eax 0x09e31d80
error code n/a
       eip 0x0928d96b
        cs 0x00000073
    eflags 0x00003246
       CR2 0x00000000
Hardware:   ASA5505
Crashinfo collected on 04:07:00.969 UTC Wed Jul 24 2013
Traceback:
0: 0805d0d3
1: 0805db77
2: 08a23d7c
3: dd7a86d5
4: dd58d1e0
5: 08a21f5f
6: 0928d9b3
7: 08062bff
8: 08062f36
9: dd5a7d14
10: 08a23009
11: 08a23566
12: dd57b4f4
13: 0804c921
Stack dump: base:0xd27ee898 size:48252300, active:48252300
entries above '==': return PC preceded by input parameters
entries below '==': local variables followed by saved regs
             '==Fn': stack frame n, contains next stack frame
                '*': stack pointer at crash
For example:
    0xeeeeef00: 0x005d0707     : arg3
    0xeeeeeefc: 0x00000159     : arg2
    0xeeeeeef8: 0x005d0722     : arg1
    0xeeeeeef4: 0x005d1754     : return PC
    0xeeeeeef0: 0xeeeeef20 ==F2: stack frame F2
    0xeeeeeeec: 0x00def9e0     : local variable
    0xeeeeeee8: 0x0187df9e     : local variable or saved reg
    0xeeeeeee4: 0x01191548     : local variable or saved reg
    0xeeeeeee0: 0x014dde20     : local variable or saved reg
0xddfffec8-0xddfffec4: 0x00000000
0xddfffec0: 0xddfffedb
0xddfffebc: 0x0000000f
0xddfffeb8: 0x00000000
0xddfffeb4: 0x00000017
0xddfffeb0: 0x00000000
0xddfffeac: 0x0000000e
0xddfffea8: 0x00000000
0xddfffea4: 0x0000000d
0xddfffea0: 0x00000000
0xddfffe9c: 0x0000000c
0xddfffe98: 0x00000000
0xddfffe94: 0x0000000b
0xddfffe90: 0x0804c900
0xddfffe8c: 0x00000009
0xddfffe88: 0x00000000
0xddfffe84: 0x00000008
0xddfffe80: 0xdd7ee000
0xddfffe7c: 0x00000007
0xddfffe78: 0x00000008
0xddfffe74: 0x00000005
0xddfffe70: 0x00000020
0xddfffe6c: 0x00000004
0xddfffe68: 0x08048034
0xddfffe64: 0x00000003
0xddfffe60: 0x00000064
0xddfffe5c: 0x00000011
0xddfffe58: 0x00001000
0xddfffe54: 0x00000006
0xddfffe50: 0x0088a93d
0xddfffe4c: 0x00000010
0xddfffe48: 0xffffe000
0xddfffe44: 0x00000021
0xddfffe40: 0xffffe400
0xddfffe3c: 0x00000020
0xddfffe38: 0x00000000
0xddfffe34: 0xddffffd0
0xddfffe30: 0xddffffca
0xddfffe2c: 0xddffff8e
0xddfffe28: 0xddffff80
0xddfffe24: 0xddffff76
0xddfffe20: 0xddffff68
0xddfffe1c: 0xddffff45
0xddfffe18: 0xddffff3a
0xddfffe14: 0xddffff33
0xddfffe10: 0xddffff05
0xddfffe0c: 0xddfffefb
0xddfffe08: 0x00000000
0xddfffe04: 0xddfffef8
0xddfffe00: 0xddfffef5
0xddfffdfc: 0xddfffef1
0xddfffdf8: 0xddfffeee
0xddfffdf4: 0xddfffee9
0xddfffdf0: 0x00000005
0xddfffdec: 0xdd800f5c
0xddfffde8: 0xddfffdec
0xddfffde4: 0xdd7f884c
0xddfffde0: 0x09319562
0xddfffddc: 0x09319508
0xddfffdd8: 0xddfffdf4
0xddfffdd4: 0x00000005
0xddfffdd0: 0x08a23030
0xddfffdcc: 0x0804c921
0xddfffdc8: 0x00000000 ==F12
0xddfffdc4: 0x0804c900
0xddfffdc0: 0x00000005
0xddfffdbc: 0xdd8009b0
0xddfffdb8: 0xddfffe0c
0xddfffdb4: 0xddfffdf4
0xddfffdb0: 0x00000005
0xddfffdac: 0xdd57b4f4
0xddfffda8: 0xddfffdc8 ==F11
0xddfffda4: 0xddfffdf4
0xddfffda0: 0xdd7f884c
0xddfffd9c: 0xdd67bed8
0xddfffd98-0xddfffd24: 0xffffffff
0xddfffd20: 0x00018d7b
0xddfffd1c: 0x51ef5031
0xddfffd18: 0x00000000
0xddfffd14: 0x10000004
0xddfffd10-0xddfffc98: 0xffffffff
0xddfffc94: 0xbe3f7b07
0xddfffc90: 0x08a237c0
0xddfffc8c: 0x006515da
0xddfffc88: 0x00000000
0xddfffc84: 0xdd7ed000
0xddfffc80: 0x08048e48
0xddfffc7c: 0x00000030
0xddfffc78: 0x00000009
0xddfffc74: 0x00000001
0xddfffc70: 0x00000002
0xddfffc6c: 0x00000008
0xddfffc68: 0x000000ff
0xddfffc64-0xddfffc60: 0x00000000
0xddfffc5c: 0x08a23566
0xddfffc58: 0xddfffda8 ==F10
0xddfffc54: 0xddfffc90
0xddfffc50: 0x01da27ed
0xddfffc4c: 0x000000ff
0xddfffc48: 0x0000c004
0xddfffc44-0xddfffc40: 0x00000000
0xddfffc3c-0xddfffbc4: 0xffffffff
0xddfffbc0: 0xbe3e7307
0xddfffbbc: 0xffffffff
0xddfffbb8: 0x00000000
0xddfffbb4: 0xddfffbc0
0xddfffbb0-0xddfffbac: 0x00000000
0xddfffba8: 0x08a227f0
0xddfffba4: 0x00000000
0xddfffba0: 0xddfffc48
0xddfffb9c: 0x08a23009
0xddfffb98: 0xddfffc58 ==F9
0xddfffb94: 0x0000c004
0xddfffb90: 0xd28f1000
0xddfffb8c-0xddfffb84: 0x00000000
0xddfffb80: 0x00100000
0xddfffb7c: 0xd28ef000
0xddfffb78: 0x00000001
0xddfffb74: 0x00001000
0xddfffb70: 0x00000000
0xddfffb6c: 0x00000001
0xddfffb68: 0x00000000
0xddfffb64: 0x00000001
0xddfffb60: 0x00000000
0xddfffb5c: 0x0912f090
0xddfffb58: 0xddfffb78
0xddfffb54: 0x00000000
0xddfffb50: 0x00000001
0xddfffb4c: 0xd59a7ac0
0xddfffb48: 0x08a2d7e0
0xddfffb44-0xddfffb40: 0xddfffb60
0xddfffb3c: 0x08a2d48c
0xddfffb38: 0xddfffb98
0xddfffb34: 0x00000000
0xddfffb30: 0xd27ef000
0xddfffb2c: 0xd59a7ac0
0xddfffb28: 0xddfffb38
0xddfffb24: 0x00100000
0xddfffb20: 0xddfffb60
0xddfffb1c: 0xdd7a23cd
0xddfffb18: 0xddfffb38
0xddfffb14: 0xddfffb60
0xddfffb10: 0xdd7aa194
0xddfffb0c: 0xdd7a232f
0xddfffb08: 0xd59a7ac0
0xddfffb04: 0x09f62f60
0xddfffb00: 0xd5000008
0xddfffafc: 0xddfffb1c
0xddfffaf8: 0x00000070
0xddfffaf4: 0x00000000
0xddfffaf0: 0xd59a7ac0
0xddfffaec: 0x08a7f9bf
0xddfffae8: 0xddfffb18
0xddfffae4: 0x00000001
0xddfffae0: 0x000000a0
0xddfffadc: 0x00000000
0xddfffad8: 0xddfffae8
0xddfffad4: 0x000000a0
0xddfffad0: 0xd59a7ac0
0xddfffacc: 0x0927fced
0xddfffac8: 0xddfffae8
0xddfffac4-0xddfffac0: 0xd59a7ac0
0xddfffabc: 0x0927f84b
0xddfffab8: 0xddfffae8
0xddfffab4: 0x000000dd
0xddfffab0: 0xd59a7ac0
0xddfffaac: 0x0927d8d9
0xddfffaa8: 0xd5000008
0xddfffaa4-0xddfffaa0: 0xd59a7ac0
0xddfffa9c: 0x00000070
0xddfffa98: 0xfffffffe
0xddfffa94: 0xbe3a7207
0xddfffa90: 0xd59a7ac0
0xddfffa8c: 0x08a2d7e0
0xddfffa88: 0xddfffb60
0xddfffa84: 0x00000000
0xddfffa80: 0xdd7aa360
0xddfffa7c: 0x00000006
0xddfffa78: 0x00000094
0xddfffa74: 0xddfffa80
0xddfffa70: 0xdd7aa360
0xddfffa6c: 0xdd7a5495
0xddfffa68: 0xddfffb38
0xddfffa64: 0xdd7aa360
0xddfffa60: 0xddfffa80
0xddfffa5c: 0xdd7aa194
0xddfffa58: 0xdd7ed19c
0xddfffa54: 0xdd8009b0
0xddfffa50: 0xdd6a0888
0xddfffa4c: 0x000000a0
0xddfffa48: 0xdd7a25fa
0xddfffa44: 0xdd6a0250
0xddfffa40: 0xdd569314
0xddfffa3c: 0xd5000008
0xddfffa38: 0xdd576c02
0xddfffa34: 0x00000003
0xddfffa30: 0xd59a7a68
0xddfffa2c: 0x00000030
0xddfffa28: 0xd5000008
0xddfffa24-0xddfffa20: 0xd599d2c0
0xddfffa1c: 0x0927cbd7
0xddfffa18: 0xddfffaa8
0xddfffa14: 0x2900d4d8
0xddfffa10: 0x00001000
0xddfffa0c: 0xd59a7aa0
0xddfffa08-0xddfffa04: 0x000000a0
0xddfffa00: 0xd596f6c8
0xddfff9fc: 0xdd6a0218
0xddfff9f8: 0x0804a6b2
0xddfff9f4: 0xdd7f5b78
0xddfff9f0: 0x00001000
0xddfff9ec: 0x0927b4ed
0xddfff9e8: 0xddfffa18
0xddfff9e4: 0xd59a7a98
0xddfff9e0: 0x000000a3
0xddfff9dc: 0x00000058
0xddfff9d8: 0x00011378
0xddfff9d4: 0xfffffffe
0xddfff9d0: 0x3e3a7207
0xddfff9cc: 0xd5000008
0xddfff9c8: 0xddfff9d0
0xddfff9c4: 0x00000020
0xddfff9c0: 0xddfff9d0
0xddfff9bc: 0xdd7a5bf6
0xddfff9b8: 0xddfffa68
0xddfff9b4: 0xddfff9d0
0xddfff9b0: 0xdd7aa354
0xddfff9ac: 0xdd7aa194
0xddfff9a8: 0xddfffa38
0xddfff9a4: 0x2900d4d8
0xddfff9a0: 0x00001000
0xddfff99c: 0xdd58d397
0xddfff998: 0xddfff9b8
0xddfff994: 0xdd57b668
0xddfff990: 0x0077b858
0xddfff98c: 0xfffffffe
0xddfff988: 0xddfff9b8
0xddfff984: 0xd59a79f0
0xddfff980: 0x00000053
0xddfff97c: 0xdd63bf31
0xddfff978: 0xddfff9a8
0xddfff974: 0xd59a7a40
0xddfff970: 0x0000005b
0xddfff96c: 0x0927b4ed
0xddfff968: 0xddfff998
0xddfff964: 0xd599d298
0xddfff960: 0x0000005b
0xddfff95c: 0x0927b4ed
0xddfff958: 0xddfff988
0xddfff954: 0xd596f650
0xddfff950: 0x00000053
0xddfff94c: 0x092973c1
0xddfff948: 0xddfffa68
0xddfff944: 0x094ad9b3
0xddfff940: 0x00000065
0xddfff93c: 0x092973c1
0xddfff938: 0xddfffa58
0xddfff934: 0x093d5977
0xddfff930: 0x00000065
0xddfff92c: 0x00000400
0xddfff928: 0xddfff960
0xddfff924: 0x00000008
0xddfff920: 0x00000003
0xddfff91c: 0xdd5ce139
0xddfff918: 0xddfff938
0xddfff914: 0xd57ae970
0xddfff910: 0xd5000008
0xddfff90c: 0x080601e2
0xddfff908: 0x00000001
0xddfff904: 0x00000000
0xddfff900: 0xd57a99b0
0xddfff8fc: 0x08a7f9bf
0xddfff8f8: 0xddfff928
0xddfff8f4: 0x00000001
0xddfff8f0: 0x00000038
0xddfff8ec: 0x00000000
0xddfff8e8: 0xddfff8f8
0xddfff8e4: 0x00000038
0xddfff8e0: 0xd57a99b0
0xddfff8dc: 0x0927fced
0xddfff8d8: 0xddfff8f8
0xddfff8d4-0xddfff8d0: 0xd57a99b0
0xddfff8cc: 0x0927f84b
0xddfff8c8: 0xddfff8f8
0xddfff8c4: 0x000000dd
0xddfff8c0: 0xd57a99b0
0xddfff8bc: 0x0927d8d9
0xddfff8b8: 0xd5000008
0xddfff8b4-0xddfff8b0: 0xd57a99b0
0xddfff8ac: 0x00000001
0xddfff8a8: 0xddfff8b8
0xddfff8a4: 0x00000058
0xddfff8a0: 0xd577a968
0xddfff89c: 0x0927fced
0xddfff898: 0xddfff8b8
0xddfff894: 0x09f62f60
0xddfff890: 0xd5000008
0xddfff88c: 0x0927f84b
0xddfff888: 0xddfff8b8
0xddfff884: 0x000000dd
0xddfff880: 0xd577a968
0xddfff87c: 0x0927d8d9
0xddfff878: 0xd5000008
0xddfff874-0xddfff870: 0xd577a968
0xddfff86c: 0x00000028
0xddfff868: 0xddfff88c
0xddfff864: 0x0000015a
0xddfff860: 0xddfff88c
0xddfff85c: 0x00000038
0xddfff858: 0xddfff998
0xddfff854: 0xddfff9bd
0xddfff850: 0x09435f2b
0xddfff84c: 0xd5000008
0xddfff848: 0x00000004
0xddfff844: 0x00000001
0xddfff840: 0xddfff88c
0xddfff83c: 0x00000003
0xddfff838: 0x00000004
0xddfff834: 0xddfff88c
0xddfff830: 0x0000003f
0xddfff82c: 0x0927cbd7
0xddfff828: 0xddfff8b8
0xddfff824: 0x2900d4d8
0xddfff820: 0x00001000
0xddfff81c: 0xd57a9990
0xddfff818-0xddfff814: 0x00000038
0xddfff810: 0x00000001
0xddfff80c: 0x00000000
0xddfff808: 0xddfff898
0xddfff804-0xddfff800: 0x00000000
0xddfff7fc: 0x0927b4ed
0xddfff7f8: 0xddfff828
0xddfff7f4: 0xd57a9988
0xddfff7f0: 0x0000003b
0xddfff7ec: 0x0927cbd7
0xddfff7e8: 0xddfff878
0xddfff7e4: 0x2900d4d8
0xddfff7e0: 0x00001000
0xddfff7dc: 0xd577a948
0xddfff7d8-0xddfff7d4: 0x00000058
0xddfff7d0: 0x00002033
0xddfff7cc: 0x09297185
0xddfff7c8: 0xddfff8e8
0xddfff7c4: 0x00000000
0xddfff7c0: 0xddfff8bd
0xddfff7bc: 0x0927b4ed
0xddfff7b8: 0xddfff7e8
0xddfff7b4: 0xd577a940
0xddfff7b0: 0x0000005b
0xddfff7ac: 0x08a27866
0xddfff7a8: 0xddfff7c8
0xddfff7a4: 0x00000000
0xddfff7a0-0xddfff79c: 0xddfff7e4
0xddfff798: 0x00000000
0xddfff794: 0x29000000
0xddfff790: 0x00001000
0xddfff78c: 0xdd7a8961
0xddfff788: 0xffff0000
0xddfff784: 0x00000611
0xddfff780-0xddfff75c: 0x00000000
0xddfff758: 0x00000008
0xddfff754-0xddfff750: 0x51ef5038
0xddfff74c: 0x08a2843d
0xddfff748: 0xddfffb98
0xddfff744: 0x51ef5038
0xddfff740: 0xdd5f10a0
0xddfff73c: 0x0000000c
0xddfff738: 0x00000000
0xddfff734: 0x09d522ec
0xddfff730: 0x0992d5e0
0xddfff72c: 0x08a2d5ab
0xddfff728: 0xddfff748
0xddfff724: 0x0000c004
0xddfff720: 0x00000001
0xddfff71c: 0x51ef5038
0xddfff718: 0x00000001
0xddfff714: 0xdd7aa360
0xddfff710: 0xddfff748
0xddfff70c: 0xdd7a295b
0xddfff708: 0x0992d5e0
0xddfff704: 0x00000000
0xddfff700: 0xdd79fc44
0xddfff6fc: 0x08049c98
0xddfff6f8: 0x097e04bc
0xddfff6f4: 0xddfff708
0xddfff6f0: 0xdd7aa360
0xddfff6ec: 0xdd7a2ad9
0xddfff6e8: 0xddfff728
0xddfff6e4-0xddfff6e0: 0x00000000
0xddfff6dc: 0xdd7aa194
0xddfff6d8: 0xddfff6e8
0xddfff6d4: 0x0992d5e0
0xddfff6d0: 0xdd7aa360
0xddfff6cc: 0xdd7aa194
0xddfff6c8: 0xdd7ed000
0xddfff6c4: 0xdd8009b0
0xddfff6c0: 0x09d522fc
0xddfff6bc: 0xdd7a6fad
0xddfff6b8: 0xffffffff
0xddfff6b4: 0x00000000
0xddfff6b0: 0x0000000c
0xddfff6ac: 0xdd7a72b8
0xddfff6a8: 0x00000080
0xddfff6a4: 0x00000000
0xddfff6a0: 0xddfff6b0
0xddfff69c: 0xdd7a717c
0xddfff698: 0xddfff748
0xddfff694: 0xdd6a0250
0xddfff690: 0xdd5699f4
0xddfff68c: 0xdd7a232f
0xddfff688: 0xd59a7bb8
0xddfff684: 0xdd7ed000
0xddfff680: 0xddfff720
0xddfff67c: 0x0fcdaa95
0xddfff678: 0x00000000
0xddfff674: 0xdd7ed540
0xddfff670: 0xdd79fc44
0xddfff66c: 0x08a7f9bf
0xddfff668: 0xddfff698
0xddfff664: 0xdd7ed000
0xddfff660: 0xddfff700
0xddfff65c: 0x0fa921e4
0xddfff658: 0x00000000
0xddfff654: 0xfffffffe
0xddfff650: 0x3e3a7207
0xddfff64c: 0x0927fced
0xddfff648: 0xddfff650
0xddfff644: 0x00000020
0xddfff640: 0xddfff650
0xddfff63c: 0xdd7a5bf6
0xddfff638: 0xddfff6e8
0xddfff634: 0xddfff650
0xddfff630: 0xdd7aa354
0xddfff62c: 0xdd7aa194
0xddfff628: 0xdd7ed150
0xddfff624: 0xddfff690
0xddfff620: 0x08049bf8
0xddfff61c: 0xdd67bed8
0xddfff618: 0xddfff638
0xddfff614: 0xdd7aa354
0xddfff610: 0xdd67bed8
0xddfff60c: 0x00000001
0xddfff608: 0xdd7ed150
0xddfff604: 0xddfff670
0xddfff600: 0x080497e8
0xddfff5fc: 0xdd63bf31
0xddfff5f8: 0x08049e20
0xddfff5f4: 0xdd7f4b95
0xddfff5f0: 0xddfff6d0
0xddfff5ec: 0x08049e20
0xddfff5e8: 0xdd7ed19c
0xddfff5e4: 0xdd8009b0
0xddfff5e0: 0xdd6a0898
0xddfff5dc: 0xdd6a07f0
0xddfff5d8: 0x00000009
0xddfff5d4: 0xdd7ed540
0xddfff5d0: 0xdd79ee54
0xddfff5cc: 0xdd7a00e4
0xddfff5c8: 0xdd7a104c
0xddfff5c4: 0x00000009
0xddfff5c0: 0xddfff610
0xddfff5bc: 0x00000090
0xddfff5b8: 0x00000000
0xddfff5b4: 0xdd8009b0
0xddfff5b0: 0x00000000
0xddfff5ac: 0x0804ac51
0xddfff5a8: 0xdd7a1014
0xddfff5a4: 0xdd7f5a61
0xddfff5a0: 0xddfff5f0
0xddfff59c: 0x08048d08
0xddfff598: 0x00000000
0xddfff594: 0xdd8009b0
0xddfff590: 0x00001000
0xddfff58c: 0xdd7ed218
0xddfff588: 0x08049c99
0xddfff584: 0xdd7f5b78
0xddfff580-0xddfff570: 0x00000000
0xddfff56c: 0x0927b4ed
0xddfff568: 0xddfff598
0xddfff564: 0xd59a7b90
0xddfff560: 0x000000a3
0xddfff55c-0xddfff558: 0x00000000
0xddfff554: 0xfffffffe
0xddfff550: 0x3e3a7207
0xddfff54c: 0x00000000
0xddfff548: 0xddfff550
0xddfff544: 0x00000020
0xddfff540: 0xddfff550
0xddfff53c: 0xdd7a5bf6
0xddfff538: 0xddfff5e8
0xddfff534: 0xddfff550
0xddfff530: 0xdd7aa354
0xddfff52c: 0xdd7aa194
0xddfff528-0xddfff520: 0x00000000
0xddfff51c: 0xdd58d397
0xddfff518: 0xddfff538
0xddfff514: 0xdd57b668
0xddfff510: 0x0077b858
0xddfff50c: 0xfffffffe
0xddfff508-0xddfff500: 0x00000000
0xddfff4fc: 0xdd63bf31
0xddfff4f8-0xddfff3f0: 0x00000000
0xddfff3ec: 0x00000001
0xddfff3e8-0xddfff30c: 0x00000000
0xddfff308: 0xffff0000
0xddfff304-0xddfff2a8: 0x00000000
0xddfff2a4: 0xffffffff
0xddfff2a0: 0xffff0000
0xddfff29c: 0xffff037f
0xddfff298: 0x00000000
0xddfff294: 0xbe3a7207
0xddfff290: 0xddfff29c
0xddfff28c: 0x0000007b
0xddfff288: 0xddfff51c
0xddfff284: 0x00003246
0xddfff280: 0x00000073
0xddfff27c: 0xdd58d376
0xddfff278-0xddfff274: 0x00000000
0xddfff270: 0xfffffffc
0xddfff26c: 0x00000008
0xddfff268: 0x00000000
0xddfff264: 0xddfff550
0xddfff260: 0xddfff51c
0xddfff25c: 0xddfff538
0xddfff258: 0xdd7aa354
0xddfff254: 0x00000000
0xddfff250-0xddfff24c: 0x0000007b
0xddfff248: 0x00000033
0xddfff244: 0x00000007
0xddfff240: 0x00000020
0xddfff23c: 0xdd58d1e8
0xddfff238: 0xddfff538
0xddfff234: 0xddfff550
0xddfff230: 0x00000004
0xddfff22c-0xddfff220: 0x00000000
0xddfff21c: 0xdd7a583b
0xddfff218-0xddfff1ec: 0x00000000
0xddfff1e8: 0x20640000
0xddfff1e4-0xddfff160: 0x00000000
0xddfff15c: 0xddfff6f7
0xddfff158-0xddfff118: 0x00000000
0xddfff114: 0x0959559f
0xddfff110: 0xddfff750
0xddfff10c: 0xdd5ab85a
0xddfff108: 0xddfff718
0xddfff104: 0xddfff6f7
0xddfff100: 0x0959559f
0xddfff0fc: 0x00000000
0xddfff0f8: 0xdd66dee0
0xddfff0f4: 0xdd5adf0c
0xddfff0f0: 0x00000000
0xddfff0ec: 0xdd5adfd1
0xddfff0e8-0xddfff0e0: 0x00000000
0xddfff0dc: 0xdd66f63c
0xddfff0d8: 0x00000001
0xddfff0d4-0xddfff0cc: 0x00000000
0xddfff0c8: 0x00000001
0xddfff0c4: 0xdd66f63c
0xddfff0c0: 0xddfff750
0xddfff0bc: 0xdd5c3e8e
0xddfff0b8: 0xddfff108
0xddfff0b4: 0xddfff750
0xddfff0b0: 0x00000001
0xddfff0ac-0xddffeffc: 0x00000000
0xddffeff8: 0x00020001
0xddffeff4: 0x0102007f
0xddffeff0: 0x00001b58
0xddffefec: 0x00000001
0xddffefe8-0xddffefe4: 0x00000000
0xddffefe0: 0x00000001
0xddffefdc: 0x00000000
0xddffefd8: 0x00020001
0xddffefd4: 0xddffefdc
0xddffefd0: 0x00000001
0xddffefcc: 0x08bb799c
0xddffefc8: 0xddfffad8
0xddffefc4: 0x00000002
0xddffefc0: 0x00000001
0xddffefbc: 0x00000000
0xddffefb8: 0x00000af0
0xddffefb4: 0xd51e70f8
0xddffefb0: 0xddffefdc
0xddffefac: 0x08098924
0xddffefa8: 0xddffefc8
0xddffefa4: 0xddffefdc
0xddffefa0: 0x09cc902c
0xddffef9c: 0x08099f5d
0xddffef98: 0xddffefa8
0xddffef94: 0x00000000
0xddffef90: 0xddffefbc
0xddffef8c: 0x08098924
0xddffef88: 0xddffefa8
0xddffef84: 0xddffefbc
0xddffef80: 0x09cc902c
0xddffef7c: 0x09276b5d
0xddffef78: 0xddffef98
0xddffef74: 0xddffefdc
0xddffef70: 0x09cc902c
0xddffef6c: 0x0927f84b
0xddffef68: 0xddffef98
0xddffef64: 0x000000dd
0xddffef60: 0x09cc902c
0xddffef5c: 0x09276b5d
0xddffef58: 0xddffef78
0xddffef54: 0xddffefbc
0xddffef50: 0x09cc902c
0xddffef4c: 0x0000100c
0xddffef48-0xddffef10: 0x00000000
0xddffef0c: 0xffffffff
0xddffef08: 0x0000000d
0xddffef04: 0x09594cb7
0xddffef00: 0x00000000
0xddffeefc: 0x00004060
0xddffeef8: 0xddfff53c
0xddffeef4: 0x00000000
0xddffeef0: 0x00000016
0xddffeeec-0xddffeedc: 0x00000000
0xddffeed8: 0xddfff004
0xddffeed4: 0x00000001
0xddffeed0: 0x09593ba7
0xddffeecc: 0x0927cbd7
0xddffeec8: 0xddffef58
0xddffeec4: 0x2900d4d8
0xddffeec0: 0x00001000
0xddffeebc: 0xd529e818
0xddffeeb8-0xddffeeb4: 0x00004060
0xddffeeb0: 0x00000016
0xddffeeac: 0x00000008
0xddffeea8: 0xddfff004
0xddffeea4: 0x00000016
0xddffeea0: 0xddffeeec
0xddffee9c: 0x0927b4ed
0xddffee98: 0xddffeec8
0xddffee94: 0xd529e810
0xddffee90: 0x00004063
0xddffee8c: 0x00000016
0xddffee88: 0x00000017
0xddffee84: 0x00000016
0xddffee80: 0xddffeeec
0xddffee7c: 0x081c0659
0xddffee78: 0xddffee98
0xddffee74: 0x00000000
0xddffee70: 0x09cb6f18
0xddffee6c: 0x08059d0f
0xddffee68: 0xddffee98
0xddffee64: 0xddffeeec
0xddffee60-0xddffee5c: 0x00000017
0xddffee58-0xddffee50: 0x00000000
0xddffee4c: 0x00000001
0xddffee48: 0xddffeff8
0xddffee44: 0x00000000
0xddffee40: 0xffffffff
0xddffee3c: 0x00000000
0xddffee38: 0x00000016
0xddffee34: 0xddffeeec
0xddffee30: 0xddffee44
0xddffee2c: 0x08a27beb
0xddffee28: 0xddffee78
0xddffee24: 0xddffeeec
0xddffee20: 0xddffee44
0xddffee1c: 0x00000000
0xddffee18: 0x00000802
0xddffee14: 0x00000004
0xddffee10: 0x00000001
0xddffee0c: 0x08a27866
0xddffee08: 0xddffee28
0xddffee04: 0xddfff090
0xddffee00-0xddffedfc: 0xddffee44
0xddffedf8: 0x00004008
0xddffedf4: 0x02000010
0xddffedf0: 0x02b00007
0xddffedec: 0xdd7aa194
0xddffede8: 0x0000000c
0xddffede4: 0xddffef02
0xddffede0: 0x09593bbe
0xddffeddc: 0x00000000
0xddffedd8: 0x0000000d
0xddffedd4: 0x09594caa
0xddffedd0: 0xddfff410
0xddffedcc: 0xdd5a9f3e
0xddffedc8: 0xddfff3d8
0xddffedc4: 0x09594caa
0xddffedc0: 0x0000000d
0xddffedbc-0xddffedb8: 0x00000000
0xddffedb4: 0x000000eb
0xddffedb0: 0x00000000
0xddffedac: 0xdd5adfd1
0xddffeda8: 0x00000001
0xddffeda4: 0x00000000
0xddffeda0: 0x00000001
0xddffed9c: 0x00000000
0xddffed98: 0xddffedec
0xddffed94-0xddffed90: 0x00000000
0xddffed8c: 0x09294816
0xddffed88: 0xdd01ee48
0xddffed84: 0x00000000
0xddffed80: 0xddffeeff
0xddffed7c: 0xddffefe0
0xddffed78: 0x09d4bb88
0xddffed74: 0x0000000b
0xddffed70: 0x00120863
0xddffed6c: 0x43201148
0xddffed68-0xddffed60: 0x00000000
0xddffed5c: 0x09296b89
0xddffed58: 0xddffee78
0xddffed54: 0x09593bbc
0xddffed50: 0x0000000a
0xddffed4c: 0x00004008
0xddffed48: 0x02000010
0xddffed44: 0x02b00007
0xddffed40: 0x43201148
0xddffed3c-0xddffec94: 0x00000000
0xddffec90: 0x00000030
0xddffec8c: 0x2e63302f
0xddffec88: 0x30302f69
0xddffec84: 0x63702f73
0xddffec80: 0x75622f63
0xddffec7c: 0x6f72702f
0xddffec78: 0x00000000
0xddffec74: 0x0000000c
0xddffec70-0xddffec6c: 0x00000000
0xddffec68: 0x00000040
0xddffec64: 0xddffedec
0xddffec60: 0x00000004
0xddffec5c: 0x08a299bc
0xddffec58: 0xdd7a8865
0xddffec54: 0x00000040
0xddffec50: 0xddffec7c
0xddffec4c: 0x00000004
0xddffec48: 0x09595590
0xddffec44: 0xdd7f8220
0xddffec40: 0xddffed88
0xddffec3c: 0x00000000
0xddffec38: 0x00000040
0xddffec34: 0xddffedec
0xddffec30: 0x00000004
0xddffec2c: 0xdd7a92a5
0xddffec28: 0xddffec58
0xddffec24: 0x00000040
0xddffec20: 0x00000000
0xddffec1c: 0xdd7aa194
0xddffec18: 0x00000010
0xddffec14: 0x00000000
0xddffec10: 0x00000001
0xddffec0c: 0xdd7aa194
0xddffec08: 0xdd7ed19c
0xddffec04: 0xdd7f803b
0xddffec00: 0xddffec40
0xddffebfc: 0x0804b388
0xddffebf8: 0xdd7ed000
0xddffebf4: 0xdd8009b0
0xddffebf0: 0x0000000f
0xddffebec: 0xdd7a2851
0xddffebe8: 0x00000000
0xddffebe4: 0xddffec20
0xddffebe0-0xddffebd8: 0x00000000
0xddffebd4: 0xdd67c960
0xddffebd0: 0x00000000
0xddffebcc: 0xdd67c4f4
0xddffebc8: 0xddffec28
0xddffebc4-0xddffebb4: 0x00000000
0xddffebb0: 0x00000006
0xddffebac: 0xdd591484
0xddffeba8: 0xddffec08
0xddffeba4: 0xdd7ed540
0xddffeba0: 0xdd79fbb4
0xddffeb9c: 0xffffffff
0xddffeb98: 0x00000000
0xddffeb94: 0xdd7ed000
0xddffeb90: 0xddffec30
0xddffeb8c: 0x00778b74
0xddffeb88-0xddffeb64: 0x00000000
0xddffeb60: 0xddffed7b
0xddffeb5c: 0xddffec7c
0xddffeb58: 0xddffed7b
0xddffeb54: 0xddffec91
0xddffeb50-0xddffeb4c: 0xddffec7c
0xddffeb48: 0x00000001
0xddffeb44: 0x00000000
0xddffeb40: 0xdd6a0868
0xddffeb3c: 0x00000001
0xddffeb38: 0xdd7ed150
0xddffeb34: 0xddffeba0
0xddffeb30: 0x08049118
0xddffeb2c: 0x00778b74
0xddffeb28: 0x08049e02
0xddffeb24: 0xdd7f4b95
0xddffeb20: 0xddffec00
0xddffeb1c: 0x08049e02
0xddffeb18: 0xdd7ed19c
0xddffeb14: 0xdd8009b0
0xddffeb10: 0xdd6a0868
0xddffeb0c: 0xdd6a07f0
0xddffeb08: 0x00000009
0xddffeb04: 0xdd7ed540
0xddffeb00: 0xdd79ee54
0xddffeafc: 0xdd7a00e4
0xddffeaf8: 0xdd7a104c
0xddffeaf4: 0x00000006
0xddffeaf0: 0x0992d340
0xddffeaec: 0x00000060
0xddffeae8: 0xddffed7b
0xddffeae4: 0x30ffec7c
0xddffeae0: 0xddffeb40
0xddffeadc: 0x0804ac5d
0xddffead8: 0xdd7a0ff2
0xddffead4: 0xdd7f5a61
0xddffead0: 0xddffeb20
0xddffeacc: 0x08048d08
0xddffeac8: 0x00000000
0xddffeac4: 0xdd8009b0
0xddffeac0: 0x00000000
0xddffeabc: 0xdd7ed218
0xddffeab8: 0x08049c99
0xddffeab4: 0xdd7f5b78
0xddffeab0: 0x000000dd
0xddffeaac: 0xd5000b40
0xddffeaa8: 0x0927d8d9
0xddffeaa4: 0xd5000008
0xddffeaa0-0xddffea9c: 0xd5000b40
0xddffea98: 0x00000000
0xddffea94: 0xdd6a0250
0xddffea90: 0x00000000
0xddffea8c: 0x00000001
0xddffea88: 0xdd6a0848
0xddffea84: 0xdd7ed19c
0xddffea80: 0xdd7f803b
0xddffea7c: 0xddffeabc
0xddffea78: 0x0804b090
0xddffea74: 0xdd7ed000
0xddffea70: 0xdd8009b0
0xddffea6c: 0xdd571a04
0xddffea68: 0xdd67bef8
0xddffea64-0xddffea60: 0x00000000
0xddffea5c: 0x00000001
0xddffea58: 0xdd6a0838
0xddffea54: 0x00000000
0xddffea50: 0x00000001
0xddffea4c: 0xdd6a0d28
0xddffea48: 0x00000098
0xddffea44: 0xdd7f803b
0xddffea40: 0xddffea80
0xddffea3c: 0xdd57ad48
0xddffea38: 0xd5000008
0xddffea34: 0xdd8009b0
0xddffea30: 0x09595753
0xddffea2c: 0xddffea74
0xddffea28: 0xdd5c17ad
0xddffea24: 0xddffea44
0xddffea20: 0xdd7ed540
0xddffea1c: 0xdd79f064
0xddffea18: 0x0927cbd7
0xddffea14: 0xddffeaa4
0xddffea10: 0x2900d4d8
0xddffea0c: 0x00001000
0xddffea08: 0xd5000b20
0xddffea04-0xddffea00: 0x00000098
0xddffe9fc-0xddffe9f8: 0x00000000
0xddffe9f4: 0x00000001
0xddffe9f0: 0xdd6a0250
0xddffe9ec: 0xdd56a7e4
0xddffe9e8: 0x0927b4ed
0xddffe9e4: 0xddffea14
0xddffe9e0: 0xd5000b18
0xddffe9dc: 0x0000009b
0xddffe9d8: 0x0b09985c
0xddffe9d4: 0xdd6a0250
0xddffe9d0: 0xddffea70
0xddffe9cc: 0x0c0b8fae
0xddffe9c8: 0x00000000
0xddffe9c4: 0x00000001
0xddffe9c0: 0x00000000
0xddffe9bc: 0xdd6a0848
0xddffe9b8: 0x00000001
0xddffe9b4: 0xdd7ed150
0xddffe9b0: 0xddffea1c
0xddffe9ac: 0x08048a68
0xddffe9a8: 0x0c0b8fae
0xddffe9a4: 0x08049cbf
0xddffe9a0: 0xdd7f4b95
0xddffe99c: 0xddffea7c
0xddffe998: 0x08049cbf
0xddffe994: 0xdd7ed19c
0xddffe990: 0xdd8009b0
0xddffe98c: 0xdd6a0848
0xddffe988: 0xdd6a07f0
0xddffe984: 0x00000009
0xddffe980: 0xdd7ed540
0xddffe97c: 0xdd79ee54
0xddffe978: 0xdd7a00e4
0xddffe974: 0xdd7a104c
0xddffe970: 0x00000002
0xddffe96c: 0x0c0b8fae
0xddffe968: 0x00000020
0xddffe964: 0xdd7f4b95
0xddffe960: 0xddffea40
0xddffe95c: 0xdd57205a
0xddffe958: 0x0804ac30
0xddffe954: 0xdd7a0fc6
0xddffe950: 0xdd7f5a61
0xddffe94c: 0xddffe99c
0xddffe948: 0x08048a68
0xddffe944: 0x00000000
0xddffe940: 0xdd8009b0
0xddffe93c: 0xdd7a00e4
0xddffe938: 0xdd7ed218
0xddffe934: 0x08049c99
0xddffe930: 0xdd7f5b78
0xddffe92c: 0x00000020
0xddffe928: 0x0804ac30
0xddffe924: 0xdd576b58
0xddffe920: 0xdd7f5a61
0xddffe91c: 0xdd576b58
0xddffe918: 0xdd7a0fc6
0xddffe914: 0xdd7f5a61
0xddffe910: 0xdd8009b0
0xddffe90c: 0x00000000
0xddffe908: 0xdd6a0218
0xddffe904: 0x0804a6b2
0xddffe900: 0xdd7f5b78
0xddffe8fc-0xddffe8d8: 0x00000000
0xddffe8d4: 0xddffe431
0xddffe8d0-0xddffe8cc: 0x00000000
0xddffe8c8: 0xddffea58
0xddffe8c4: 0x0959576d
0xddffe8c0: 0x64000000
0xddffe8bc: 0x00000001
0xddffe8b8: 0x0000001d
0xddffe8b4: 0x00000020
0xddffe8b0: 0xffffffff
0xddffe8ac-0xddffe8a4: 0x00000000
0xddffe8a0: 0x0000000a
0xddffe89c: 0x00000001
0xddffe898: 0xdd675544
0xddffe894-0xddffe890: 0x00000000
0xddffe88c: 0x00009720
0xddffe888-0xddffe874: 0x00000000
0xddffe870: 0xddffe42c
0xddffe86c: 0x00000100
0xddffe868: 0x00000005
0xddffe864: 0x00000001
0xddffe860-0xddffe828: 0x00000000
0xddffe824: 0xddffe97c
0xddffe820: 0x00000033
0xddffe81c: 0x00000004
0xddffe818: 0xdd5b9ffa
0xddffe814: 0xddffe954
0xddffe810: 0xdd7aa50c
0xddffe80c-0xddffe6d4: 0x00000000
0xddffe6d0: 0xdd67cd60
0xddffe6cc: 0xdd7a666c
0xddffe6c8-0xddffe6ac: 0x00000000
0xddffe6a8: 0x0959559f
0xddffe6a4-0xddffe688: 0x00000000
0xddffe684: 0x09597389
0xddffe680-0xddffe640: 0x00000000
0xddffe63c: 0xffffffff
0xddffe638: 0x00000015
0xddffe634: 0x09595590
0xddffe630: 0x00000000
0xddffe62c: 0xddffeae8
0xddffe628: 0xddffec6c
0xddffe624: 0x00000004
0xddffe620: 0x00000016
0xddffe61c-0xddffe618: 0x00000000
0xddffe614: 0x00000053
0xddffe610: 0x00000000
0xddffe60c: 0x0000000a
0xddffe608-0xddffe5dc: 0x00000000
0xddffe5d8: 0x20640000
0xddffe5d4-0xddffe5cc: 0x00000000
0xddffe5c8: 0x00000001
0xddffe5c4-0xddffe5b8: 0x00000000
0xddffe5b4: 0x20750000
0xddffe5b0-0xddffe550: 0x00000000
0xddffe54c: 0xddffeae7
0xddffe548-0xddffe52c: 0x00000000
0xddffe528: 0xddffeabc
0xddffe524-0xddffe508: 0x00000000
0xddffe504: 0x0959559f
0xddffe500: 0xddffeb40
0xddffe4fc: 0xdd5ab85a
0xddffe4f8: 0xddffeb08
0xddffe4f4: 0xddffeae7
0xddffe4f0: 0x0959559f
0xddffe4ec: 0x00000000
0xddffe4e8: 0xdd66dee0
0xddffe4e4: 0xdd5adf0c
0xddffe4e0: 0x00000000
0xddffe4dc: 0xdd5adfd1
0xddffe4d8: 0xdd5ad8e2
0xddffe4d4: 0xddffeae4
0xddffe4d0: 0x09597387
0xddffe4cc: 0xdd66f63c
0xddffe4c8: 0x00000001
0xddffe4c4: 0xddffe4d4
0xddffe4c0: 0xdd67bed8
0xddffe4bc: 0xdd67c130
0xddffe4b8: 0x00000001
0xddffe4b4: 0xdd66f63c
0xddffe4b0: 0xddffeb40
0xddffe4ac: 0xdd5c3e8e
0xddffe4a8: 0xddffe4f8
0xddffe4a4: 0xddffeb40
0xddffe4a0: 0x00000001
0xddffe49c: 0x00000000
0xddffe498: 0xdd67bed8
0xddffe494: 0x00000053
0xddffe490: 0xdd559000
0xddffe48c: 0xdd67cd60
0xddffe488: 0xdd7a6fad
0xddffe484: 0xddffe4a4
0xddffe480: 0xdd67cd60
0xddffe47c: 0x00000000
0xddffe478: 0xdd7a6e4e
0xddffe474: 0x00000053
0xddffe470: 0xdd559000
0xddffe46c: 0xdd67cd60
0xddffe468: 0xdd5cc289
0xddffe464: 0xddffe484
0xddffe460: 0xffffffff
0xddffe45c: 0x00000053
0xddffe458: 0xdd67bed8
0xddffe454-0xddffe448: 0x00000000
0xddffe444: 0x00000053
0xddffe440: 0xdd559000
0xddffe43c: 0xdd67cd60
0xddffe438: 0xdd5cc335
0xddffe434: 0xddffe464
0xddffe430: 0xffffffff
0xddffe42c: 0xdd67cd60
0xddffe428: 0x00000000
0xddffe424: 0x00000053
0xddffe420: 0xdd559000
0xddffe41c: 0x00000001
0xddffe418: 0xdd5cd478
0xddffe414: 0xdd67bed8
0xddffe410: 0xdd7aa50c
0xddffe40c-0xddffe408: 0xdd67bed8
0xddffe404: 0x00000000
0xddffe400: 0x19999999
0xddffe3fc: 0x00000005
0xddffe3f8: 0xdd7a2851
0xddffe3f4: 0x00000000
0xddffe3f0: 0xddffe42c
0xddffe3ec-0xddffe3dc: 0x00000000
0xddffe3d8: 0xdd67c4f4
0xddffe3d4: 0xddffe431
0xddffe3d0-0xddffe3c0: 0x00000000
0xddffe3bc: 0x00000004
0xddffe3b8: 0xdd590721
0xddffe3b4: 0xddffe414
0xddffe3b0-0xddffe2c0: 0x00000000
0xddffe2bc: 0x0808010b
0xddffe2b8: 0x00000000
0xddffe2b4: 0x00000048
0xddffe2b0: 0x00000000
0xddffe2ac: 0x43201148
0xddffe2a8-0xddffe298: 0x00000000
0xddffe294: 0x0000f801
0xddffe290: 0xe0004000
0xddffe28c: 0x00004008
0xddffe288: 0x02000010
0xddffe284: 0x02b00007
0xddffe280: 0x43201148
0xddffe27c-0xddffe24c: 0x00000000
0xddffe248: 0x00000005
0xddffe244: 0x0000000b
0xddffe240: 0x00000000
0xddffe23c: 0x0000000c
0xddffe238: 0x00000000
0xddffe234: 0x00000002
0xddffe230-0xddffe22c: 0x00000000
0xddffe228: 0x00000031
0xddffe224: 0x094bbe59
0xddffe220: 0x09d4bb2c
0xddffe21c: 0x08a1da5d
0xddffe218: 0xddffed88
0xddffe214: 0x00000031
0xddffe210: 0x094bbe59
0xddffe20c: 0x09d4bad0
0xddffe208-0xddffe200: 0x00000000
0xddffe1fc: 0x080991b0
0xddffe1f8: 0xddffe218
0xddffe1f4: 0x00000001
0xddffe1f0: 0x09cc902c
0xddffe1ec: 0x08099f5d
0xddffe1e8: 0xddffe1f8
0xddffe1e4-0xddffe1d4: 0x00000000
0xddffe1d0: 0x09cc902c
0xddffe1cc: 0x09276b5d
0xddffe1c8: 0xddffe1e8
0xddffe1c4: 0x09d4bb88
0xddffe1c0: 0x09cc902c
0xddffe1bc-0xddffdba4: 0x00000000
0xddffdba0: 0x0000000a
0xddffdb9c: 0x30203136
0xddffdb98: 0x34312030
0xddffdb94: 0x20302030
0xddffdb90: 0x20302032
0xddffdb8c-0xddffdb88: 0x20302030
0xddffdb84: 0x20323220
0xddffdb80: 0x30200000
0xddffdb7c: 0x0a302064
0xddffdb78: 0x656b636f
0xddffdb74: 0x6c625f73
0xddffdb70: 0x636f7270
0xddffdb6c: 0xd5000ec8
0xddffdb68: 0x00000001
0xddffdb64-0xddffdb58: 0x00000000
0xddffdb54: 0x00007461
0xddffdb50: 0x74732f63
0xddffdb4c: 0x6f72702f
0xddffdb48: 0xd5000ec8
0xddffdb44: 0x00002000
0xddffdb40: 0xd5000ec8
0xddffdb3c: 0xdd630e4c
0xddffdb38: 0xddfffb88
0xddffdb34: 0xdd67561b
0xddffdb30: 0xddffdb71
0xddffdb2c: 0xdd67bed8
0xddffdb28: 0x00000000
0xddffdb24: 0xdd67528e
0xddffdb20: 0x00000001
0xddffdb1c: 0x0000000a
0xddffdb18: 0x00001fff
0xddffdb14: 0xddffdb70
0xddffdb10: 0xd5000ec8
0xddffdb0c: 0x00000000
0xddffdb08: 0xddffdb38
0xddffdb04: 0xdd67bed8
0xddffdb00: 0xdd67c760
0xddffdafc: 0x00000001
0xddffdaf8: 0xdd67528e
0xddffdaf4: 0x00000000
0xddffdaf0: 0xd5000ec8
0xddffdaec: 0xdd5c284c
0xddffdae8: 0xddffdb38
0xddffdae4: 0x00000000
0xddffdae0: 0xdd67bed8
0xddffdadc: 0xdd7a6680
0xddffdad8: 0xddffdae8
0xddffdad4: 0xd5000ea8
0xddffdad0: 0xd5000008
0xddffdacc: 0x08a2aec6
0xddffdac8: 0xddffdae8
0xddffdac4-0xddffdac0: 0xd5000ec8
0xddffdabc: 0x00000000
0xddffdab8: 0xddffdae8
0xddffdab4: 0xd5000008
0xddffdab0: 0xd5000ea0
0xddffdaac: 0xdd5ce769
0xddffdaa8: 0xddffdac8
0xddffdaa4: 0xd5000ec8
0xddffdaa0: 0x0000016c
0xddffda9c: 0x0927e8f8
0xddffda98: 0xd5001038
0xddffda94: 0x00000198
0xddffda90: 0xd5000ec8
0xddffda8c: 0xd5000008
0xddffda88: 0xddffdaa8
0xddffda84: 0xdd67c0f0
0xddffda80: 0x00000001
0xddffda7c: 0xdd5cda0d
0xddffda78: 0xddffda88
0xddffda74: 0x00001fff
0xddffda70: 0xd5000ec8
0xddffda6c: 0xdd5cda0d
0xddffda68: 0xddffdae8
0xddffda64: 0xd5000ec8
0xddffda60: 0xdd67528e
0xddffda5c: 0x0927aad2
0xddffda58: 0xddffdac8
0xddffda54: 0xd5000008
0xddffda50: 0xd5000ea0
0xddffda4c: 0xdd7a6fad
0xddffda48: 0x00000400
0xddffda44: 0xdd559000
0xddffda40: 0xd5000ec8
0xddffda3c: 0xdd5cc501
0xddffda38: 0xddffda78
0xddffda34: 0xd5000ec8
0xddffda30-0xddffda2c: 0xdd67bed8
0xddffda28: 0x00000400
0xddffda24: 0xdd559000
0xddffda20: 0x00000004
0xddffda1c: 0xdd5cd37e
0xddffda18: 0xdd67bed8
0xddffda14: 0x00001fff
0xddffda10: 0xd5000ec8
0xddffda0c: 0xdd67bed8
0xddffda08: 0x00000000
0xddffda04: 0xdd674b66
0xddffda00: 0xdd67528f
0xddffd9fc: 0x00000000
0xddffd9f8: 0xf000000d
0xddffd9f4: 0x061268b6
0xddffd9f0: 0x51ef5031
0xddffd9ec: 0x061268b6
0xddffd9e8: 0x51ef5031
0xddffd9e4: 0x061268b6
0xddffd9e0: 0x51ef5031
0xddffd9dc-0xddffd9d8: 0x00000000
0xddffd9d4: 0x00000400
0xddffd9d0-0xddffd9b8: 0x00000000
0xddffd9b4: 0x00000001
0xddffd9b0: 0x00008124
0xddffd9ac: 0xf000000d
0xddffd9a8-0xddffd9a4: 0x00000000
0xddffd9a0: 0x00000003
0xddffd99c-0xddffd994: 0x00000000
0xddffd990: 0xffffffff
0xddffd98c: 0x00000001
0xddffd988: 0xdd559400
0xddffd984: 0xdd559000
0xddffd980: 0xd5000ec8
0xddffd97c: 0xdd5c26f9
0xddffd978: 0xddffda18
0xddffd974: 0xd5000ec8
0xddffd970: 0xdd67bed8
0xddffd96c: 0x00000400
0xddffd968: 0xddffd9a0
0xddffd964: 0x00000004
0xddffd960: 0x00000003
0xddffd95c: 0xdd5ce139
0xddffd958: 0xddffd978
0xddffd954: 0xd5000ec8
0xddffd950: 0x0000019b
0xddffd94c-0xddffd6d0: 0x00000000
0xddffd6cc: 0xddffdb83
0xddffd6c8-0xddffd6c0: 0x00000000
0xddffd6bc: 0x00000070
0xddffd6b8-0xddffd6b0: 0x00000000
0xddffd6ac: 0xddffdb24
0xddffd6a8: 0xddffdb20
0xddffd6a4: 0xdd67556c
0xddffd6a0: 0xddffdb83
0xddffd69c: 0xdd62cb11
0xddffd698: 0xddffdae8
0xddffd694: 0xdd67bed8
0xddffd690: 0xddffdb7a
0xddffd68c: 0xdd67bed8
0xddffd688: 0xddffd6a8
0xddffd684: 0xdd67556c
0xddffd680: 0xddffdb83
0xddffd67c: 0xdd5c17ad
0xddffd678: 0xddffd698
0xddffd674: 0xddffdb80
0xddffd670: 0xdd67bed8
0xddffd66c: 0xdd5cb9e2
0xddffd668: 0x00000000
0xddffd664: 0xdd67cf80
0xddffd660-0xddffd654: 0x00000000
0xddffd650: 0x00000001
0xddffd64c: 0x0000000a
0xddffd648: 0x00001fff
0xddffd644: 0xddffdb70
0xddffd640: 0xd5000ec8
0xddffd63c: 0xdd5c3af3
0xddffd638: 0xddffd668
0xddffd634: 0xd5000ec8
0xddffd630: 0xddffdb7a
0xddffd62c: 0xffffffff
0xddffd628: 0xddffdb70
0xddffd624: 0xdd55902e
0xddffd620-0xddffd618: 0x00000000
0xddffd614: 0xdd000000
0xddffd610: 0xddffdb70
0xddffd60c: 0x00000000
0xddffd608: 0x000000a9
0xddffd604-0xddffd5f4: 0x00000000
0xddffd5f0: 0xddffdb86
0xddffd5ec-0xddffd5dc: 0xddffdb83
0xddffd5d8-0xddffd5d4: 0xddffdb86
0xddffd5d0: 0xfbad8001
0xddffd5cc: 0xdd67bed8
0xddffd5c8-0xddffd5bc: 0x00000000
0xddffd5b8: 0xddffd6a8
0xddffd5b4: 0xdd67556c
0xddffd5b0: 0xddffd5d0
0xddffd5ac: 0xdd5c4bf5
0xddffd5a8: 0xddffd678
0xddffd5a4: 0x00000009
0xddffd5a0: 0xddffd5d0
0xddffd59c: 0xdd67bed8
0xddffd598: 0xddffdb86
0xddffd594: 0xd5000ec8
0xddffd590: 0xdd67bed8
0xddffd58c-0xddffd588: 0x00000000
0xddffd584: 0xddffd5d0
0xddffd580: 0xdd7a666c
0xddffd57c: 0xdd5cefef
0xddffd578: 0xddffd5a8
0xddffd574: 0xddffd5d0
0xddffd570-0xddffd56c: 0xdd67bed8
0xddffd568-0xddffd560: 0x00000000
0xddffd55c: 0xdd5ce139
0xddffd558: 0x00b40012
0xddffd554: 0x2a4f6102
0xddffd550: 0x51ef5030
0xddffd54c-0xddffd548: 0x00000000
0xddffd544: 0x2a4f6102
0xddffd540: 0x51ef5030
0xddffd53c-0xddffd538: 0x00000000
0xddffd534: 0x00000400
0xddffd530-0xddffd52c: 0x00000000
0xddffd528: 0xddffd081
0xddffd524-0xddffd520: 0x
Output truncated
Process virtual address map:
08048000-097e0000 r-xp 00000000 00:01 163        /asa/bin/lina
097e0000-09c61000 rwxp 01798000 00:01 163        /asa/bin/lina
09c61000-09ffb000 rwxp 09c61000 00:00 0          [heap]
d26e8000-d27eb000 rwxp d26e8000 00:00 0
d27eb000-d27ef000 rwxs 00000000 00:07 410        /dev/zero (deleted)
d27ef000-d28f2000 rwxp d27ef000 00:00 0
d28f2000-d28f6000 rwxs e0004000 00:01 106        /dev/mem
d28f6000-d29f8000 rwxp d28f6000 00:00 0
d29f8000-d2c00000 rw-p d29f8000 00:00 0
d2c00000-d4c00000 rw-p d2c00000 00:00 0
d4c00000-d4fb8000 rw-p d4c00000 00:00 0
d5000000-d7000000 rwxs 00000000 00:0b 0          /1 (deleted)
d7000000-d7400000 r-xs 02000000 00:0b 0          /1 (deleted)
d7400000-d7800000 rwxs 02400000 00:0b 0          /1 (deleted)
d7800000-d7c00000 r-xs 02800000 00:0b 0          /1 (deleted)
d7c00000-dd400000 rwxs 02c00000 00:0b 0          /1 (deleted)
dd43f000-dd541000 rwxp dd43f000 00:00 0
dd541000-dd542000 rwxs ffb00000 00:01 106        /dev/mem
dd542000-dd552000 rwxs fff00000 00:01 106        /dev/mem
dd552000-dd55a000 rwxs 000d8000 00:01 106        /dev/mem
dd55a000-dd55b000 rwxp dd55a000 00:00 0
dd55b000-dd565000 r-xp 00000000 00:01 149        /lib/libgcc_s.so.1
dd565000-dd566000 rwxp 00009000 00:01 149        /lib/libgcc_s.so.1
dd566000-dd67a000 r-xp 00000000 00:01 141        /lib/libc.so.6
dd67a000-dd67e000 rwxp 00114000 00:01 141        /lib/libc.so.6
dd67e000-dd681000 rwxp dd67e000 00:00 0
dd681000-dd69e000 r-xp 00000000 00:01 151        /lib/libexpat.so.1
dd69e000-dd6a0000 rwxp 0001d000 00:01 151        /lib/libexpat.so.1
dd6a0000-dd6a1000 rwxp dd6a0000 00:00 0
dd6a1000-dd771000 r-xp 00000000 00:01 147        /lib/libstdc++.so.6
dd771000-dd776000 rwxp 000d0000 00:01 147        /lib/libstdc++.so.6
dd776000-dd77b000 rwxp dd776000 00:00 0
dd77b000-dd79a000 r-xp 00000000 00:01 148        /lib/libm.so.6
dd79a000-dd79b000 rwxp 0001e000 00:01 148        /lib/libm.so.6
dd79b000-dd79d000 r-xp 00000000 00:01 150        /lib/libdl.so.2
dd79d000-dd79e000 rwxp 00001000 00:01 150        /lib/libdl.so.2
dd79e000-dd7aa000 r-xp 00000000 00:01 139        /lib/libpthread.so.0
dd7aa000-dd7ab000 rwxp 0000c000 00:01 139        /lib/libpthread.so.0
dd7ab000-dd7ee000 rwxp dd7ab000 00:00 0
dd7ee000-dd800000 r-xp 00000000 00:01 142        /lib/ld-linux.so.2
dd800000-dd801000 rwxp 00011000 00:01 142        /lib/ld-linux.so.2
ddfea000-de000000 rwxp ddfea000 00:00 0          [stack]
ffffe000-fffff000 ---p 00000000 00:00 0          [vdso]
Globl mempool: least_addr=0xd5000000 top=0xda83d980 dv=0xda7ad108 mflags=0x7
DMA   mempool: least_addr=0xd29f8000 top=0xd493ba98 dv=0xd493b268 mflags=0x7
Current Block:
Block     : 0xd50dde10
B-base    : 0xd50de0a4
B-size    : 0x98
B-rptr    : 0xd50de138
B-hptr    : 0xd50de138
B-allocd  : 0x8e7719b
B-freed   : 0x0
B-location: 0x77
B-meta    : 0x0
B-flags2  : 0x0
B-input   :
B-output  :
Region #0 [0xd50ddeb0] ext-dump 0 of (Block) from Current Block extra dump
d50dde90: 00 00 00 00 00 00 00 00 a8 00 08 01 30 df 0d d5  |  ............0...
d50ddea0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d50ddeb0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d50ddec0: 77 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  w...............
d50dded0: 00 89 00 89 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d50ddee0: 00 00 00 00 00 00 00 00 00 00 00 00 38 e1 0d d5  |  ............8...
d50ddef0: 00 00 00 00 28 ef 80 da 00 00 00 00 00 00 00 00  |  ....(...........
d50ddf00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d50ddf10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d50ddf20: 00 00 00 00 8c 73 0a 00 00 00 00 00 00 00 00 00  |  .....s..........
Region #1 [0xd50de138] ext-dump 1 of (Block) from Current Block extra dump
d50de118: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d50de128: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d50de138: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d50de148: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d50de158: 00 00 00 00 00 00 00 00 dd dd dd dd dd dd dd dd  |  ................
d50de168: dd dd dd dd dd dd dd ef cd 1c a1 00 00 00 00 00  |  ................
d50de178: d0 d4 00 fc c3 10 00 00 23 01 1c a1 90 10 00 00  |  ........#.......
d50de188: 00 00 00 00 00 00 00 00 28 b8 1a d5 f2 f8 24 09  |  ........(.....$.
d50de198: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d50de1a8: 00 00 00 00 00 00 00 00 00 00 00 00 9d c9 a3 15  |  ................
Region #2 [0xd50de1d8] ext-dump 2 of (Block) from Current Block extra dump
d50de1b8: 00 04 00 00 00 04 00 00 60 03 00 00 70 03 00 00  |  ........`...p...
d50de1c8: fa 03 00 00 06 00 00 00 06 00 00 00 fa 03 00 00  |  ................
d50de1d8: 10 00 00 00 10 00 20 00 45 02 00 00 ee 00 00 00  |  ...... .E.......
d50de1e8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d50de1f8: 4c 6f 63 61 6c 20 62 6c 6f 63 6b 00 00 00 00 00  |  Local block.....
d50de208: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d50de218: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d50de228: 50 21 00 d5 60 e1 0d d5 60 21 00 d5 d0 24 00 d5  |  P!..`...`!...$..
d50de238: 40 28 00 d5 b0 2b 00 d5 20 2f 00 d5 90 32 00 d5  |  @(...+.. /...2..
d50de248: 00 36 00 d5 70 39 00 d5 e0 3c 00 d5 50 40 00 d5  |  .6..p9...<..P@..
Current Connection:
Conn      : 0xd62154e0
C-flow    : 0xd6215528 0xd62155f4
C-flowcnt : 2
C-flags   : 0x0
C-par_conn: 0x0
C-chd_conn: 0x0
C-sib_conn: 0x0
C-inspect : 0xd6225ca0
C-inspect2: 0x0
C-ids     : 0x0
C-grp_lock: 0xd62154f0
C-conn_lck_own: 0x0
C-conn_lck_cnt: 0x0
C-work_que: 0xffffffff
C-pur_call: 0x0
C-pur_calb: 0x0
C-tim_call:0x86e3040
C-tim_calq:0xd6195fa8
Flow      : C-FLOW_SRC 0xd6215528
F-SrcIP  : 0x3701a8c0
F-DstIP  : 0x55b107c7
F-SrcPort: 0x5206
F-DstPort: 0x5000
F-ESrcIP : 0x83c13d5c
F-EDstIP : 0x55b107c7
F-ESrcPrt: 0xdb4b
F-EDstPrt: 0x5000
F-flags  : 0x1002000
F-flags2 : 0x18032
F-flags3 : 0x8008
F-bytes  : 984
F-disp-refcnt   : 61
F-host    : 0xd621f9d0
H-addr    : 0x3701a8c0
H-refcnt  : 193
H-tcpmss  : 1380
Flow      : C-FLOW_DEST 0xd62155f4
F-SrcIP  : 0x55b107c7
F-DstIP  : 0x83c13d5c
F-SrcPort: 0x5000
F-DstPort: 0xdb4b
F-ESrcIP : 0x55b107c7
F-EDstIP : 0x3701a8c0
F-ESrcPrt: 0x5000
F-EDstPrt: 0x5206
F-flags  : 0x2
F-flags2 : 0x18030
F-flags3 : 0x28008
F-bytes  : 22282542
F-disp-refcnt   : 60
F-host    : 0xd621fd90
H-addr    : 0x55b107c7
H-refcnt  : 1
H-tcpmss  : 1380
TCB       : C-TCB_SRC 0xd692f980
T-state   : 0x4
T-flasg   : 0x41401c0c
T-refcnt  : 0x0
T-cltqcnt : 0
T-cltqhead: 0x0
T-srvqcnt : 0
T-srvqhead: 0
Region #3 [0xd6215528] ext-dump 0 of (Conn) from Current Conn extra dump
d6215508: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d6215518: 80 f9 92 d6 00 00 00 00 00 00 00 00 02 35 5f 35  |  .............5_5
d6215528: 01 00 00 00 fe 57 b6 fa e0 54 21 d6 20 38 1f d6  |  .....W...T!. 8..
d6215538: 28 e6 f8 d7 d0 ce 18 d8 01 00 00 00 01 00 00 00  |  (...............
d6215548: 70 41 cf d8 1d 00 00 00 55 4f 85 10 96 22 53 e8  |  pA......UO..."S.
d6215558: 5b e1 a1 6a 32 80 01 00 08 80 00 00 d8 03 00 00  |  [..j2...........
d6215568: 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00  |  ................
d6215578: 00 00 00 00 d0 f9 21 d6 50 56 21 d6 06 52 00 50  |  ......!.PV!..R.P
d6215588: 06 00 00 00 00 00 00 00 c0 a8 01 37 00 00 00 00  |  ...........7....
d6215598: 00 00 00 00 00 00 00 00 00 00 00 00 c7 07 b1 55  |  ...............U
Region #4 [0xd62155c8] ext-dump 1 of (Conn) from Current Conn extra dump
d62155a8: 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 00  |  ................
d62155b8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d62155c8: 00 20 00 01 00 00 00 00 d0 f0 7a da 00 00 00 00  |  . ........z.....
d62155d8: 00 00 00 00 00 00 00 00 00 00 00 00 f4 55 21 d6  |  .............U!.
d62155e8: 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00  |  ................
d62155f8: cb 61 c6 5a e0 54 21 d6 20 37 1f d6 d0 ce 18 d8  |  .a.Z.T!. 7......
d6215608: 28 e6 f8 d7 01 00 00 00 01 00 00 00 f0 17 7a d5  |  (.............z.
d6215618: 1d 00 00 00 6a dd ac 17 ab b0 7a ef a4 1e 5e 95  |  ....j.....z...^.
d6215628: 30 80 01 00 08 80 02 00 2e 01 54 01 00 00 00 00  |  0.........T.....
d6215638: 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00  |  ................
Region #5 [0xda7af0d0] ext-dump 2 of (Conn) from Current Conn extra dump
da7af0b0: 23 01 1c a1 04 01 00 00 00 00 00 00 e0 4e 2a d5  |  #............N*.
da7af0c0: 08 fb 7a da 40 69 72 08 00 00 00 00 2f 89 21 09  |  ..z.@ir...../.!.
da7af0d0: ef be ad de 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
da7af0e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
da7af0f0: 00 00 00 00 ff ff ff ff 04 01 00 00 d0 f0 7a da  |  ..............z.
da7af100: 00 41 00 00 01 00 00 00 06 52 4b db 00 00 00 00  |  .A.......RK.....
da7af110: ff ff ff ff 5c 3d c1 83 00 00 00 00 00 00 00 00  |  ....\=..........
da7af120: 28 e6 f8 d7 00 00 00 00 c0 a8 01 37 00 00 00 00  |  (..........7....
da7af130: 00 00 00 00 00 00 00 00 d0 ce 18 d8 00 00 00 00  |  ................
da7af140: 5c 3d c1 83 00 00 00 00 00 00 00 00 00 00 00 00  |  \=..............
Region #6 [0xd61f3820] ext-dump 3 of (Conn) from Current Conn extra dump
d61f3800: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d61f3810: 00 00 00 00 00 00 00 00 00 00 00 00 90 eb fc d5  |  ................
d61f3820: 01 00 00 00 62 c3 18 e0 3d 00 00 00 07 00 00 00  |  ....b...=.......
d61f3830: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d61f3840: 00 00 00 00 00 00 00 00 00 00 00 00 40 20 29 d5  |  ............@ ).
d61f3850: 00 00 00 00 00 1f 29 d5 00 00 00 00 a0 1f 29 d5  |  ......).......).
d61f3860: 00 00 00 00 e0 21 29 d5 00 00 00 00 60 20 29 d5  |  .....!).....` ).
d61f3870: 00 00 00 00 20 20 29 d5 00 00 00 00 c0 13 29 d5  |  ....  ).......).
d61f3880: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d61f3890: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #7 [0xd62155f4] ext-dump 4 of (Conn) from Current Conn extra dump
d62155d4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d62155e4: f4 55 21 d6 00 00 00 00 00 00 00 00 00 00 00 00  |  .U!.............
d62155f4: 01 00 00 00 cb 61 c6 5a e0 54 21 d6 20 37 1f d6  |  .....a.Z.T!. 7..
d6215604: d0 ce 18 d8 28 e6 f8 d7 01 00 00 00 01 00 00 00  |  ....(...........
d6215614: f0 17 7a d5 1d 00 00 00 6a dd ac 17 ab b0 7a ef  |  ..z.....j.....z.
d6215624: a4 1e 5e 95 30 80 01 00 08 80 02 00 2e 01 54 01  |  ..^.0.........T.
d6215634: 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00  |  ................
d6215644: 00 00 00 00 90 fd 21 d6 84 55 21 d6 00 50 4b db  |  ......!..U!..PK.
d6215654: 06 00 00 00 00 00 00 00 c7 07 b1 55 00 00 00 00  |  ...........U....
d6215664: 00 00 00 00 00 00 00 00 00 00 00 00 5c 3d c1 83  |  ............\=..
Region #8 [0xd6215694] ext-dump 5 of (Conn) from Current Conn extra dump
d6215674: 00 00 00 00 00 00 00 00 c0 a8 01 37 03 00 00 00  |  ...........7....
d6215684: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d6215694: 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d62156a4: 00 00 00 00 00 00 00 00 00 00 00 00 28 55 21 d6  |  ............(U!.
d62156b4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00  |  ................
d62156c4: 00 00 00 00 00 00 00 00 cc 2a 21 d6 8c 43 21 d6  |  .........*!..C!.
d62156d4: fc fd 21 d6 fc fd 21 d6 56 0d 00 00 00 00 00 00  |  ..!...!.V.......
d62156e4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d62156f4: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d6215704: a0 5c 22 d6 00 00 00 00 00 00 00 00 40 30 6e 08  |  .\".........@0n.
Region #9 [0xd61f3720] ext-dump 6 of (Conn) from Current Conn extra dump
d61f3700: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d61f3710: 00 00 00 00 00 00 00 00 00 00 00 00 90 eb fc d5  |  ................
d61f3720: 01 00 00 00 19 eb 59 c3 3c 00 00 00 07 00 00 00  |  ......Y.<.......
d61f3730: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d61f3740: 00 00 00 00 00 00 00 00 00 00 00 00 40 20 29 d5  |  ............@ ).
d61f3750: 00 00 00 00 e0 21 29 d5 00 00 00 00 00 1f 29 d5  |  .....!).......).
d61f3760: 00 00 00 00 a0 1f 29 d5 00 00 00 00 60 20 29 d5  |  ......).....` ).
d61f3770: 00 00 00 00 20 20 29 d5 00 00 00 00 20 15 29 d5  |  ....  )..... .).
d61f3780: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d61f3790: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #10 [0xd6225ca0] ext-dump 7 of (Conn) from Current Conn extra dump
d6225c80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d6225c90: 09 00 00 00 e0 8e b7 d8 00 00 00 00 68 b5 78 d5  |  ............h.x.
d6225ca0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d6225cb0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d6225cc0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d6225cd0: 00 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00  |  ................
d6225ce0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d6225cf0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d6225d00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d6225d10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #11 [0xd62154f0] ext-dump 8 of (Conn) from Current Conn extra dump
d62154d0: a0 b8 21 d6 00 00 00 00 00 00 00 00 28 ac 78 d5  |  ..!.........(.x.
d62154e0: c0 8f 2c 09 ad 00 00 00 c1 10 a1 c0 f0 54 21 d6  |  ..,..........T!.
d62154f0: 00 00 00 00 00 00 00 00 00 00 00 00 ff ff ff ff  |  ................
d6215500: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d6215510: 00 00 00 00 00 00 00 00 80 f9 92 d6 00 00 00 00  |  ................
d6215520: 00 00 00 00 02 35 5f 35 01 00 00 00 fe 57 b6 fa  |  .....5_5.....W..
d6215530: e0 54 21 d6 20 38 1f d6 28 e6 f8 d7 d0 ce 18 d8  |  .T!. 8..(.......
d6215540: 01 00 00 00 01 00 00 00 70 41 cf d8 1d 00 00 00  |  ........pA......
d6215550: 55 4f 85 10 96 22 53 e8 5b e1 a1 6a 32 80 01 00  |  UO..."S.[..j2...
d6215560: 08 80 00 00 d8 03 00 00 00 00 00 00 00 00 00 00  |  ................
TSD dump (core0 tp=9d4f120):
core0: dp_executing_cp=1 tid=0xd519d5b0 latest purge=0x0 calq=0xd8b45e78
       async_cnt=0 purgatory=0x0 async_lock=0x0 dor_spinlock=0x0
Dumping latest_calq_entry 0xd8b45e78
d8b45e38: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d8b45e48: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d8b45e58: 00 00 00 00 00 00 00 00 e0 56 78 da 40 56 78 da  |  .........Vx.@Vx.
d8b45e68: c0 74 b4 d8 30 18 79 08 00 00 00 00 38 1f 18 d6  |  .t..0.y.....8...
d8b45e78: 08 56 18 d6 9c 41 82 da 00 56 18 d6 00 00 00 00  |  .V...A...V......
d8b45e88: 50 23 0f 01 01 00 00 00 00 00 00 00 01 00 00 00  |  P#..............
d8b45e98: 4f e7 57 86 03 00 00 00 80 85 a1 7a 09 00 00 00  |  O.W........z....
d8b45ea8: 00 00 00 00 f0 66 b4 d8 03 00 0b 01 00 00 00 00  |  .....f..........
Selective memory dump: DT(Data, default) TX(Text) UD(Uninit-Data)
                       BA(Bad) ID(Init-Data) UK(Unknown)
Region #0 [UK:0xd27eef30] from tback F0
d27eef10: 05 00 01 00 06 00 00 00 00 00 00 00 b0 d5 19 d5  |  ................
d27eef20: d0 1f e3 09 34 ef 7e d2 5f 1f a2 08 00 00 00 00  |  ....4.~._.......
d27eef30: b0 d5 19 d5 54 ef 7e d2 b3 d9 28 09 6c 06 7d 09  |  ....T.~...(.l.}.
d27eef40: bd b8 31 09 c0 58 59 09 e7 02 00 00 b0 d5 19 d5  |  ..1..XY.........
d27eef50: d0 1f e3 09 a4 ef 7e d2 ff 2b 06 08 bd b8 31 09  |  ......~..+....1.
d27eef60: c0 58 59 09 e7 02 00 00 00 00 00 00 00 00 00 00  |  .XY.............
d27eef70: 22 99 02 00 00 00 00 00 00 00 00 00 22 99 02 00  |  "..........."...
d27eef80: 00 00 00 00 00 00 00 00 00 00 00 00 b0 5e 8f 02  |  .............^..
d27eef90: b0 5e 8f 02 dc e4 30 2f 56 00 00 00 00 00 00 00  |  .^....0/V.......
d27eefa0: b0 d5 19 d5 f4 ef 7e d2 36 2f 06 08 e0 ef 7e d2  |  ......~.6/....~.
Region #1 [0xd519d5b0] from #0 tback F0 dump off 0x0
d519d590: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d519d5a0: 00 00 00 00 00 00 00 00 30 f5 58 d8 b8 d3 19 d5  |  ........0.X.....
d519d5b0: 00 00 00 00 88 1c e3 09 56 34 12 ff b8 d3 19 d5  |  ........V4......
d519d5c0: 88 1c e3 09 1e d2 64 09 36 55 47 08 64 57 24 d8  |  ......d.6UG.dW$.
d519d5d0: b0 57 24 d8 88 1c e3 09 b0 d5 19 d5 72 00 00 00  |  .W$.........r...
d519d5e0: f0 45 24 d8 00 20 00 00 91 12 36 2f 56 00 00 00  |  .E$.. ....6/V...
d519d5f0: e3 08 00 38 03 00 00 00 ed 51 aa 01 00 00 00 00  |  ...8.....Q......
d519d600: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d519d610: 04 00 00 00 01 00 00 00 ef 79 01 00 72 78 01 00  |  .........y..rx..
d519d620: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #2 [0xd51806e8] from #1 (malloc_header) magic off 0
d51806c8: dd dd dd dd dd dd dd dd dd dd dd dd dd dd dd dd  |  ................
d51806d8: ef cd 1c a1 00 00 00 00 d0 d4 00 fc 43 b1 02 00  |  ............C...
d51806e8: 23 01 1c a1 10 b1 02 00 00 00 00 00 00 00 00 00  |  #...............
d51806f8: a8 0a 1b d5 02 18 06 08 00 00 00 00 00 00 00 00  |  ................
d5180708: 38 b0 1a d5 00 09 18 d5 56 34 12 ff 00 00 00 00  |  8.......V4......
d5180718: d4 71 cc 09 00 00 00 00 00 00 00 00 00 00 00 00  |  .q..............
d5180728: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d5180738: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d5180748: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d5180758: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
malloc_header:0d51806e8
M-size    : 0x2b110
M-allocd  : 0x8061802
Region #3 [UK:0xd27eef54] from #0 tback F0 dump off 0x4
d27eef34: 54 ef 7e d2 b3 d9 28 09 6c 06 7d 09 bd b8 31 09  |  T.~...(.l.}...1.
d27eef44: c0 58 59 09 e7 02 00 00 b0 d5 19 d5 d0 1f e3 09  |  .XY.............
d27eef54: a4 ef 7e d2 ff 2b 06 08 bd b8 31 09 c0 58 59 09  |  ..~..+....1..XY.
d27eef64: e7 02 00 00 00 00 00 00 00 00 00 00 22 99 02 00  |  ............"...
d27eef74: 00 00 00 00 00 00 00 00 22 99 02 00 00 00 00 00  |  ........".......
d27eef84: 00 00 00 00 00 00 00 00 b0 5e 8f 02 b0 5e 8f 02  |  .........^...^..
d27eef94: dc e4 30 2f 56 00 00 00 00 00 00 00 b0 d5 19 d5  |  ..0/V...........
d27eefa4: f4 ef 7e d2 36 2f 06 08 e0 ef 7e d2 01 00 00 00  |  ..~.6/....~.....
d27eefb4: 00 00 00 00 94 a1 7a dd 00 00 00 00 30 b2 1a d5  |  ......z.....0...
d27eefc4: d0 1f e3 09 b0 d5 19 d5 d0 1f e3 09 00 00 00 00  |  ................
Region #4 [TX:0x0928d9b0] from #0 tback F0 dump off 0x8
0928d990: c7 04 24 6c 06 7d 09 89 44 24 0c 8b 45 0c 89 44  |  ..$l.}..D$..E..D
0928d9a0: 24 08 8b 45 08 89 44 24 04 e8 b2 6e dd fe e8 8d  |  $..E..D$...n....
0928d9b0: 45 79 ff 8d b6 00 00 00 00 8d bc 27 00 00 00 00  |  Ey.........'....
0928d9c0: 55 a1 50 bd c5 09 89 e5 53 3b 45 10 8b 5d 14 8b  |  U.P.....S;E..]..
0928d9d0: 55 1c 8b 4d 20 77 09 5b 5d c3 8d b6 00 00 00 00  |  U..M w.[].......
0928d9e0: 89 55 10 89 5d 0c 89 4d 08 5b 5d e9 70 ff ff ff  |  .U..]..M.[].p...
0928d9f0: 55 b8 c0 d4 01 00 89 e5 83 ec 08 89 44 24 04 c7  |  U...........D$..
0928da00: 04 24 00 00 00 00 e8 d5 6b dd fe e8 c0 01 01 00  |  .$......k.......
0928da10: e8 3b 47 79 ff eb fe 90 90 90 90 90 90 90 90 90  |  .;Gy............
0928da20: 55 ba 1f 85 eb 51 89 e5 53 8b 1d 40 d8 e2 09 43  |  U....Q..S..@...C
Region #5 [TX:0x0927fcfc] from #4 (malloc_header) magic off 0
0927fcdc: 5d 08 89 75 f8 89 7d fc 85 db 74 70 e8 e3 00 00  |  ]..u..}...tp....
0927fcec: 00 29 c3 89 d8 8d 5b e0 8b 53 04 01 da 81 78 e0  |  .)....[..S....x.
0927fcfc: 23 01 1c a1 74 63 8d 73 f8 31 ff e8 b4 b3 dd fe  |  #...tc.s.1......
0927fd0c: f6 46 04 01 74 6f c7 04 24 9c dc 7c 09 e8 42 4b  |  .F..to..$..|..BK
0927fd1c: de fe b9 d4 dc 7c 09 81 3b 23 01 1c a1 74 76 89  |  .....|..;#...tv.
0927fd2c: fa 89 f0 e8 ac 94 ff ff bb aa 16 00 00 b9 40 ce  |  ..............@.
0927fd3c: 7c 09 89 5c 24 08 89 4c 24 04 c7 04 24 30 13 34  |  |..\$..L$...$0.4
0927fd4c: 09 e8 0e dc 00 00 8b 46 04 83 e0 fc 8b 5d f4 8b  |  .......F.....]..
0927fd5c: 75 f8 8b 7d fc 89 ec 5d c3 81 7a 20 ef cd 1c a1  |  u..}...]..z ....
0927fd6c: 8d 70 d8 74 e1 8d 73 f8 31 ff e8 45 b3 dd fe f6  |  .p.t..s.1..E....
malloc_header:0927fcfc
M-size    : 0x738d6374
M-allocd  : 0x4c76f74
**WARNING: invalid mh->mh_fd_link 0xfeddb3b4
**WARNING: invalid mh->mh_bk_link 0x10446f6
**WARNING: invalid mh_tail_offset(mh) 0x7cb56090
**WARNING: ptr 0x928d9b0 not within fm->least_addr 0xd5000000 and fm->top 0xda83d980
Region #6 [UD:0x097d066c] from #0 tback F0 dump off 0xc
097d064c: 69 63 61 6c 20 73 75 70 70 6f 72 74 20 72 65 70  |  ical support rep
097d065c: 72 65 73 65 6e 74 61 74 69 76 65 2e 0a 0a 00 00  |  resentative.....
097d066c: 61 73 73 65 72 74 69 6f 6e 20 22 25 73 22 20 66  |  assertion "%s" f
097d067c: 61 69 6c 65 64 3a 20 66 69 6c 65 20 22 25 73 22  |  ailed: file "%s"
097d068c: 2c 20 6c 69 6e 65 20 25 64 0a 00 55 6e 6c 69 6d  |  , line %d..Unlim
097d069c: 69 74 65 64 00 20 20 20 20 20 20 63 75 72 72 65  |  ited.      curre
097d06ac: 6e 74 20 73 74 61 74 65 2e 0a 00 4d 61 78 69 6d  |  nt state...Maxim
097d06bc: 75 6d 20 50 68 79 73 69 63 61 6c 20 49 6e 74 65  |  um Physical Inte
097d06cc: 72 66 61 63 65 73 00 4d 61 78 69 6d 75 6d 20 56  |  rfaces.Maximum V
097d06dc: 4c 41 4e 73 00 56 50 4e 2d 44 45 53 00 56 50 4e  |  LANs.VPN-DES.VPN
Region #7 [UD:0x0931b8bc] from #0 tback F0 dump off 0x10
0931b89c: 6d 65 72 20 74 79 70 65 0a 00 74 69 6d 65 6f 75  |  mer type..timeou
0931b8ac: 74 20 74 61 62 6c 65 20 66 75 6c 6c 00 63 75 72  |  t table full.cur
0931b8bc: 5f 74 2d 3e 73 74 61 63 6b 5b 30 5d 20 3d 3d 20  |  _t->stack[0] ==
0931b8cc: 53 54 4b 49 4e 49 54 00 25 30 38 78 3a 20 00 50  |  STKINIT.%08x: .P
0931b8dc: 61 6e 69 63 3a 20 25 73 20 2d 20 00 69 6e 62 75  |  anic: %s - .inbu
0931b8ec: 66 6c 65 6e 20 3e 3d 20 44 55 4d 50 5f 42 55 46  |  flen >= DUMP_BUF
0931b8fc: 46 45 52 5f 4c 45 4e 00 43 68 61 6e 6e 65 6c 20  |  FER_LEN.Channel
0931b90c: 63 68 75 6e 6b 00 63 68 61 6e 6e 65 6c 20 69 6e  |  chunk.channel in
0931b91c: 69 74 2e 20 66 61 69 6c 65 64 0a 00 63 68 2d 3e  |  it. failed..ch->
0931b92c: 72 65 66 63 6f 75 6e 74 20 3e 3d 20 30 00 52 65  |  refcount >= 0.Re
Region #8 [UD:0x095958c0] from #0 tback F0 dump off 0x14
095958a0: 00 70 74 68 72 65 61 64 5f 61 74 74 72 5f 73 65  |  .pthread_attr_se
095958b0: 74 73 74 61 63 6b 61 64 64 72 00 6c 69 6e 61 5f  |  tstackaddr.lina_
095958c0: 74 68 72 65 61 64 2e 63 00 45 52 52 4f 52 3a 20  |  thread.c.ERROR:
095958d0: 73 65 74 70 72 69 6f 72 69 74 79 20 66 61 69 6c  |  setpriority fail
095958e0: 75 72 65 00 46 61 69 6c 65 64 20 72 65 6e 69 63  |  ure.Failed renic
095958f0: 65 20 74 6f 20 70 72 69 6f 72 69 74 79 20 25 64  |  e to priority %d
09595900: 0a 00 6c 69 6e 61 5f 70 74 68 72 65 61 64 5f 65  |  ..lina_pthread_e
09595910: 6e 74 72 79 20 69 6e 69 74 5f 6c 6f 63 6b 00 44  |  ntry init_lock.D
09595920: 41 54 41 50 41 54 48 2d 25 64 2d 25 64 00 50 54  |  ATAPATH-%d-%d.PT
09595930: 48 52 45 41 44 2d 25 64 00 73 79 73 5f 73 63 68  |  HREAD-%d.sys_sch
Region #10 [0xd519d5b0] from #0 tback F0 dump off 0x1c
Region #11 [0xd51806e8] from #10 (malloc_header) magic off 0
M-size    : 0x2b110
Region #12 [UK:0xd27ee998] from tback F1
d27ee978: 98 e9 7e d2 bd d1 05 08 91 12 36 2f 56 00 00 00  |  ..~.......6/V...
d27ee988: 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d27ee998: 38 eb 7e d2 7c 3d a2 08 c0 f4 d4 09 01 00 00 00  |  8.~.|=..........
d27ee9a8: 00 00 00 00 ff ff ff ff ff ff ff ff ff ff ff ff  |  ................
d27ee9b8: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff  |  ................
d27ee9c8: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff  |  ................
d27ee9d8: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff  |  ................
d27ee9e8: ff ff ff ff ff ff ff ff 94 ee 50 06 55 00 00 00  |  ..........P.U...
d27ee9f8: 28 ea 7e d2 00 00 00 00 01 00 00 00 90 46 06 08  |  (.~..........F..
d27eea08: 28 ea 7e d2 b9 15 a2 08 02 00 00 00 e0 fb d4 09  |  (.~.............
Region #13 [UK:0xd27eeb38] from #12 tback F1 dump off 0x0
d27eeb18: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d27eeb28: 47 ec 61 dd 94 a1 7a dd 00 00 00 00 10 ef 7e d2  |  G.a...z.......~.
d27eeb38: 58 eb 7e d2 d5 86 7a dd 06 00 00 00 6c eb 7e d2  |  X.~...z.....l.~.
d27eeb48: ec eb 7e d2 d5 86 7a dd 09 00 00 00 00 00 00 00  |  ..~...z.........
d27eeb58: 24 ef 7e d2 e0 d1 58 dd 06 00 00 00 6c eb 7e d2  |  $.~...X.....l.~.
d27eeb68: ec eb 7e d2 06 00 00 00 00 00 00 00 00 00 00 00  |  ..~.............
d27eeb78: b8 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00  |  ................
d27eeb88: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d27eeb98: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d27eeba8: 00 00 00 00 00 00 00 00 00 00 00 00 d0 1f e3 09  |  ................
Region #14 [TX:0x08a23d7c] from #12 tback F1 dump off 0x4
08a23d5c: f4 d4 09 8b 42 68 c7 04 24 c0 f4 d4 09 a3 40 1f  |  ....Bh..$.....@.
08a23d6c: f4 09 b8 01 00 00 00 89 44 24 04 e8 c4 9b 63 ff  |  ........D$....c.
08a23d7c: 81 c4 8c 01 00 00 5b 5e 5f 5d c3 8b 4d 10 8b 41  |  ......[^_]..M..A
08a23d8c: 44 89 45 8c 8b 41 24 89 45 90 8b 41 28 89 45 94  |  D.E..A$.E..A(.E.
08a23d9c: 8b 41 2c 89 45 98 8b 41 30 89 45 9c 8b 41 34 89  |  .A,.E..A0.E..A4.
08a23dac: 45 a0 8b 41 38 89 45 a4 8b 41 3c 89 45 a8 8b 41  |  E..A8.E..A<.E..A
08a23dbc: 40 89 45 ac 8b 41 4c 89 45 b4 8b 41 50 89 45 b8  |  @.E..AL.E..AP.E.
08a23dcc: 8b 41 54 89 45 bc 8b 41 48 89 45 b0 8d 45 8c 89  |  .AT.E..AH.E..E..
08a23ddc: 04 24 e8 5d 72 63 ff 8b 0d a8 69 f4 09 a1 50 e7  |  .$.]rc....i...P.
08a23dec: d4 09 49 85 c0 89 0d a8 69 f4 09 0f 84 53 04 00  |  ..I.....i....S..
Region #15 [ID:0x09d4f4c0] from #12 tback F1 dump off 0x8
09d4f4a0: cd 3f d1 0e 00 00 00 00 00 00 00 00 00 00 00 00  |  .?..............
09d4f4b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09d4f4c0: 20 00 00 00 d0 1f e3 09 b0 d5 19 d5 98 e9 7e d2  |   .............~.
09d4f4d0: 30 ef 7e d2 60 1d e3 09 c0 58 59 09 e7 02 00 00  |  0.~.`....XY.....
09d4f4e0: 80 1d e3 09 00 00 00 00 6b d9 28 09 73 00 00 00  |  ........k.(.s...
09d4f4f0: 46 32 00 00 3d 01 44 09 b5 50 59 09 00 00 00 00  |  F2..=.D..PY.....
09d4f500: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09d4f510: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09d4f520: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09d4f530: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #24 [UK:0xd27eeb38] from tback F2
Region #25 [UK:0xd27eeb58] from #24 tback F2 dump off 0x0
d27eebb8: 30 b2 1a d5 a4 ef 7e d2 a4 ef 7e d2 00 00 00 00  |  0.....~...~.....
d27eebc8: 00 00 00 00 1c 39 0a 00 00 00 00 00 00 00 00 00  |  .....9..........
Region #26 [UK:0xdd7a86d4] from #24 tback F2 dump off 0x4
dd7a86b4: 65 89 2d 84 00 00 00 8b 45 10 89 44 24 08 8b 45  |  e.-.....E..D$..E
dd7a86c4: 0c 89 44 24 04 89 14 24 8b 83 8c ff ff ff ff 14  |  ..D$...$........
dd7a86d4: 90 85 f6 75 0b b8 00 00 00 00 65 a3 84 00 00 00  |  ...u......e.....
dd7a86e4: 8b 5d f8 8b 75 fc 89 ec 5d c3 55 89 e5 5d c3 90  |  .]..u...].U..]..
dd7a86f4: 55 89 e5 83 ec 08 89 5d fc e8 c2 99 ff ff 81 c3  |  U......]........
dd7a8704: 92 1a 00 00 e8 a3 96 ff ff 8b 5d fc 89 ec 5d c3  |  ..........]...].
dd7a8714: 55 89 e5 83 ec 08 89 5d fc e8 a2 99 ff ff 81 c3  |  U......]........
dd7a8724: 72 1a 00 00 e8 63 94 ff ff 8b 5d fc 89 ec 5d c3  |  r....c....]...].
dd7a8734: 55 89 e5 83 ec 08 89 5d fc e8 82 99 ff ff 81 c3  |  U......]........
dd7a8744: 52 1a 00 00 8b 45 08 89 04 24 e8 6d 96 ff ff 8b  |  R....E...$.m....
Region #28 [UK:0xd27eeb6c] from #24 tback F2 dump off 0xc
d27eeb4c: d5 86 7a dd 09 00 00 00 00 00 00 00 24 ef 7e d2  |  ..z.........$.~.
d27eeb5c: e0 d1 58 dd 06 00 00 00 6c eb 7e d2 ec eb 7e d2  |  ..X.....l.~...~.
d27eeb6c: 06 00 00 00 00 00 00 00 00 00 00 00 b8 00 00 00  |  ................
d27eeb7c: 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00  |  ................
d27eeb8c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d27eeb9c: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d27eebac: 00 00 00 00 00 00 00 00 d0 1f e3 09 30 b2 1a d5  |  ............0...
d27eebbc: a4 ef 7e d2 a4 ef 7e d2 00 00 00 00 00 00 00 00  |  ..~...~.........
d27eebcc: 1c 39 0a 00 00 00 00 00 00 00 00 00 7a ee 05 08  |  .9..........z...
d27eebdc: 73 00 00 00 46 32 00 00 00 00 00 00 ba 30 06 08  |  s...F2.......0..
Region #29 [UK:0xd27eebec] from #24 tback F2 dump off 0x10
d27eebec: 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00  |  ................
d27eebfc: 00 00 00 00 2f 00 00 00 33 00 00 00 7b 00 00 00  |  ..../...3...{...
d27eec0c: 7b 00 00 00 10 ef 7e d2 00 00 00 00 24 ef 7e d2  |  {.....~.....$.~.
d27eec1c: e0 ee 7e d2 09 00 00 00 08 00 00 00 10 ef 7e d2  |  ..~...........~.
d27eec2c: 08 00 00 00 00 00 00 00 00 00 00 00 ab 87 7a dd  |  ..............z.
d27eec3c: 73 00 00 00 46 32 00 00 e0 ee 7e d2 7b 00 00 00  |  s...F2....~.{...
d27eec4c: 60 ec 7e d2 05 5a 3b be 00 00 00 00 05 5a 3b be  |  `.~..Z;......Z;.
d27eec5c: be ff ff ff 7f 03 ff ff 61 70 ff ff ff ff ff ff  |  .......ap......
Region #30 [UK:0xd27ee10c] from #29 (malloc_header) magic off 0
d27ee0ec: 20 23 33 33 30 65 65 37 32 64 6f 63 5f 68 65 61  |   #160ee72doc_hea
d27ee0fc: 20 36 38 20 36 35 20 36 31 20 20 7c 20 20 20 23  |   68 65 61  |   #
d27ee10c: 7a e3 7e d2 3f 00 00 00 01 00 00 00 58 e1 7e d2  |  ..~.........X.~.
d27ee11c: 08 82 29 09 b8 e1 7e d2 01 00 00 00 27 00 00 00  |  ..)...~.........
d27ee12c: 00 00 30 33 0a 00 00 00 c8 e5 7e d2 58 e2 7e 00  |  ..03......~.X.~.
d27ee13c: c1 73 29 09 00 00 00 00 00 00 00 00 b4 e1 7e d2  |  .s)...........~.
d27ee14c: 4c 00 00 00 50 e1 7e d2 08 00 00 00 98 e1 7e d2  |  :...P.~.......~.
d27ee15c: 1d 8a 29 09 1d a2 7b 09 49 00 00 00 a5 e3 7e d2  |  ..)...{.Y.....~.
d27ee16c: 52 00 00 00 46 0c 59 09 00 00 00 00 b4 e1 7e d2  |  ....#7q.......~.
d27ee17c: 00 00 00 00 80 e1 7e d2 84 e1 7e d2 98 e1 7e d2  |  ......~...~...~.
malloc_header:0d27ee10c
M-size    : 0x2e2e2e7e
M-allocd  : 0xd27ee1b8
**WARNING: invalid mh->mh_fd_link 0xa2e7e
**WARNING: invalid mh->mh_bk_link 0x9298208
**WARNING: invalid mh_tail_offset(mh) 0xad0faa
**WARNING: ptr 0xd27eebec not within (mh + 1) 0xd27ee12c and (ulong)(mh + 1) + mh->mh_len 0xad0faa
**WARNING: ptr 0xd27eebec not within fm->least_addr 0xd5000000 and fm->top 0xda83d980
Region #31 [UK:0xdd7a86d4] from #24 tback F2 dump off 0x14
Region #33 [UK:0xd27eef54] from tback F6
Region #34 [UK:0xd27eefa4] from #33 tback F6 dump off 0x0
d27eefd4: 00 00 00 00 7e 49 7a dd d8 22 d5 09 b4 73 0a 00  |  ....~Iz.."...s..
d27eefe4: 00 00 00 00 00 00 00 00 00 10 8f d2 04 c0 00 00  |  ................
d27eeff4: 98 fb ff dd 14 7d 5a dd 00 00 00 00              |  .....}Z.....
Region #35 [TX:0x08062bfc] from #33 tback F6 dump off 0x4
08062bdc: 56 34 12 74 1e b9 e7 02 00 00 ba c0 58 59 09 89  |  V4.t........XY..
08062bec: 4c 24 08 89 54 24 04 c7 04 24 bd b8 31 09 e8 61  |  L$..T$...$..1..a
08062bfc: ad 22 01 a1 e4 a5 ff 09 85 c0 75 76 e8 e3 ca 9b  |  ."........uv....
08062c0c: 00 83 c4 40 5b 5e 5d c3 a1 d8 71 cc 09 85 c0 0f  |  ...@[^]...q.....
08062c1c: 85 ee fd ff ff 31 c0 a3 d4 71 cc 09 b8 d4 71 cc  |  .....1...q....q.
08062c2c: 09 a3 d8 71 cc 09 e9 d8 fd ff ff 8b 56 10 8b 46  |  ...q........V..F
08062c3c: 04 89 42 04 8b 16 e9 df fd ff ff 39 45 d8 0f 87  |  ..B........9E...
08062c4c: 16 ff ff ff 8b 55 d8 8b 4d dc e9 17 ff ff ff b8  |  .....U..M.......
08062c5c: ad 02 00 00 89 44 24 08 b8 c0 58 59 09 89 44 24  |  .....D$...XY..D$
08062c6c: 04 c7 04 24 6d b8 31 09 e8 e7 ac 22 01 e9 24 fc  |  ...$m.1...."..$.
Region #36 [UD:0x0931b8bc] from #33 tback F6 dump off 0x8
Region #37 [UD:0x095958c0] from #33 tback F6 dump off 0xc
Region #45 [UK:0xd27eefa4] from tback F7
Region #46 [UK:0xd27eeff4] from #45 tback F7 dump off 0x0
Region #47 [TX:0x08062f34] from #45 tback F7 dump off 0x4
08062f14: 85 c0 0f 84 c8 00 00 00 8b 75 e0 8b 16 89 55 e0  |  .........u....U.
08062f24: 80 be ae 00 00 00 00 75 db 89 f0 31 db e8 5a f9  |  .......u...1..Z.
08062f34: ff ff 8d 76 00 8d bc 27 00 00 00 00 a1 70 1b e3  |  ...v...'.....p..
08062f44: 09 8b 15 74 1b e3 09 89 45 ec 8d 45 ec 89 55 f0  |  ...t....E..E..U.
08062f54: 89 04 24 e8 c4 be ff ff 85 c0 0f 84 e6 01 00 00  |  ..$.............
08062f64: c7 04 24 60 1b e3 09 e8 80 c6 ff ff 85 c0 89 c2  |  ..$`............
08062f74: 0f 84 94 02 00 00 0f b7 40 18 66 83 f8 01 0f 84  |  ........@.f.....
08062f84: 14 02 00 00 0f 82 79 01 00 00 66 83 f8 02 0f 84  |  ......y...f.....
08062f94: 4e 02 00 00 66 83 f8 03 8d 74 26 00 0f 85 70 fe  |  N...f....t&...p.
08062fa4: ff ff b8 00 00 00 40 89 44 24 04 89 14 24 e8 59  |  ......@.D$...$.Y
Region #48 [UK:0xdd7aa194] from #45 tback F7 dump off 0x14
dd7aa174: 0c ce 7a dd 58 a3 7a dd e0 09 80 dd 54 a3 7a dd  |  ..z.X.z.....T.z.
dd7aa184: fc f5 58 dd c0 d9 67 dd d0 37 7a dd 60 f3 67 dd  |  ..X...g..7z.`.g.
dd7aa194: 18 c0 00 00 40 d5 7e dd 10 82 7f dd 66 1a 7a dd  |  ....@.~....f.z.
dd7aa1a4: 40 d9 58 dd 86 1a 7a dd 96 1a 7a dd 77 cf 65 dd  |  @.X...z...z.w.e.
dd7aa1b4: b6 1a 7a dd c6 1a 7a dd d6 1a 7a dd e6 1a 7a dd  |  ..z...z...z...z.
dd7aa1c4: 30 66 7a dd e4 a2 62 dd 16 1b 7a dd 26 1b 7a dd  |  0fz...b...z.&.z.
dd7aa1d4: 36 1b 7a dd 40 ec 61 dd 56 1b 7a dd 66 1b 7a dd  |  6.z.@.a.V.z.f.z.
dd7aa1e4: c0 af a2 08 86 1b 7a dd 96 1b 7a dd 99 27 7a dd  |  ......z...z..'z.
dd7aa1f4: 10 84 5d dd 80 17 63 dd d6 1b 7a dd e6 1b 7a dd  |  ..]...c...z...z.
dd7aa204: 26 47 7a dd 98 bf 63 dd 16 1c 7a dd 26 1c 7a dd  |  &Gz...c...z.&.z.
Region #49 [0xd51ab230] from #45 tback F7 dump off 0x1c
d51ab210: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d51ab220: 00 00 00 00 00 00 00 00 70 f6 2c d5 38 b0 1a d5  |  ........p.,.8...
d51ab230: 00 00 00 00 64 24 e3 09 56 34 12 ff 38 b0 1a d5  |  ....d$..V4..8...
d51ab240: 64 24 e3 09 68 95 36 09 24 a3 1a 08 24 9e 2c d5  |  d$..h.6.$...$.,.
d51ab250: 70 9e 2c d5 64 24 e3 09 30 b2 1a d5 80 1a e7 d7  |  p.,.d$..0.......
d51ab260: e0 9f 2a d5 00 00 02 00 4a de 30 2f 56 00 00 00  |  ..*.....J.0/V...
d51ab270: 40 6a 14 d2 29 00 00 00 f2 ca 2d 00 00 00 00 00  |  @j..).....-.....
d51ab280: 00 00 00 00 00 00 00 00 4f 30 86 51 01 00 00 00  |  ........O0.Q....
d51ab290: 03 00 00 00 01 00 00 00 d3 17 77 07 d3 17 77 07  |  ..........w...w.
d51ab2a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #50 [0xd51806e8] from #49 (malloc_header) magic off 0
M-size    : 0x2b110
Region #51 [ID:0x09e31fd0] from #45 tback F7 dump off 0x20
09e31fb0: 63 6e 4e 09 90 7c 05 08 c0 62 c5 09 00 00 00 00  |  cnN..|...b......
09e31fc0: 00 00 00 00 bf b1 31 09 01 00 00 00 00 00 00 00  |  ......1.........
09e31fd0: 00 00 00 00 d0 1f e3 09 00 00 00 00 00 00 00 00  |  ................
09e31fe0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09e31ff0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09e32000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09e32010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09e32020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09e32030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09e32040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #52 [0xd519d5b0] from #45 tback F7 dump off 0x24
Region #53 [0xd51806e8] from #52 (malloc_header) magic off 0
M-size    : 0x2b110
Region #54 [ID:0x09e31fd0] from #45 tback F7 dump off 0x28
Region #55 [UK:0xdd7a497c] from #45 tback F7 dump off 0x34
dd7a495c: 08 75 06 83 7a 10 00 75 07 b8 01 00 00 00 eb 1e  |  .u..z..u........
dd7a496c: c7 42 08 00 00 00 00 8d 42 10 89 04 24 e8 2c 29  |  .B......B...$.,)
dd7a497c: 00 00 b8 00 00 00 00 eb 05 b8 16 00 00 00 8b 5d  |  ...............]
dd7a498c: fc 89 ec 5d c3 55 89 e5 8b 45 08 c7 00 00 00 00  |  ...].U...E......
dd7a499c: 00 b8 00 00 00 00 5d c3 55 89 e5 b8 00 00 00 00  |  ......].U.......
dd7a49ac: 5d c3 55 89 e5 8b 55 0c 83 fa 03 74 13 83 fa 01  |  ].U...U....t....
dd7a49bc: 74 0e 83 fa 02 74 09 b8 16 00 00 00 85 d2 75 0a  |  t....t........u.
dd7a49cc: 8b 45 08 89 10 b8 00 00 00 00 5d c3 55 89 e5 8b  |  .E........].U...
dd7a49dc: 45 08 8b 10 8b 45 0c 89 10 b8 00 00 00 00 5d c3  |  E....E........].
dd7a49ec: 55 89 e5 8b 45 0c c7 00 00 00 00 00 b8 00 00 00  |  U...E...........
Region #56 [ID:0x09d522d8] from #45 tback F7 dump off 0x38
09d522b8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09d522c8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09d522d8: 00 00 00 00 00 00 00 00 01 00 00 00 01 00 00 00  |  ................
09d522e8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09d522f8: 00 00 00 00 00 00 00 00 00 00 00 00 40 d5 7e dd  |  ............@.~.
09d52308: d8 53 7a dd 00 00 00 00 00 00 00 00 00 00 00 00  |  .Sz.............
09d52318: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09d52328: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09d52338: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09d52348: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #57 [UK:0xd27eeff4] from tback F8
Region #58 [UK:0xddfffb98] from #57 tback F8 dump off 0x0
ddfffb78: 01 00 00 00 00 f0 8e d2 00 00 10 00 00 00 00 00  |  ................
ddfffb88: 00 00 00 00 00 00 00 00 00 10 8f d2 04 c0 00 00  |  ................
ddfffb98: 58 fc ff dd 09 30 a2 08 48 fc ff dd 00 00 00 00  |  X....0..H.......
ddfffba8: f0 27 a2 08 00 00 00 00 00 00 00 00 c0 fb ff dd  |  .'..............
ddfffbb8: 00 00 00 00 ff ff ff ff 07 73 3e be ff ff ff ff  |  .........s>.....
ddfffbc8: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff  |  ................
ddfffbd8: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff  |  ................
ddfffbe8: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff  |  ................
ddfffbf8: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff  |  ................
ddfffc08: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff  |  ................
Region #59 [UK:0xdd5a7d14] from #57 tback F8 dump off 0x4
dd5a7cf4: f7 d9 89 50 30 e3 0a 8b 44 8c 0c 89 04 8a 49 75  |  ...P0...D.....Iu
dd5a7d04: f6 e8 00 00 00 00 59 81 c1 0a 00 00 00 89 0a c3  |  ......Y.........
dd5a7d14: 8d 24 9c e8 00 00 00 00 5b 81 c3 bc 41 0d 00 58  |  .$......[...A..X
dd5a7d24: 85 c0 74 06 50 e8 12 ff ff ff 50 e8 7c 76 fe ff  |  ..t.P.....P.|v..
dd5a7d34: f4 90 90 90 90 90 90 90 90 90 90 90 8b 44 24 04  |  .............D$.
dd5a7d44: c7 40 40 00 00 00 00 89 48 3c 89 50 38 89 78 24  |  .@@.....H<.P8.x$
dd5a7d54: 89 70 28 89 68 2c 8b 0c 24 89 48 4c 8d 4c 24 04  |  .p(.h,..$.HL.L$.
dd5a7d64: 89 48 30 89 58 34 31 d2 66 8c e2 89 50 18 8d 88  |  .H0.X41.f...P...
dd5a7d74: ec 00 00 00 89 48 60 d9 31 8b 4c 24 08 53 8d 50  |  .....H`.1.L$.S.P
dd5a7d84: 6c 8d 49 6c bb 02 00 00 00 b8 7e 00 00 00 cd 80  |  l.Il......~.....
Region #60 [UK:0xddfffb98] from tback F9
Region #61 [UK:0xddfffc58] from #60 tback F9 dump off 0x0
ddfffc38: ff ff ff ff ff ff ff ff 00 00 00 00 00 00 00 00  |  ................
ddfffc48: 04 c0 00 00 ff 00 00 00 ed 27 da 01 90 fc ff dd  |  .........'......
ddfffc58: a8 fd ff dd 66 35 a2 08 00 00 00 00 00 00 00 00  |  ....f5..........
ddfffc68: ff 00 00 00 08 00 00 00 02 00 00 00 01 00 00 00  |  ................
ddfffc78: 09 00 00 00 30 00 00 00 48 8e 04 08 00 d0 7e dd  |  ....0...H.....~.
ddfffc88: 00 00 00 00 da 15 65 00 c0 37 a2 08 07 7b 3f be  |  ......e..7...{?.
ddfffc98: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff  |  ................
ddfffca8: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff  |  ................
ddfffcb8: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff  |  ................
ddfffcc8: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff  |  ................
Region #62 [TX:0x08a23008] from #60 tback F9 dump off 0x4
08a22fe8: 85 ff 75 18 c7 04 24 54 4e 59 09 e8 98 8d 62 ff  |  ..u...$TNY....b.
08a22ff8: c7 04 24 a4 62 59 09 e8 dc 1b 64 ff e8 c7 4f 00  |  ..$.bY....d...O.
08a23008: 00 c7 04 24 63 4e 59 09 e8 9b 91 62 ff c7 04 24  |  ...$cNY....b...$
08a23018: 00 00 00 00 e8 0f 8a 62 ff eb 0d 90 90 90 90 90  |  .......b........
08a23028: 90 90 90 90 90 90 90 90 55 89 e5 57 56 53 81 ec  |  ........U..WVS..
08a23038: 2c 01 00 00 8b 5d 0c 83 e4 f0 8b 75 08 83 ec 10  |  ,....].....u....
08a23048: 89 1d c4 fb d4 09 89 35 c8 fb d4 09 8b 03 a3 b0  |  .......5........
08a23058: 69 f4 09 e8 20 89 62 ff a3 30 e7 d4 09 b8 a6 4e  |  i... .b..0.....N
08a23068: 59 09 89 44 24 08 89 5c 24 04 89 34 24 e8 b6 8f  |  Y..D$..\$..4$...
08a23078: 62 ff 3c ff 0f 84 da 01 00 00 0f be c0 8d 50 9f  |  b.<...........P.
Region #63 [TX:0x08a227f0] from #60 tback F9 dump off 0x10
08a227d0: 81 c7 48 f4 d4 09 f3 a5 c1 e2 03 29 d0 05 b0 f0  |  ..H........)....
08a227e0: d4 09 e8 19 f4 ff ff eb fe 8d b4 26 00 00 00 00  |  ...........&....
08a227f0: 55 89 e5 57 bf 5c d2 92 09 56 53 bb e8 d0 92 09  |  U..W.\...VS.....
08a22800: 81 ec cc 01 00 00 8d b5 6c fe ff ff 89 34 24 e8  |  ........l....4$.
08a22810: 9c 9d 62 ff 81 3b a0 3a a2 08 75 0f 8b 43 f8 89  |  ..b..;.:..u..C..
08a22820: 34 24 89 44 24 04 e8 45 99 62 ff 83 c3 0c 39 df  |  4$.D$..E.b....9.
08a22830: 75 e2 31 c9 89 4c 24 08 8d bd 6c ff ff ff 89 74  |  u.1..L$...l....t
08a22840: 24 04 c7 04 24 00 00 00 00 e8 32 99 62 ff 31 c0  |  $...$.....2.b.1.
08a22850: b9 20 00 00 00 fc f3 ab b9 20 00 00 00 8d bd ec  |  . ....... ......
08a22860: fe ff ff fc f3 ab a1 58 1f f4 09 85 c0 89 85 40  |  .......X.......@
Region #64 [UK:0xddfffbc0] from #60 tback F9 dump off 0x1c
ddfffba0: 48 fc ff dd 00 00 00 00 f0 27 a2 08 00 00 00 00  |  H........'......
ddfffbb0: 00 00 00 00 c0 fb ff dd 00 00 00 00 ff ff ff ff  |  ................
ddfffbc0: 07 73 3e be ff ff ff ff ff ff ff ff ff ff ff ff  |  .s>.............
ddfffbd0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff  |  ................
ddfffbe0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff  |  ................
ddfffbf0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff  |  ................
ddfffc00: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff  |  ................
ddfffc10: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff  |  ................
ddfffc20: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff  |  ................
ddfffc30: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff  |  ................
Region #72 [UK:0xddfffc58] from tback F10
Region #73 [UK:0xddfffda8] from #72 tback F10 dump off 0x0
ddfffd88: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff  |  ................
ddfffd98: ff ff ff ff d8 be 67 dd 4c 88 7f dd f4 fd ff dd  |  ......g.L......
ddfffda8: c8 fd ff dd f4 b4 57 dd 05 00 00 00 f4 fd ff dd  |  ......W.........
ddfffdb8: 0c fe ff dd b0 09 80 dd 05 00 00 00 00 c9 04 08  |  ................
ddfffdc8: 00 00 00 00 21 c9 04 08 30 30 a2 08 05 00 00 00  |  ....!...00......
ddfffdd8: f4 fd ff dd 08 95 31 09 62 95 31 09 4c 88 7f dd  |  ......1.b.1.L..
ddfffde8: ec fd ff dd 5c 0f 80 dd 05 00 00 00 e9 fe ff dd  |  ....\...........
ddfffdf8: ee fe ff dd f1 fe ff dd f5 fe ff dd f8 fe ff dd  |  ................
ddfffe08: 00 00 00 00 fb fe ff dd 05 ff ff dd 33 ff ff dd  |  ............3...
ddfffe18: 3a ff ff dd 45 ff ff dd 68 ff ff dd 76 ff ff dd  |  :...E...h...v...
Region #74 [TX:0x08a23564] from #72 tback F10 dump off 0x4
08a23544: 00 00 00 a1 b8 d2 92 09 85 c0 75 0a b8 01 00 00  |  ..........u.....
08a23554: 00 a3 20 20 d5 09 c7 04 24 00 00 00 00 e8 7a f7  |  ..  ....$.....z.
08a23564: ff ff c7 04 24 fb 4e 59 09 e8 3e 8c 62 ff c7 04  |  ....$.NY..>.b...
08a23574: 24 00 00 00 00 e8 02 93 62 ff e8 0d a4 1e 00 89  |  $.......b.......
08a23584: c3 89 04 24 e8 f3 d7 1e 00 89 1c 24 e8 6b d8 1e  |  ...$.......$.k..
08a23594: 00 e8 56 be 1e 00 0f b6 c3 89 44 24 10 b8 68 b4  |  ..V.......D$..h.
08a235a4: 42 09 c1 fb 08 89 44 24 08 b8 50 00 00 00 89 5c  |  B.....D$..P....\
08a235b4: 24 0c 89 44 24 04 c7 04 24 40 01 d5 09 e8 da 91  |  $..D$...$@......
08a235c4: 62 ff e9 2f ff ff ff ba ff 01 00 00 89 54 24 04  |  b../.........T$.
08a235d4: c7 04 24 a0 01 d5 09 e8 d0 83 62 ff 85 c0 0f 84  |  ..$.......b.....
Region #79 [TX:0x08048e48] from #72 tback F10 dump off 0x28
08048e28: 9a 0b 00 00 00 00 00 00 3c 00 00 00 12 00 00 00  |  ........<.......
08048e38: 37 0c 00 00 00 00 00 00 e8 06 00 00 12 00 00 00  |  7...............
08048e48: 93 0b 00 00 e0 ae a2 08 de 00 00 00 12 00 0c 00  |  ................
08048e58: 6a 06 00 00 00 00 00 00 f5 06 00 00 12 00 00 00  |  j...............
08048e68: c1 01 00 00 00 00 00 00 20 00 00 00 12 00 00 00  |  ........ .......
08048e78: bf 04 00 00 00 00 00 00 14 00 00 00 12 00 00 00  |  ................
08048e88: dd 0c 00 00 00 00 00 00 fc 00 00 00 12 00 00 00  |  ................
08048e98: 75 0a 00 00 00 00 00 00 c5 00 00 00 12 00 00 00  |  u...............
08048ea8: a1 01 00 00 00 00 00 00 13 00 00 00 12 00 00 00  |  ................
08048eb8: 9c 07 00 00 00 00 00 00 14 00 00 00 12 00 00 00  |  ................
Region #80 [UK:0xdd7ed000] from #72 tback F10 dump off 0x2c
dd7ecfe0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
dd7ecff0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
dd7ed000: 00 00 00 00 45 d3 7f dd 88 00 7e 09 40 d5 7e dd  |  ....E....~.@.~.
dd7ed010: 00 00 00 00 0c d2 7e dd 00 00 00 00 b0 00 7e 09  |  ......~.......~.
dd7ed020: 00 01 7e 09 f8 00 7e 09 c8 00 7e 09 d0 00 7e 09  |  ..~...~...~...~.
dd7ed030: d8 00 7e 09 00 00 00 00 00 00 00 00 00 00 00 00  |  ..~.............
dd7ed040: e0 00 7e 09 e8 00 7e 09 b8 00 7e 09 c0 00 7e 09  |  ..~...~...~...~.
dd7ed050: 00 00 00 00 00 00 00 00 00 00 00 00 18 01 7e 09  |  ..............~.
dd7ed060: 20 01 7e 09 28 01 7e 09 08 01 7e 09 f0 00 7e 09  |   .~.(.~...~...~.
dd7ed070: 00 00 00 00 10 01 7e 09 00 00 00 00 00 00 00 00  |  ......~.........
Region #82 [TX:0x08a237c0] from #72 tback F10 dump off 0x38
08a237a0: b8 60 1c a2 08 89 44 24 08 b8 cc 45 59 09 89 44  |  .`....D$...EY..D
08a237b0: 24 04 c7 04 24 15 4f 59 09 e8 22 14 64 ff 89 f6  |  $...$.OY..".d...
08a237c0: 55 89 e5 56 53 83 ec 50 8b 5d 0c 8b 75 10 e8 ad  |  U..VS..P.]..u...
08a237d0: 51 00 00 85 c0 74 06 89 35 d0 fb d4 09 64 8b 15  |  Q....t..5....d..
08a237e0: 08 00 00 00 8b 03 83 e8 04 83 f8 1b 77 07 ff 24  |  ............w..$
08a237f0: 85 e4 45 59 09 b9 79 40 62 09 b8 cc bd 3c 09 89  |  ..EY..[email protected]...<..
08a23800: 4d f0 89 45 f4 8b 46 44 89 45 bc 8b 46 24 89 45  |  M..E..FD.E..F$.E
08a23810: c0 8b 46 28 89 45 c4 8b 46 2c 89 45 c8 8b 46 30  |  ..F(.E..F,.E..F0
08a23820: 89 45 cc 8b 46 34 89 45 d0 8b 46 38 89 45 d4 8b  |  .E..F4.E..F8.E..
08a23830: 46 3c 89 45 d8 8b 46 40 89 45 dc 8b 46 4c 89 45  |  F<.E..F@.E..FL.E
Region #84 [UK:0xddfffda8] from tback F11
Region #85 [UK:0xddfffdc8] from #84 tback F11 dump off 0x0
ddfffe28: 80 ff ff dd 8e ff ff dd ca ff ff dd d0 ff ff dd  |  ................
ddfffe38: 00 00 00 00 20 00 00 00 00 e4 ff ff 21 00 00 00  |  .... .......!...
Region #86 [UK:0xdd57b4f4] from #84 tback F11 dump off 0x4
dd57b4d4: 04 24 e8 e5 fb ff ff 8b 83 84 ff ff ff 8b 00 89  |  .$..............
dd57b4e4: 44 24 08 89 7c 24 04 8b 45 0c 89 04 24 ff 55 08  |  D$..|$..E...$.U.
dd57b4f4: 89 04 24 e8 b4 3e 01 00 55 89 e5 83 ec 18 89 5d  |  ..$..>..U......]
dd57b504: fc e8 3a fe ff ff 81 c3 ce 09 10 00 c7 44 24 08  |  ..:..........D$.
dd57b514: 9a 02 00 00 8d 83 28 3d fe ff 89 44 24 04 c7 04  |  ......(=...D$...
dd57b524: 24 01 00 00 00 e8 c2 a8 0a 00 8b 5d fc 89 ec 5d  |  $..........]...]
dd57b534: c3 55 89 e5 e8 1d 3d 0e 00 81 c1 9b 09 10 00 8d  |  .U....=.........
dd57b544: 81 08 3d fe ff 5d c3 55 89 e5 e8 07 3d 0e 00 81  |  ..=..].U....=...
dd57b554: c1 85 09 10 00 8d 81 0f 3d fe ff 5d c3 55 89 e5  |  ........=..].U..
dd57b564: 83 ec 08 89 5d fc e8 d5 fd ff ff 81 c3 69 09 10  |  ....]........i..
Region #88 [UK:0xddfffdf4] from #84 tback F11 dump off 0xc
ddfffdd4: 05 00 00 00 f4 fd ff dd 08 95 31 09 62 95 31 09  |  ..........1.b.1.
ddfffde4: 4c 88 7f dd ec fd ff dd 5c 0f 80 dd 05 00 00 00  |  L......\.......
ddfffdf4: e9 fe ff dd ee fe ff dd f1 fe ff dd f5 fe ff dd  |  ................
ddfffe04: f8 fe ff dd 00 00 00 00 fb fe ff dd 05 ff ff dd  |  ................
ddfffe14: 33 ff ff dd 3a ff ff dd 45 ff ff dd 68 ff ff dd  |  3...:...E...h...
ddfffe24: 76 ff ff dd 80 ff ff dd 8e ff ff dd ca ff ff dd  |  v...............
ddfffe34: d0 ff ff dd 00 00 00 00 20 00 00 00 00 e4 ff ff  |  ........ .......
ddfffe44: 21 00 00 00 00 e0 ff ff 10 00 00 00 3d a9 88 00  |  !...........=...
ddfffe54: 06 00 00 00 00 10 00 00 11 00 00 00 64 00 00 00  |  ............d...
ddfffe64: 03 00 00 00 34 80 04 08 04 00 00 00 20 00 00 00  |  ....4....... ...
Region #89 [UK:0xddfffe0c] from #84 tback F11 dump off 0x10
ddfffdec: 5c 0f 80 dd 05 00 00 00 e9 fe ff dd ee fe ff dd  |  \...............
ddfffdfc: f1 fe ff dd f5 fe ff dd f8 fe ff dd 00 00 00 00  |  ................
ddfffe0c: fb fe ff dd 05 ff ff dd 33 ff ff dd 3a ff ff dd  |  ........3...:...
ddfffe1c: 45 ff ff dd 68 ff ff dd 76 ff ff dd 80 ff ff dd  |  E...h...v.......
ddfffe2c: 8e ff ff dd ca ff ff dd d0 ff ff dd 00 00 00 00  |  ................
ddfffe3c: 20 00 00 00 00 e4 ff ff 21 00 00 00 00 e0 ff ff  |   .......!.......
ddfffe4c: 10 00 00 00 3d a9 88 00 06 00 00 00 00 10 00 00  |  ....=...........
ddfffe5c: 11 00 00 00 64 00 00 00 03 00 00 00 34 80 04 08  |  ....d.......4...
ddfffe6c: 04 00 00 00 20 00 00 00 05 00 00 00 08 00 00 00  |  .... ...........
ddfffe7c: 07 00 00 00 00 e0 7e dd 08 00 00 00 00 00 00 00  |  ......~.........
Region #90 [UK:0xdd8009b0] from #84 tback F11 dump off 0x14
dd800990: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
dd8009a0: 54 0f 80 dd 26 47 7a dd f4 48 7a dd 5c 0f 80 dd  |  T...&Gz..Hz.\...
dd8009b0: f0 28 01 00 00 00 00 00 00 00 00 00 c0 af a2 08  |  .(..............
dd8009c0: 60 ad a2 08 e0 ae a2 08 ba 29 5d dd 40 ae a2 08  |  `........)].@...
dd8009d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
dd8009e0: 00 d0 7e dd 09 00 00 00 50 d1 7e dd 00 00 00 00  |  ..~.....P.~.....
dd8009f0: 50 d1 7e dd f0 07 6a dd 09 00 00 00 00 00 00 00  |  P.~...j.........
dd800a00: 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00  |  ................
dd800a10: 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00  |  ................
dd800a20: 08 11 06 02 db fe ff dd 04 00 00 00 64 00 00 00  |  ............d...
Region #92 [TX:0x0804c900] from #84 tback F11 dump off 0x1c
0804c8e0: ff 25 b8 05 7e 09 68 10 08 00 00 e9 c0 ef ff ff  |  .%..~.h.........
0804c8f0: ff 25 bc 05 7e 09 68 18 08 00 00 e9 b0 ef ff ff  |  .%..~.h.........
0804c900: 31 ed 5e 89 e1 83 e4 f0 50 54 52 68 62 95 31 09  |  1.^.....PTRhb.1.
0804c910: 68 08 95 31 09 51 56 68 30 30 a2 08 e8 4f f3 ff  |  h..1.QVh00...O..
0804c920: ff f4 90 90 55 89 e5 53 83 ec 04 e8 00 00 00 00  |  ....U..S........
0804c930: 5b 81 c3 74 38 79 01 8b 83 d8 ff ff ff 85 c0 74  |  [..t8y.........t
0804c940: 02 ff d0 8b 5d fc c9 c3 90 90 90 90 90 90 90 90  |  ....]...........
0804c950: 55 89 e5 83 ec 08 80 3d e8 0f c6 09 00 74 0c eb  |  U......=.....t..
0804c960: 1c 83 c0 04 a3 c8 05 7e 09 ff d2 a1 c8 05 7e 09  |  .......~......~.
0804c970: 8b 10 85 d2 75 eb c6 05 e8 0f c6 09 01 c9 c3 90  |  ....u...........
Region #93 [TX:0x0804c920] from #84 tback F11 dump off 0x24
0804c980: 55 89 e5 83 ec 08 a1 7c 00 7e 09 85 c0 74 12 b8  |  U......|.~...t..
0804c990: 00 00 00 00 85 c0 74 09 c7 04 24 7c 00 7e 09 ff  |  ......t...$|.~..
Region #94 [TX:0x08a23030] from #84 tback F11 dump off 0x28
08a23010: e8 9b 91 62 ff c7 04 24 00 00 00 00 e8 0f 8a 62  |  ...b...$.......b
08a23020: ff eb 0d 90 90 90 90 90 90 90 90 90 90 90 90 90  |  ................
08a23030: 55 89 e5 57 56 53 81 ec 2c 01 00 00 8b 5d 0c 83  |  U..WVS..,....]..
08a23040: e4 f0 8b 75 08 83 ec 10 89 1d c4 fb d4 09 89 35  |  ...u...........5
08a23050: c8 fb d4 09 8b 03 a3 b0 69 f4 09 e8 20 89 62 ff  |  ........i... .b.
08a23060: a3 30 e7 d4 09 b8 a6 4e 59 09 89 44 24 08 89 5c  |  .0.....NY..D$..\
08a23070: 24 04 89 34 24 e8 b6 8f 62 ff 3c ff 0f 84 da 01  |  $..4$...b.<.....
08a23080: 00 00 0f be c0 8d 50 9f 83 fa 17 77 0a 8d 76 00  |  ......P....w..v.
08a23090: ff 24 95 6c 45 59 09 89 44 24 04 c7 04 24 8d 4e  |  .$.lEY..D$...$.N
08a230a0: 59 09 e8 09 91 62 ff c7 04 24 f4 59 59 09 e8 fd  |  Y....b...$.YY...
Region #96 [ID:0x09e31fd0] from %edi
Region #97 [ID:0x09e31fd0] from #96 (%edi) dump off 0x4
Region #98 [0xd519d5b0] from %esi
Region #99 [0xd51806e8] from #98 (malloc_header) magic off 0
M-size    : 0x2b110
Region #100 [ID:0x09e31c88] from #98 (%esi) dump off 0x4
09e31c68: 00 5c b2 ec 22 00 00 00 00 00 00 00 70 1c e3 09  |  .\..".......p...
09e31c78: 78 b8 1a d5 00 00 00 00 00 00 00 00 00 00 00 00  |  x...............
09e31c88: b0 d5 19 d5 b0 d5 19 d5 00 00 00 00 00 00 00 00  |  ................
09e31c98: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09e31ca8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09e31cb8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09e31cc8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09e31cd8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09e31ce8: 88 1c e3 09 00 00 00 00 00 ac 23 fc 06 00 00 00  |  ..........#.....
09e31cf8: 09 00 00 00 d8 41 1e d5 00 00 00 00 00 00 00 00  |  .....A..........
Region #102 [0xd519d3b8] from #98 (%esi) dump off 0xc
d519d398: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d519d3a8: 00 00 00 00 00 00 00 00 30 20 59 d8 c0 d1 19 d5  |  ........0 Y.....
d519d3b8: 88 df 19 d5 c0 d1 19 d5 56 34 12 ff c0 d1 19 d5  |  ........V4......
d519d3c8: ac 1b e3 09 16 04 3b 09 13 c0 21 08 e4 ee 58 d8  |  ......;...!...X.
d519d3d8: 30 ef 58 d8 00 00 00 00 b8 d3 19 d5 80 f4 58 d8  |  0.X...........X.
d519d3e8: 50 b4 58 d8 00 40 00 00 87 c0 14 ea 53 00 00 00  |  P.X..@......S...
d519d3f8: 58 b2 09 00 00 00 00 00 5a af 05 00 00 00 00 00  |  X.......Z.......
d519d408: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d519d418: 03 00 00 00 02 00 00 00 17 00 00 00 00 00 00 00  |  ................
d519d428: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #103 [0xd51806e8] from #102 (malloc_header) magic off 0
M-size    : 0x2b110
Region #104 [ID:0x09e31c88] from #98 (%esi) dump off 0x10
Region #105 [UD:0x0964d21c] from #98 (%esi) dump off 0x14
0964d1fc: 65 6c 0a 00 43 6f 75 6c 64 6e 27 74 20 66 69 6e  |  el..Couldn't fin
0964d20c: 64 20 6c 6f 67 20 68 6f 73 74 20 65 6e 74 72 79  |  d log host entry
0964d21c: 0a 00 6c 6f 67 67 65 72 5f 73 61 76 65 00 65 6d  |  ..logger_save.em
0964d22c: 65 72 67 65 6e 63 69 65 73 00 63 70 5f 73 79 73  |  ergencies.cp_sys
0964d23c: 6c 6f 67 5f 66 72 6f 6d 5f 64 70 5f 63 6f 6e 74  |  log_from_dp_cont
0964d24c: 65 78 74 00 6e 70 5f 6d 73 67 5f 69 6e 64 65 78  |  ext.np_msg_index
0964d25c: 20 3c 20 4e 50 5f 53 59 53 4c 4f 47 5f 4c 41 53  |   < NP_SYSLOG_LAS
0964d26c: 54 00 25 73 20 43 61 6e 6e 6f 74 20 73 65 74 20  |  T.%s Cannot set
0964d27c: 74 6f 20 63 6f 6e 74 65 78 74 20 25 64 0a 00 53  |  to context %d..S
0964d28c: 79 73 6c 6f 67 20 25 64 20 69 73 20 72 61 74 65  |  yslog %d is rate
Region #106 [TX:0x08475534] from #98 (%esi) dump off 0x18
08475514: 7e 51 47 8b 85 d8 fd ff ff 8b 18 89 04 24 e8 59  |  ~QG..........$.Y
08475524: aa e0 00 64 a1 00 00 00 00 85 c0 74 05 e8 4a dd  |  ...d.......t..J.
08475534: be ff 85 db 89 9d d8 fd ff ff 0f 84 a0 00 00 00  |  ................
08475544: 8b 9d d8 fd ff ff 31 c0 83 c3 04 83 bd d0 fd ff  |  ......1.........
08475554: ff 01 0f 85 1b ff ff ff 8b 85 b0 fd ff ff e9 10  |  ................
08475564: ff ff ff 7d ae 8b 95 d8 fd ff ff 8b 1a 89 14 24  |  ...}...........$
08475574: e8 07 aa e0 00 85 db 89 9d d8 fd ff ff 75 e6 85  |  .............u..
08475584: f6 0f 85 75 03 00 00 bf ff ff ff ff 81 c4 6c 02  |  ...u..........l.
08475594: 00 00 89 f8 5b 5e 5f 5d c3 85 f6 0f 84 ef 01 00  |  ....[^_]........
084755a4: 00 c7 04 24 14 01 00 00 e8 af 93 60 00 8b 95 dc  |  ...$.......`....
Region #107 [0xd8245764] from #98 (%esi) dump off 0x1c
d8245744: 58 01 00 d5 50 5a 24 d8 00 00 00 00 f8 02 00 00  |  X...PZ$.........
d8245754: 01 00 00 00 28 28 83 da 00 19 00 00 b0 57 24 d8  |  ....((.......W$.
d8245764: 42 33 06 08 00 00 00 00 08 00 00 d5 90 57 24 d8  |  B3...........W$.
d8245774: a8 ef a7 08 08 00 00 d5 40 29 83 da 00 00 00 00  |  ........@)......
d8245784: 00 00 00 00 08 00 00 d5 72 00 00 00 b0 57 24 d8  |  ........r....W$.
d8245794: b8 ff 27 09 08 00 00 d5 08 28 83 da 00 00 00 00  |  ..'......(......
d82457a4: 68 29 83 da 00 00 00 00 72 00 00 00 30 5a 24 d8  |  h)......r...0Z$.
d82457b4: 36 55 47 08 28 28 83 da 2c 28 83 da 50 5a 24 d8  |  6UG.((..,(..PZ$.
d82457c4: 72 ca 2c d5 82 ca 2c d5 92 ca 2c d5 d2 ca 2c d5  |  r.,...,...,...,.
d82457d4: d8 ca 2c d5 2c 28 83 da b4 58 24 d8 d8 ca 2c d5  |  ..,.,(...X$...,.
Region #108 [0xd8243ea0] from #107 (malloc_header) magic off 0
d8243e80: 00 00 00 00 00 00 ff ff 00 00 ff 00 ff ff 00 00  |  ................
d8243e90: 00 00 00 00 ef cd 1c a1 d0 d4 00 fc c3 05 00 00  |  ................
d8243ea0: 23 01 1c a1 94 05 00 00 00 00 00 00 c0 35 24 d8  |  #............5$.
d8243eb0: e0 77 24 d8 f5 af bc 08 00 00 00 00 50 57 ff 75  |  .w$.........PW.u
d8243ec0: 00 78 24 d8 07 00 00 00 ea 4a 09 00 01 00 00 00  |  .x$......J......
d8243ed0: 44 00 00 00 00 00 00 00 01 00 00 00 36 30 39 30  |  D...........6090
d8243ee0: 30 32 3a 20 54 65 61 72 64 6f 77 6e 20 6c 6f 63  |  02: Teardown loc
d8243ef0: 61 6c 2d 68 6f 73 74 20 69 64 65 6e 74 69 74 79  |  al-host identity
d8243f00: 3a 39 32 2e 36 31 2e 31 39 33 2e 31 33 31 20 64  |  :92.61.193.131 d
d8243f10: 75 72 61 74 69 6f 6e 20 30 3a 30 30 3a 30 30 0a  |  uration 0:00:00.
malloc_header:0d8243ea0
M-size    : 0x594
M-allocd  : 0x8bcaff5
**WARNING: mh_tail_offset(mh) contains 0xffffffff not MALLOC_MAGIC_TAIL
**WARNING: ptr 0xd8245764 not within (mh + 1) 0xd8243ec0 and (ulong)(mh + 1) + mh->mh_len 0xd8244454
Region #109 [0xd82457b0] from #98 (%esi) dump off 0x20
d8245790: b0 57 24 d8 b8 ff 27 09 08 00 00 d5 08 28 83 da  |  .W$...'......(..
d82457a0: 00 00 00 00 68 29 83 da 00 00 00 00 72 00 00 00  |  ....h)......r...
d82457b0: 30 5a 24 d8 36 55 47 08 28 28 83 da 2c 28 83 da  |  0Z$.6UG.((..,(..
d82457c0: 50 5a 24 d8 72 ca 2c d5 82 ca 2c d5 92 ca 2c d5  |  PZ$.r.,...,...,.
d82457d0: d2 ca 2c d5 d8 ca 2c d5 2c 28 83 da b4 58 24 d8  |  ..,...,.,(...X$.
d82457e0: d8 ca 2c d5 d2 ca 2c d5 92 ca 2c d5 82 ca 2c d5  |  ..,...,...,...,.
d82457f0: 72 ca 2c d5 52 ca 2c d5 12 c9 2c d5 00 00 00 00  |  r.,.R.,...,.....
d8245800: 01 00 00 00 68 d8 83 da 28 28 83 da 00 00 00 00  |  ....h...((......
d8245810: 54 5a 24 d8 4c 4f 47 2d 32 30 31 33 2d 30 37 2d  |  TZ$.LOG-2013-07-
d8245820: 32 34 2d 30 34 30 34 30 30 2e 54 58 54 00 00 00  |  24-040400.TXT...
Region #110 [0xd8243ea0] from #109 (malloc_header) magic off 0
M-size    : 0x594
**WARNING: ptr 0xd82457b0 not within (mh + 1) 0xd8243ec0 and (ulong)(mh + 1) + mh->mh_len 0xd8244454
Region #111 [ID:0x09e31c88] from #98 (%esi) dump off 0x24
Region #112 [0xd519d5b0] from #98 (%esi) dump off 0x28
Region #113 [0xd51806e8] from #112 (malloc_header) magic off 0
M-size    : 0x2b110
Region #115 [0xd82445f0] from #98 (%esi) dump off 0x30
d82445d0: a8 49 24 d8 d8 be 67 dd 08 00 00 00 7d 51 24 d8  |  .I$...g.....}Q$.
d82445e0: 6d 00 00 00 00 00 00 00 b4 e2 5c dd 73 00 00 00  |  m.........\.s...
d82445f0: 06 32 00 00 78 56 34 12 78 56 34 12 94 a1 7a dd  |  .2..xV4.xV4...z.
d8244600: 00 00 00 00 0a 00 00 00 28 46 24 d8 d5 86 7a dd  |  ........(F$...z.
d8244610: 0e 00 00 00 3c 46 24 d8 bc 46 24 d8 78 56 34 12  |  ....
d8244620: d8 be 67 dd cc d2 92 09 c0 49 24 d8 e0 d1 58 dd  |  ..g......I$...X.
d8244630: 0e 00 00 00 3c 46 24 d8 bc 46 24 d8 0e 00 00 00  |  ....
d8244640: 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00  |  ................
d8244650: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
d8244660: 78 56 34 12 78 56 34 12 78 56 34 12 78 56 34 12  |  xV4.xV4.xV4.xV4.
Region #116 [0xd8243ea0] from #115 (malloc_header) magic off 0
M-size    : 0x594
**WARNING: ptr 0xd82445f0 not within (mh + 1) 0xd8243ec0 and (ulong)(mh + 1) + mh->mh_len 0xd8244454
Region #125 [ID:0x09e31d60] from %ebx
09e31d40: f0 54 21 d6 00 00 00 00 00 00 00 00 00 00 00 00  |  .T!.............
09e31d50: d8 1a 1e d5 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09e31d60: 00 00 00 00 d0 1f e3 09 b0 d5 19 d5 54 ef 7e d2  |  ............T.~.
09e31d70: 30 ef 7e d2 60 1d e3 09 c0 58 59 09 e7 02 00 00  |  0.~.`....XY.....
09e31d80: 80 1d e3 09 00 00 00 00 6b d9 28 09 00 00 00 00  |  ........k.(.....
09e31d90: 00 00 00 00 00 00 00 00 00 00 00 00 fc fe 34 12  |  ..............4.
09e31da0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09e31db0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09e31dc0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09e31dd0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #126 [ID:0x09e31fd0] from #125 (%ebx) dump off 0x4
Region #127 [0xd519d5b0] from #125 (%ebx) dump off 0x8
Region #128 [0xd51806e8] from #127 (malloc_header) magic off 0
M-size    : 0x2b110
Region #129 [UK:0xd27eef54] from #125 (%ebx) dump off 0xc
Region #130 [ID:0x09e31d60] from #125 (%ebx) dump off 0x14
Region #131 [UD:0x095958c0] from #125 (%ebx) dump off 0x18
Region #133 [ID:0x09e31d80] from #125 (%ebx) dump off 0x20
09e31de0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
09e31df0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
Region #134 [TX:0x0928d968] from #125 (%ebx) dump off 0x28
0928d948: ff 85 ff 89 7d e8 7f 8e 83 c4 1c 5b 5e 5f 5d c3  |  ....}.....[^_].
0928d958: 90 90 90 90 90 90 90 90 55 89 e5 83 ec 18 e8 55  |  ........U......U
0928d968: d7 dc fe 64 a1 08 00 00 00 89 44 24 04 c7 04 24  |  ...d......D$...$
0928d978: 50 05 7d 09 e8 df 6e dd fe c7 04 24 e8 05 7d 09  |  P.}...n....$..}.
0928d988: e8 d3 6e dd fe 8b 45 10 c7 04 24 6c 06 7d 09 89  |  ..n...E...$l.}..
0928d998: 44 24 0c 8b 45 0c 89 44 24 08 8b 45 08 89 44 24  |  D$..E..D$..E..D$
0928d9a8: 04 e8 b2 6e dd fe e8 8d 45 79 ff 8d b6 00 00 00  |  ...n....Ey......
0928d9b8: 00 8d bc 27 00 00 00 00 55 a1 50 bd c5 09 89 e5  |  ...'....U.P.....
0928d9c8: 53 3b 45 10 8b 5d 14 8b 55 1c 8b 4d 20 77 09 5b  |  S;E..]..U..M w.[
0928d9d8: 5d c3 8d b6 00 00 00 00 89 55 10 89 5d 0c 89 4d  |  ]........U..]..M
Region #135 [TX:0x0927fcfc] from #134 (malloc_header) magic off 0
M-size    : 0x738d6374
**WARNING: ptr 0x928d968 not within fm->least_addr 0xd5000000 and fm->top 0xda83d980
Region #137 [UD:0x095958c0] from %edx
Region #171 [ID:0x09e31d80] from %eax
Region #172 [ID:0x09e31d80] from #171 (%eax) dump off 0x0
Region #173 [TX:0x0928d968] from #171 (%eax) dump off 0x8
Region #174 [TX:0x0927fcfc] from #173 (malloc_header) magic off 0
M-size    : 0x738d6374
Region #178 [0xd519d5b0] from #0 deep dump off 0xc
Region #179 [0xd51806e8] from #178 (malloc_header) magic off 0
M-size    : 0x2b110
Region #180 [ID:0x09e31fd0] from #0 deep dump off 0x10
Region #181 [TX:0x08a21f5c] from #0 deep dump off 0x18
08a21f3c: 00 00 00 00 55 89 e5 83 ec 08 8b 0d 60 1f f4 09  |  ....U.......`...
08a21f4c: 85 c9 74 1b e8 4b a9 62 ff ba 06 00 00 00 e8 c1  |  ..t..K.b........
08a21f5c: fe ff ff e8 2c a6 62 ff e8 27 a6 62 ff eb f4 90  |  ....,.b..'.b....
08a21f6c: 8d 74 26 00 e8 0b 9a 62 ff ba 06 00 00 00 89 54  |  .t&....b.......T
08a21f7c: 24 04 89 04 24 e8 2a a8 62 ff eb d7 90 8d b4 26  |  $...$.*.b......&
08a21f8c: 00 00 00 00 55 89 e5 57 31 ff 56 53 81 ec dc 00  |  ....U..W1.VS....
08a21f9c: 00 00 8b 15 58 1f f4 09 8b 75 10 85 d2 74 20 31  |  ....X....u...t 1
08a21fac: c9 bb 01 00 00 00 8d b4 26 00 00 00 00 8d bc 27  |  ........&......'
08a21fbc: 00 00 00 00 89 d8 d3 e0 41 09 c7 39 ca 75 f5 64  |  ........A..9.u.d
08a21fcc: a1 08 00 00 00 83 3d bc d2 92 09 ff 74 0b 81 c4  |  ......=.....t...
Region #182 [0xd519d5b0] from #0 deep dump off 0x20
Region #183 [0xd51806e8] from #182 (malloc_header) magic off 0
M-size    : 0x2b110
Region #184 [UK:0xd27eef54] from #0 deep dump off 0x24
Region #185 [TX:0x0928d9b0] from #0 deep dump off 0x28
Region #186 [TX:0x0927fcfc] from #185 (malloc_header) magic off 0
M-size    : 0x738d6374
Region #187 [UD:0x097d066c] from #0 deep dump off 0x2c
Region #188 [UD:0x0931b8bc] from #0 deep dump off 0x30
Region #189 [UD:0x095958c0] from #0 deep dump off 0x34
Region #191 [0xd519d5b0] from #0 deep dump off 0x3c
Region #192 [0xd51806e8] from #191 (malloc_header) magic off 0
M-size    : 0x2b110
Region #193 [ID:0x09e31fd0] from #0 deep dump off 0x40
Region #194 [UK:0xd27eefa4] from #0 deep dump off 0x44
Region #195 [TX:0x08062bfc] from #0 deep dump off 0x48
Region #196 [UD:0x0931b8bc] from #0 deep dump off 0x4c
Region #197 [UD:0x095958c0] from #0 deep dump off 0x50
Region #205 [0xd519d5b0] from #0 deep dump off 0x90
Region #206 [0xd51806e8] from #205 (malloc_header) magic off 0
M-size    : 0x2b110
Region #207 [UK:0xd27eeff4] from #0 deep dump off 0x94
Region #208 [TX:0x08062f34] from #0 deep dump off 0x98
Region #209 [0xd858f530] from #1 deep dump off 0x18
d858f510: 23 01 1c a1 20 00 00 00 00 00 00 00 d8 a6 58 d8  |  #... .........X.
d858f520: 10 20 59 d8 1b 59 27 09 00 00 00 00 00 00 00 00  |  . Y..Y'.........
d858f530: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  |  ................
d858f540: 00 00 00 00 00 00 00 00 58 b2 09 00 00 00 00 00  |  ........X.......
d858f550: ef cd 1c a1 00 00 00 00 d0 d4 00 fc 5b 00 00 00  |  ............[...
d858f560: 23 01 1c a1 28 00 00 00 00 00 00 00 d8 b3 58 d8  |  #...(.........X.
d858f570: 60 20 59 d8 0e 20 a8 08 00 00 00 00 00 00 00 00  |  ` Y.. ..........
d858f580: 00 00 00 00 38 8c d2 d7 b8 d3 19 d5 16 04 3b 09  |  ....8.........;.
d858f590: e0 47 00 00 00 00 00 00 b0 00 00 00 00 00 00 00  |  .G..............
d858f5a0: 96 00 00 00 16 00 00 00 ef cd 1c a1 00 00 00 00  |  ................
Region #210 [0xd519d3b8] from #1 deep dump off 0x1c
Region #211 [0xd51806e8] from #210 (malloc_header) magic off 0
M-size    : 0x2b110
Region #212 [ID:0x09e31c88] from #1 deep dump off 0x24
Region #214 [0xd519d3b8] from #1 deep dump off 0x2c
Region #215 [0xd51806e8] from #214 (malloc_header) magic off 0
M-size    : 0x2b110
Region #216 [ID:0x09e31c88] from #1 deep dump off 0x30
Region #217 [UD:0x0964d21c] from #1 deep dump off 0x34
Region #218 [TX:0x08475534] from #1 deep dump off 0x38
Region #219 [0xd8245764] from #1 deep dump off 0x3c
Region #220 [0xd8243ea0] from #219 (malloc_header) magic off 0
M-size    : 0x594
Region #221 [0xd82457b0] from #1 deep dump off 0x40
Region #222 [0xd8243ea0] from #221 (malloc_header) magic off 0
M-size    : 0x594
Region #223 [ID:0x09e31c88] from #1 deep dump off 0x44
Region #224 [0xd519d5b0] from #1 deep dump off 0x48
Region #225 [0xd51806e8] from #224 (malloc_header) magic off 0
M-size    : 0x2b110
Region #227 [0xd82445f0] from #1 deep dump off 0x50
Region #228 [0xd8243ea0] from #227 (malloc_header) magic off 0
M-size    : 0x594
End of Selective memory dump
Traceback of previous thread 'Dispatch Unit':
0: 00000001
1: 081aa324
2: 08062413
Cisco Adaptive Security Appliance Software Version 8.2(1)
Traceback output aborted.
Nested traceback attempted via signal, from:
Page fault: Address not mapped
    vector 0x0000000e
       edi 0x00000072
       esi 0xd5000008
       ebp 0x0000004c
       esp 0xd8245794
       ebx 0x00000000
       edx 0xd8245764
       ecx 0xd519d32e
       eax 0xd5190068
error code 0x00000004
       eip 0xd519d3cf
        cs 0x00000073
    eflags 0x00013212
       CR2 0x00000000
Compiled on Tue 05-May-09 22:45 by builders
Hardware:   ASA5505
Crashinfo collected on 04:07:00.969 UTC Wed Jul 24 2013
Traceback:
0: 0805d0d3
1: 0805d16b
2: 0805d1fc
3: 08a23c27
4: dd7a86d5
5: dd58d1e0
: End_Crash
------------------ show crashinfo module 1 ------------------
INFO: There is no module in slot 1 to retrieve crashinfo from.
INFO: This module has no crashinfo available.
/////////////////////////////////// Reboot History ////////////////////////////
7/24/2013 3:44 PM                    EscapeASA rebooted at 24/07/2013 15:43:00
7/24/2013 3:30 PM                    EscapeASA rebooted at 24/07/2013 15:29:00
7/24/2013 3:21 PM                    EscapeASA rebooted at 24/07/2013 15:20:00
7/24/2013 2:55 PM                    EscapeASA rebooted at 24/07/2013 14:54:00
7/24/2013 1:43 PM                    EscapeASA rebooted at 24/07/2013 13:43:00
7/24/2013 12:22 AM                    EscapeASA rebooted at 24/07/2013 00:21:00
7/23/2013 12:00 PM                    EscapeASA rebooted at 23/07/2013 11:59:00
7/23/2013 11:18 AM                    EscapeASA rebooted at 23/07/2013 11:18:00
7/23/2013 11:12 AM                    EscapeASA rebooted at 23/07/2013 11:12:00
7/23/2013 1:54 AM                    EscapeASA rebooted at 23/07/2013 01:54:00
7/22/2013 10:10 AM                    EscapeASA rebooted at 22/07/2013 10:10:00
7/21/2013 3:21 PM                    EscapeASA rebooted at 21/07/2013 15:20:00
7/20/2013 8:48 PM                    EscapeASA rebooted at 20/07/2013 20:47:00
7/20/2013 8:26 PM                    EscapeASA rebooted at 20/07/2013 20:25:00
7/20/2013 7:16 PM                    EscapeASA rebooted at 20/07/2013 19:15:00
7/20/2013 3:39 PM                    EscapeASA rebooted at 20/07/2013 15:39:00
7/20/2013 12:28 PM                    EscapeASA rebooted at 20/07/2013 12:12:00
7/20/2013 5:15 AM                    EscapeASA rebooted at 20/07/2013 05:14:00
7/19/2013 8:08 PM                    EscapeASA rebooted at 19/07/2013 20:07:00
7/19/2013 4:12 PM                    EscapeASA rebooted at 19/07/2013 16:11:00
7/19/2013 2:44 PM                    EscapeASA rebooted at 19/07/2013 14:44:00
7/19/2013 1:08 PM                    EscapeASA rebooted at 19/07/2013 13:07:00
7/18/2013 11:59 AM                    EscapeASA rebooted at 18/07/2013 11:58:00
7/18/2013 11:42 AM                    EscapeASA rebooted at 18/07/2013 11:41:00
7/18/2013 10:48 AM                    EscapeASA rebooted at 18/07/2013 10:47:00
7/18/2013 10:16 AM                    EscapeASA rebooted at 18/07/2013 10:15:00
7/18/2013 10:01 AM                    EscapeASA rebooted at 18/07/2013 10:00:00
7/18/2013 9:34 AM                    EscapeASA rebooted at 18/07/2013 09:33:00
7/18/2013 7:17 AM                    EscapeASA rebooted at 18/07/2013 07:17:00
7/18/2013 6:53 AM                    EscapeASA rebooted at 18/07/2013 06:52:00
7/18/2013 12:19 AM                    EscapeASA rebooted at 18/07/2013 00:18:00
7/17/2013 11:41 PM                    EscapeASA rebooted at 17/07/2013 23:40:00
7/17/2013 11:12 PM                    EscapeASA rebooted at 17/07/2013 23:11:00
7/17/2013 10:23 PM                    EscapeASA rebooted at 17/07/2013 22:22:00
7/17/2013 9:54 PM                    EscapeASA rebooted at 17/07/2013 21:53:00
7/17/2013 6:19 PM                    EscapeASA rebooted at 17/07/2013 18:19:00
7/17/2013 5:49 PM                    EscapeASA rebooted at 17/07/2013 17:44:00
oiram Wed, 07/24/2013 - 09:25
Indeed it could be hardware, but I would first try with IOS upgrade
You are currently on:
Device Manager Version 6.2(5)
I would go with 8.4(6) / 6.4(9) for start and see how that goes.
oiram Wed, 07/24/2013 - 09:40
Definitelly Julio, but since Tipu is not able to decode and device is critical I would seek any possible, quick and even dirty solution
Julio Carvajal Tue, 07/23/2013 - 18:00
  • Purple, 4500 points or more
Agree with Favaloro (some kudos to you Favaloro)
Based on your explanation seems like the ASA is crashing
You should get the show crash outputs, core-dumps and call Cisco TAC so we can determine what's the root of the problem,
For Networking Posts check my blog at http://www.laguiadelnetworking.com/category/english/
Cheers,
Julio Carvajal Segura
Favaloro. Wed, 07/24/2013 - 09:53
It's software, so, no need for a spare power supply.
"Crashinfo collected on 04:07:00.969 UTC Wed Jul 24 2013"
Now, a decode of the crash will be necessary, but until then, if this is so urgent, try to go to 8.2(5), that's a very stable version and very similar to what you have right now, except for the bugs.
You might try something higher than 8.3 as Mariusz suggested, but unless you know of the changes that were applied on the code and you have the necessary amount of RAM mem, you'll be up for an exciting surprise.
Also, can you try to attach the output of the "show tech" command?
Haider Malik Wed, 07/24/2013 - 10:09
Thank you i will try to upgrade the ASA tonigth as its urgent effecting working. i would apriciate if someone can point me to download link for 8.2(5) / or
I have icnluded the tech report below.
sh tech
System image file is "disk0:/Asa821-k8.bin"
Config file at boot was "startup-config"
EscapeASA up 1 hour 57 mins
Hardware:   ASA5505, 256 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash Firmware Hub @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
                             Boot microcode   :  CN1000-MC-BOOT-2.00
                             SSL/IKE microcode:  CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  :  CNlite-MC-IPSECm-MAIN-2.04
0: Int: Internal-Data0/0    : address is 8843.e112.0863, irq 11
1: Ext: Ethernet0/0         : address is 8843.e112.085b, irq 255
2: Ext: Ethernet0/1         : address is 8843.e112.085c, irq 255
3: Ext: Ethernet0/2         : address is 8843.e112.085d, irq 255
4: Ext: Ethernet0/3         : address is 8843.e112.085e, irq 255
5: Ext: Ethernet0/4         : address is 8843.e112.085f, irq 255
6: Ext: Ethernet0/5         : address is 8843.e112.0860, irq 255
7: Ext: Ethernet0/6         : address is 8843.e112.0861, irq 255
8: Ext: Ethernet0/7         : address is 8843.e112.0862, irq 255
9: Int: Internal-Data0/1    : address is 0000.0003.0002, irq 255
10: Int: Not used            : irq 255
11: Int: Not used            : irq 255
Licensed features for this platform:
Maximum Physical Interfaces  : 8
VLANs                        : 3, DMZ Restricted
Inside Hosts                 : 50
Failover                     : Disabled
VPN-DES                      : Enabled
VPN-3DES-AES                 : Enabled
SSL VPN Peers                : 2
Total VPN Peers              : 10
Dual ISPs                    : Disabled
VLAN Trunk Ports             : 0
Shared License               : Disabled
AnyConnect for Mobile        : Disabled
AnyConnect for Linksys phone : Disabled
AnyConnect Essentials        : Disabled
Advanced Endpoint Assessment : Disabled
UC Phone Proxy Sessions      : 2
Total UC Proxy Sessions      : 2
Botnet Traffic Filter        : Disabled
This platform has a Base license.
Serial Number: JMX1403406W
Running Activation Key: 0x8012e660 0xb4e3b8fb 0x8033dd70 0x8ac864d4 0xc2033ab8
Configuration register is 0x1
Configuration last modified by Admin at 04:45:39.929 UTC Wed Jul 24 2013
------------------ show clock ------------------
06:20:42.229 UTC Wed Jul 24 2013
------------------ show crashinfo ------------------
Saved crash: 23:42:56.179 UTC Mon Jul 22 2013
------------------ show module ------------------
Mod Card Type                                    Model              Serial No.
  0 ASA 5505 Adaptive Security Appliance         ASA5505
Mod MAC Address Range                 Hw Version   Fw Version   Sw Version
  0 8843.e112.085b to 8843.e112.0865  1.0          1.0(12)13    8.2(1)
Mod SSC Application Name           Status           SSC Application Version
Mod Status             Data Plane Status     Compatibility
  0 Up Sys             Not Applicable
------------------ show memory ------------------
Free memory:        84106840 bytes (31%)
Used memory:       184328616 bytes (69%)
Total memory:      268435456 bytes (100%)
------------------ show conn count ------------------
270 in use, 667 most used
------------------ show xlate count ------------------
265 in use, 726 most used
------------------ show blocks ------------------
  SIZE    MAX    LOW    CNT
     0    400    400    400
     4    100     99     99
    80    227    216    227
   256   2248   2176   2248
  1550   6889   6838   6880
  2048   1200   1186   1200
  2560    264    264    264
  4096    100    100    100
  8192    100    100    100
16384    102    102    102
65536     16     16     16
CORE  LIMIT  ALLOC   HIGH    CNT       FAILED
   0  24576     64     64     63            0
------------------ show blocks queue history detail ------------------
History buffer memory usage: 2832 bytes (default)
History analysis time limit: 100 msec
Please see 'show blocks exhaustion snapshot' for more information
------------------ show interface ------------------
Interface Internal-Data0/0 "", is up, line protocol is up
  Hardware is y88acs06, BW 1000 Mbps, DLY 10 usec
(Full-duplex), (1000 Mbps)
MAC address 8843.e112.0863, MTU not set
IP address unassigned
2291779 packets input, 1894936440 bytes, 0 no buffer
Received 84480 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 L2 decode drops, 0 demux drops
2253769 packets output, 1915790068 bytes, 0 underruns
0 late collisions, 0 deferred
0 input reset drops, 0 output reset drops, 0 tx hangs
input queue (blocks free curr/low): hardware (512/487)
output queue (blocks free curr/low): hardware (511/450)
  Control Point Interface States:
Interface number is 3
Interface config status is active
Interface state is active
Interface Internal-Data0/1 "", is up, line protocol is up
  Hardware is 88E6095, BW 1000 Mbps, DLY 10 usec
MAC address 0000.0003.0002, MTU not set
2252365 packets input, 1914625763 bytes, 0 no buffer
Received 2823 broadcasts, 0 runts, 0 giants
0 switch ingress policy drops
2290376 packets output, 1893776672 bytes, 0 underruns
0 switch egress policy drops
Interface number is 12
Interface Vlan1 "inside", is up, line protocol is up
  Hardware is EtherSVI, BW 100 Mbps, DLY 100 usec
Description: ##OutSide Interface Vlan##
MAC address 8843.e112.0863, MTU 1500
IP address 192.168.1.1, subnet mask 255.255.255.0
  Traffic Statistics for "inside":
845562 packets input, 82196340 bytes
1475860 packets output, 1788814938 bytes
1617 packets dropped
      1 minute input rate 141 pkts/sec,  21543 bytes/sec
      1 minute output rate 236 pkts/sec,  252185 bytes/sec
      1 minute drop rate, 0 pkts/sec
      5 minute input rate 118 pkts/sec,  9333 bytes/sec
      5 minute output rate 205 pkts/sec,  262609 bytes/sec
      5 minute drop rate, 0 pkts/sec
Interface number is 15
Interface Vlan2 "outside", is up, line protocol is up
IP address , subnet mask 255.255.255.0
  Traffic Statistics for "outside":
1447118 packets input, 1759508074 bytes
778743 packets output, 76591413 bytes
1966 packets dropped
      1 minute input rate 205 pkts/sec,  246766 bytes/sec
      1 minute output rate 118 pkts/sec,  20059 bytes/sec
      5 minute input rate 210 pkts/sec,  260776 bytes/sec
      5 minute output rate 109 pkts/sec,  8630 bytes/sec
Interface number is 16
Interface Vlan5 "DMZ-Escape", is down, line protocol is down
IP address 172.16.0.1, subnet mask 255.255.255.0
  Traffic Statistics for "DMZ-Escape":
99 packets input, 4656 bytes
0 packets output, 0 bytes
11 packets dropped
      1 minute input rate 0 pkts/sec,  0 bytes/sec
      1 minute output rate 0 pkts/sec,  0 bytes/sec
      5 minute input rate 0 pkts/sec,  0 bytes/sec
      5 minute output rate 0 pkts/sec,  0 bytes/sec
Interface number is 17
Interface state is not active
Interface Virtual0 "_internal_loopback", is up, line protocol is up
  Hardware is Virtual          MAC address 0000.0000.0000, MTU 1500
IP address 127.0.0.1, subnet mask 255.255.255.0
  Traffic Statistics for "_internal_loopback":
1 packets input, 28 bytes
1 packets output, 28 bytes
1 packets dropped
Interface number is 13
Interface Ethernet0/0 "", is up, line protocol is up
  Hardware is 88E6095, BW 100 Mbps, DLY 100 usec
Auto-Duplex(Full-duplex), Auto-Speed(100 Mbps)
Description: #***OutSide Internet***#
Available but not configured via nameif
MAC address 8843.e112.085b, MTU not set
1447101 packets input, 1785808195 bytes, 0 no buffer
Received 54836 broadcasts, 0 runts, 0 giants
0 L2 decode drops
9 switch ingress policy drops
778730 packets output, 94085718 bytes, 0 underruns
0 rate limit drops
Interface number is 4
Interface Ethernet0/1 "", is down, line protocol is down
Auto-Duplex, Auto-Speed
MAC address 8843.e112.085c, MTU not set
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants
0 L2 decode drops
0 packets output, 0 bytes, 0 underruns
0 rate limit drops
Interface number is 5
Interface Ethernet0/2 "", is down, line protocol is down
MAC address 8843.e112.085d, MTU not set
0 L2 decode drops
0 rate limit drops
Interface number is 6
Interface Ethernet0/3 "", is down, line protocol is down
MAC address 8843.e112.085e, MTU not set
161 packets input, 10434 bytes, 0 no buffer
Received 146 broadcasts, 0 runts, 0 giants
0 L2 decode drops
62 switch ingress policy drops
0 rate limit drops
Interface number is 7
Interface config status is not active
Interface Ethernet0/4 "", is down, line protocol is down
MAC address 8843.e112.085f, MTU not set
0 L2 decode drops
0 rate limit drops
Interface number is 8
Interface Ethernet0/5 "", is down, line protocol is down
MAC address 8843.e112.0860, MTU not set
0 L2 decode drops
0 rate limit drops
Interface number is 9
Interface Ethernet0/6 "", is down, line protocol is down
MAC address 8843.e112.0861, MTU not set
0 L2 decode drops
0 rate limit drops
Interface number is 10
Interface Ethernet0/7 "", is up, line protocol is up
MAC address 8843.e112.0862, MTU not set
860325 packets input, 102503162 bytes, 0 no buffer
Received 29672 broadcasts, 0 runts, 0 giants
0 L2 decode drops
201 switch ingress policy drops
1478771 packets output, 1819273689 bytes, 0 underruns
0 rate limit drops
Interface number is 11
------------------ show cpu usage ------------------
CPU utilization for 5 seconds = 12%; 1 minute: 17%; 5 minutes: 14%
------------------ show cpu hogging process ------------------
Process:      DHCPC Receiver, PROC_PC_TOTAL: 1, MAXHOG: 12, LASTHOG: 12
LASTHOG At:   04:24:51 UTC Jul 24 2013
PC:           80635a5 (suspend)
Process:      DHCPC Receiver, NUMHOG: 1, MAXHOG: 12, LASTHOG: 12
Traceback:    80635a5  8133d0b  9224474  9221290  921523a  9214c22  9215869
              920530c  922564a  92254c1  9214606  92050bc  812e98e  89e51b2
Process:      DHCPC Receiver, PROC_PC_TOTAL: 1, MAXHOG: 110, LASTHOG: 110
LASTHOG At:   04:24:52 UTC Jul 24 2013
PC:           8c09598 (suspend)
Process:      DHCPC Receiver, NUMHOG: 1, MAXHOG: 110, LASTHOG: 110
Traceback:    81cae91  8062413
Process:      Dispatch Unit, PROC_PC_TOTAL: 1, MAXHOG: 162, LASTHOG: 162
LASTHOG At:   04:27:26 UTC Jul 24 2013
PC:           81aa5f9 (suspend)
Process:      Dispatch Unit, NUMHOG: 1, MAXHOG: 162, LASTHOG: 162
Traceback:    81aa5f9  8062413
Process:      logger_save, NUMHOG: 388, MAXHOG: 11, LASTHOG: 11
LASTHOG At:   04:45:38 UTC Jul 24 2013
PC:           8475536 (suspend)
Traceback:    8475536  80cff3f  80d0ccd  8bcbb81  8bcbf70  8062413
Process:      logger_save, PROC_PC_TOTAL: 769, MAXHOG: 45, LASTHOG: 43
Process:      logger_save, NUMHOG: 364, MAXHOG: 45, LASTHOG: 43
Traceback:    8475536  80cff3f  80d01b1  80d0dc4  8bcbb81  8bcbf70  8062413
Process:      ssh, NUMHOG: 4, MAXHOG: 24, LASTHOG: 10
LASTHOG At:   06:19:45 UTC Jul 24 2013
PC:           8b9ac8c (suspend)
Traceback:    8b9ac8c  8ba9616  8b9f385  8b9f51f  8b9f653  8870cb4  9298bf1
              8056edb  8057500  8057908  8879ac6  887b1aa  80c1a60  80c2da6
Process:      ssh, NUMHOG: 1, MAXHOG: 10, LASTHOG: 10
LASTHOG At:   06:19:52 UTC Jul 24 2013
PC:           8870ba5 (suspend)
Traceback:    8870ba5  9298bf1  852fd7b  89896a8  89897ad  8878a6f  8871c20
              8948384  8948441  8871a97  8978a9b  88aa112  8879ac6  887b1aa
Process:      ssh_init, PROC_PC_TOTAL: 9, MAXHOG: 24, LASTHOG: 14
LASTHOG At:   06:20:33 UTC Jul 24 2013
Process:      ssh_init, NUMHOG: 5, MAXHOG: 15, LASTHOG: 14
Traceback:    8b9ac8c  8ba77ed  8ba573e  8ba58e8  8ba6971  8ba02b4  8062413
Process:      ssh, PROC_PC_TOTAL: 3, MAXHOG: 75, LASTHOG: 75
LASTHOG At:   06:20:42 UTC Jul 24 2013
Process:      ssh, NUMHOG: 2, MAXHOG: 75, LASTHOG: 75
Traceback:    8870ba5  9298bf1  89784ad  88aa112  8879ac6  887b1aa  80c1a60
              80c2da6  80c397a  8062413
CPU hog threshold (msec): 10.240
Last cleared: None
------------------ show process ------------------
    PC       SP       STATE       Runtime    SBASE     Stack Process
Lwe 08054f3c d529a554 09e32ed4          0 d5298650 7544/8192 block_diag
Mrd 081aa324 d52c9e24 09e32464     142483 d52a9fe0 123228/131072 Dispatch Unit
Msi 08e7b7d5 d577a73c 09e31bac         42 d5778838 7792/8192 y88acs06 OneSec Thread
Mwe 08068755 d577eb3c 09e31bac          0 d577cc98 7692/8192 Reload Control Thread
Mwe 080705a6 d5789ac4 09e347f8          1 d5785f10 12704/16384 aaa
Mwe 080a0f36 d5792b2c 09e34854          0 d578ec38 15712/16384 CMGR Server Process
Mwe 080a1445 d5794c54 09e31bac          0 d5792dc0 7760/8192 CMGR Timer Process
Lwe 081a974c d579d2e4 09e439c8          0 d579b3e0 7376/8192 dbgtrace
Mwe 084612e5 d57a58d4 09e31bac        111 d57a3b50 4712/8192 eswilp_svi_init
Mwe 08c2bb4d d59c117c 09e31bac          0 d57bd3d0 7016/8192 netfs_thread_init
Mwe 09250e05 d57cb9c4 09e31bac          0 d57c9b70 7612/8192 Chunk Manager
Msi 088b480e d57ce174 09e31bac         58 d57cc290 7560/8192 PIX Garbage Collector
Mwe 088a7cb4 d57d7e94 09d3e46c          0 d57d5f90 7904/8192 IP Address Assign
Mwe 08a6e896 d596a934 09d81f78          0 d5968a30 7904/8192 QoS Support Module
Mwe 0892250f d596cafc 09d3f490          0 d596abf8 7904/8192 Client Update Task
Lwe 0929b50a d596f42c 09e31bac       1371 d596d598 7696/8192 Checkheaps
Mwe 08a72385 d5977894 09e31bac        582 d5973c20 8256/16384 Quack process
Mwe 08ac8b02 d597fc1c 09e31bac          5 d5977da8 31888/32768 Session Manager
Mwe 08bd8745 d5985b0c d7c5f850          6 d59820b8 14520/16384 uauth
Mwe 08b790c5 d5988144 09d8ed80          0 d5986240 7376/8192 Uauth_Proxy
Msp 08bb00a5 d598e5dc 09e31bac          1 d598c6d8 7512/8192 SSL
Mwe 08bd6bb6 d5990744 09d94924          0 d598e860 7480/8192 SMTP
Mwe 08bd08d6 d59928cc 09d94898       1628 d59909e8 2952/8192 Logger
Mwe 08bcb21e d5994a04 09e31bac          0 d5992b70 7344/8192 Thread Logger
Mwe 08db9d42 d59a350c 09dc84e8          0 d59a1628 7040/8192 vpnlb_thread
Mwe 082728ad d59aabd4 09e31bac          0 d59a8d50 7660/8192 TLS Proxy Inspector
Msi 08ae2313 d5a33234 09e31bac         31 d5a31330 7792/8192 emweb/cifs_timer
Mwe 086862e7 d5a75d14 09d35414          0 d5a73e20 7432/8192 netfs_mount_handler
Msi 0851d148 d57c98bc 09e31bac        292 d57c79e8 7168/8192 arp_timer
Mwe 085269dc d56f7f84 09e58288          0 d56f60d0 7824/8192 arp_forward_thread
Mwe 085938a5 d615b7cc 09e5d080          0 d6159948 7808/8192 Lic TMR
Mwe 08bdbce1 d615d86c 09d94ba0          0 d615b978 7776/8192 tcp_fast
Mwe 08bdeec0 d615f88c 09d94ba0          0 d615d9a8 7760/8192 tcp_slow
Mwe 08c094e9 d616dd8c 09d9cb08          0 d616be98 7872/8192 udp_timer
Mwe 080fd2a8 d57c1494 09e31bac          0 d57bf600 7760/8192 CTCP Timer process
Mwe 08d69913 d57c34a4 09e31bac          0 d57c1630 7728/8192 L2TP data daemon
Mwe 08d6a6e3 d57c54e4 09e31bac          0 d57c3660 7744/8192 L2TP mgmt daemon
Mwe 08d56a28 d6aef50c 09dc2384          7 d6aeb658 16028/16384 ppp_timer_thread
Msi 08dba1f7 d6af160c 09e31bac         42 d6aef738 7744/8192 vpnlb_timer_thread
Mwe 081165e7 d6b249a4 d5798cb0          3 d6b20b00 15656/16384 IPsec message handler
Msi 0812772c d598a27c 09e31bac        632 d59883c8 7336/8192 CTM message handler
Mwe 08980d99 d579b0ac 09e31bac          0 d5799248 7628/8192 NAT security-level reconfiguration
Mwe 08a9d7c8 d6b92794 09e31bac          0 d6b908f0 7776/8192 ICMP event handler
Mwe 08d2ab0f d6b97f0c 09e31bac          0 d6b96078 7760/8192 Dynamic Filter VC Housekeeper
Mwe 0880c023 d6b9c0fc 09e31bac          5 d6b98258 12492/16384 IP Background
Mwe 081928c6 d6c036cc 09cd2688        129 d6be3888 121096/131072 tmatch compile thread
Mwe 089ad9f5 d7d2dc9c 09e31bac          0 d7d29de8 15900/16384 Crypto PKI RECV
Mwe 089b061a d7d31cac 09e31bac          0 d7d2de18 15868/16384 Crypto CA
Mwe 085c0e7d d5998d04 09e31bac         34 d5996e80 6976/8192 ESW_MRVL switch interrupt service
Mwe 08a1f8b0 d59a5694 09d4e630          0 d59a37b0 7776/8192 lina_int
Msi 085b982c d598c35c 09e31bac     313592 d598a528 5460/8192 esw_stats
Lsi 088c5408 d7d75a04 09e31bac          0 d7d73af0 7808/8192 uauth_urlb clean
Lwe 088adc1f d7d97a44 09e31bac         42 d7d95bd0 5288/8192 pm_timer_thread
Mwe 084aea45 d7d99a94 09e31bac        140 d7d97c00 7696/8192 IKE Timekeeper
Mwe 084a243b d7d9eea4 09d2f794         60 d7d9b2d0 13000/16384 IKE Daemon
Mwe 08b8cb3a d7da297c 09d93494          0 d7da0a98 7872/8192 RADIUS Proxy Event Daemon
Mwe 08b5a75b d7da486c d7e0feb8          0 d7da2ac8 6904/8192 RADIUS Proxy Listener
Mwe 08b8b737 d7da698c 09e31bac          0 d7da4af8 7760/8192 RADIUS Proxy Time Keeper
Mwe 0850dfcc d7da96ac 09e58208          0 d7da7868 7024/8192 Integrity FW Task
Mwe 081c041b d7e34754 098461dc          1 d7e14f50 124980/131072 ci/console
Msi 088e580c d7e36fec 09e31bac        796 d7e350d8 6728/8192 update_cpu_usage
Msi 088e09fa d7e41274 09e31bac          0 d7e3f450 3932/8192 NIC status poll
Mwe 08b13e4b d57bafb4 09d86804      43331 d57b90c0 2888/8192 SNMP Notify Thread
Mwe 08518606 d7e84e6c 09e58954       1316 d7e7cf98 28712/32768 IP Thread
Mwe 0851ef5e d7e87014 09e58308       8433 d7e85120 3000/8192 ARP Thread
Mwe 08440ba0 d7e8922c 09e58940       1330 d7e873d8 4632/8192 icmp_thread
Mwe 08c0a3f6 d7e8b3f4 09e31bac        209 d7e89560 7512/8192 udp_thread
Mwe 08be0f2c d7e8d43c 09e5895c          0 d7e8b6e8 7472/8192 tcp_thread
Mwe 08bea703 d7e8f704 09e31bac          0 d7e8d870 7324/8192 npshim_thread
Mwe 08c2bb4d d7f0f24c 09e31bac        297 d7e928a0 24816/32768 rtcli async executor process
Mwe 081c8cd1 d81cd2fc 09e31bac          2 d81cb458 6988/8192 DHCPD Timer
Mwe 081dc1d0 d81d261c 09e31bac          1 d81d0798 3512/8192 DHCP Client
Mwe 08c09598 d81da6ac d616bbb4       4041 d81d2878 26508/32768 DHCPC Receiver
Mwe 08b5a75b d81e6a34 d81c7e88          0 d81e4c80 7288/8192 EAPoUDP-sock
Mwe 081e6615 d81e8814 09e31bac          0 d81e6cb0 6860/8192 EAPoUDP
Lwe 08bcbfd2 d8246504 09d94890      56966 d82445f0  660/8192 logger_save
Mwe 0821c013 d858eecc 09e31bac         13 d858b438 10120/16384 emweb/https
Mwe 082129f6 d8591ddc 09e31bac          2 d858ff38 7544/8192 Timekeeper
Mwe 08c2bb4d d86d9b8c 09e31bac         63 d8608550 6696/8192 Unicorn Proxy Thread
Mwe 08c09598 d8a7e8ec d616b734      14106 d8a7ccd8 3212/8192 snmp
Mwe 08b5a75b d8b31244 d8b1dcd8          0 d8b2f4a0 7272/8192 IKE Receiver
Mwe 08beb814 d8b371fc d8b35510          0 d8b35548 7312/8192 listen/telnet
Mwe 08beb814 d8b3a024 d822f528          0 d8b38370 6892/8192 listen/ssh
Mwe 081ca8be d8b3fd44 09e31bac         19 d8b3bf00 9176/16384 dhcp_daemon
Mwe 08d9a10d d8ce20a4 09dc8210          0 d8cda1b0 32464/32768 vpnfol_thread_msg
Msi 08da0742 d8ce40c4 09e31bac         29 d8ce21e0 7760/8192 vpnfol_thread_timer
Mwe 08d9ea12 d8ce6664 09dc8380          0 d8ce47d0 7792/8192 vpnfol_thread_sync
Msi 08da02cc d8ce8d0c 09e31bac        143 d8ce6e18 7776/8192 vpnfol_thread_unsent
Mwe 0850a318 d59a77cc 09e31bac          0 d59a5938 7760/8192 Integrity Fw Timer Thread
Lwe 08914412 d7e3b644 09e31bac          0 d7e397d0 7664/8192 vPif_stats_cleaner
Msi 086863cc d7e45644 09e31bac          2 d7e43760 7756/8192 netfs_vnode_reclaim
Mwe 088941dd da954a1c d8231aec        151 da94de58 25992/32768 Unicorn Admin Handler
Mwe 08893791 da95cc1c 09e31bac       1983 da955e88 21084/32768 Unicorn Admin Handler
Mwe 08a44459 da885abc 09f495e0          5 da883bf8 7760/8192 qos_metric_daemon
Mwe 08ba114b da95fd4c 09e31bac          0 da95deb8 5916/8192 ssh/timer
Mwe 08beab4b da991704 da831760       2420 da98a400 21980/32768 ssh
M*  08b9ac8c d27eef48 09e32464        998 da963e50 21980/32768 ssh
-      -        -         -             0    -         -     DATAPATH-0-185
-     -        -         -       6487820    -         -     scheduler
-     -        -         -       7119800    -         -     total elapsed
------------------ show kernel process ------------------
PID PPID PRI NI      VSIZE      RSS      WCHAN STAT  RUNTIME COMMAND
  1    0  17  0    1544192      508 3725685523    S     2579 init
  2    1  34 19          0        0 3725694925    S       21 ksoftirqd/0
  3    1  10 -5          0        0 3725737663    S        0 events/0
  4    1  15 -5          0        0 3725737663    S        0 khelper
  5    1  20 -5          0        0 3725737663    S        0 kthread
  7    5  10 -5          0        0 3725737663    S        0 kblockd/0
  8    5  20 -5          0        0 3726737422    S        0 kseriod
46    5  20  0          0        0 3725813080    S        0 pdflush
47    5  15  0          0        0 3725813080    S        0 pdflush
48    1  25  0          0        0 3725825763    S        0 kswapd0
49    5  20 -5          0        0 3725737663    S        0 aio/0
144    1  17  0    1544192      108 3725685523    S        0 init
145  144  18  0    1544192      472 3725685523    S        0 rcS
177  145  16  0   10076160      452 3725713492    S        0 lina_monitor
178  177  15  0   10076160      452          0    S        0 lina_monitor
179  178  15  0   10076160      452 3726344008    S        0 lina_monitor
180  177   5 -20  218468352   174576 3725716908    S      756 lina
181  180   0 -20  218468352   174576          0    S        0 lina
182  181   0 -20  218468352   174576          0    S        0 lina
183  181   0 -20  218468352   174576 3725716908    S       28 lina
184  181   5 -20  218468352   174576          0    S        0 lina
185  181   5 -20  218468352   174576          0    R   709070 lina
------------------ show traffic ------------------
inside:
received (in 7090.240 secs):
850232 packets          82482096 bytes
119 pkts/sec          11027 bytes/sec
transmitted (in 7090.240 secs):
1483672 packets          1798206419 bytes
209 pkts/sec          253011 bytes/sec
      1 minute input rate 120 pkts/sec,  9893 bytes/sec
      1 minute output rate 201 pkts/sec,  243366 bytes/sec
outside:
received (in 7092.220 secs):
1454331 packets          1768710450 bytes
205 pkts/sec          249387 bytes/sec
transmitted (in 7092.220 secs):
782737 packets          76823524 bytes
110 pkts/sec          10226 bytes/sec
      1 minute input rate 188 pkts/sec,  239935 bytes/sec
      1 minute output rate 105 pkts/sec,  8830 bytes/sec
DMZ-Escape:
received (in 7094.220 secs):
99 packets          4656 bytes
0 pkts/sec          0 bytes/sec
transmitted (in 7094.220 secs):
0 packets          0 bytes
_internal_loopback:
received (in 7094.240 secs):
1 packets          28 bytes
transmitted (in 7094.240 secs):
1 packets          28 bytes
Aggregated Traffic on Physical Interface
Ethernet0/0:
received (in 7096.270 secs):
1454946 packets          1795970460 bytes
205 pkts/sec          253086 bytes/sec
transmitted (in 7096.270 secs):
783076 packets          94435010 bytes
110 pkts/sec          13307 bytes/sec
      1 minute input rate 201 pkts/sec,  259904 bytes/sec
      1 minute output rate 112 pkts/sec,  12295 bytes/sec
      5 minute input rate 214 pkts/sec,  268181 bytes/sec
      5 minute output rate 111 pkts/sec,  11306 bytes/sec
Ethernet0/1:
received (in 7096.290 secs):
0 packets          0 bytes
transmitted (in 7096.290 secs):
0 packets          0 bytes
Ethernet0/2:
received (in 7098.330 secs):
0 packets          0 bytes
transmitted (in 7098.330 secs):
0 packets          0 bytes
Ethernet0/3:
received (in 7098.350 secs):
161 packets          10434 bytes
0 pkts/sec          1 bytes/sec
transmitted (in 7098.350 secs):
0 packets          0 bytes
Ethernet0/4:
received (in 7100.270 secs):
0 packets          0 bytes
transmitted (in 7100.270 secs):
0 packets          0 bytes
Ethernet0/5:
received (in 7100.290 secs):
0 packets          0 bytes
transmitted (in 7100.290 secs):
0 packets          0 bytes
Ethernet0/6:
received (in 7102.280 secs):
0 packets          0 bytes
transmitted (in 7102.280 secs):
0 packets          0 bytes
Ethernet0/7:
received (in 7104.280 secs):
864560 packets          102845220 bytes
121 pkts/sec          14476 bytes/sec
transmitted (in 7104.280 secs):
1485861 packets          1827991653 bytes
209 pkts/sec          257308 bytes/sec
      1 minute input rate 128 pkts/sec,  13820 bytes/sec
      1 minute output rate 212 pkts/sec,  261779 bytes/sec
      5 minute input rate 120 pkts/sec,  12300 bytes/sec
      5 minute output rate 207 pkts/sec,  269487 bytes/sec
Internal-Data0/0:
received (in 7104.300 secs):
2308546 packets          1908842810 bytes
324 pkts/sec          268083 bytes/sec
transmitted (in 7104.300 secs):
2270483 packets          1929825088 bytes
319 pkts/sec          271037 bytes/sec
      1 minute input rate 308 pkts/sec,  257235 bytes/sec
      1 minute output rate 306 pkts/sec,  259146 bytes/sec
      5 minute input rate 329 pkts/sec,  277953 bytes/sec
      5 minute output rate 314 pkts/sec,  278374 bytes/sec
Internal-Data0/1:
received (in 7106.290 secs):
2269416 packets          1928890138 bytes
319 pkts/sec          271434 bytes/sec
transmitted (in 7106.290 secs):
2307490 packets          1907919943 bytes
324 pkts/sec          268483 bytes/sec
      1 minute input rate 324 pkts/sec,  275067 bytes/sec
      1 minute output rate 327 pkts/sec,  273272 bytes/sec
      5 minute input rate 318 pkts/sec,  282052 bytes/sec
      5 minute output rate 334 pkts/sec,  281688 bytes/sec
------------------ show perfmon ------------------
PERFMON STATS:                     Current      Average
Xlates                                1/s          2/s
Connections                           9/s          6/s
TCP Conns                             0/s          1/s
UDP Conns                             2/s          1/s
URL Access                            0/s          0/s
URL Server Req                        0/s          0/s
TCP Fixup                           195/s        246/s
TCP Intercept Established Conns       0/s          0/s
TCP Intercept Attempts                0/s          0/s
TCP Embryonic Conns Timeout           0/s          0/s
HTTP Fixup                          195/s        246/s
FTP Fixup                             0/s          0/s
AAA Authen                            0/s          0/s
AAA Author                            0/s          0/s
AAA Account                           0/s          0/s
VALID CONNS RATE in TCP INTERCEPT:    Current      Average
                                       N/A         100.00%
------------------ show counters ------------------
Protocol     Counter                             Value   Context
IP           IN_PKTS                            126664   Summary
IP           OUT_PKTS                            76183   Summary
IP           IN_DROP_NFU                            36   Summary
IP           OUT_DROP_DWN                           26   Summary
IP           TO_ARP                              81363   Summary
IP           TO_UDP                              24101   Summary
IP           TO_ICMP                             21164   Summary
UDP          IN_PKTS                             24101   Summary
UDP          OUT_PKTS                            89377   Summary
UDP          DROP_NO_APP                          8981   Summary
ICMP         IN_PKTS                             21164   Summary
ICMP         OUT_PKTS                            21158   Summary
SSLERR       BAD_PROTOCOL_VERSION_NUMBER             1   Summary
SSLERR       BAD_SIGNATURE                           2   Summary
SSLALERT     RX_CLOSE_NOTIFY                         5   Summary
SSLALERT     RX_WARNING_ALERT                        5   Summary
SSLALERT     TX_CLOSE_NOTIFY                        79   Summary
SSLALERT     TX_WARNING_ALERT                       79   Summary
SSLDEV       NEW_CTX                                 1   Summary
SSLNP        OPEN_CONN                               1   Summary
SSLNP        HANDSHAKE_START                        81   Summary
SSLNP        HANDSHAKE_DONE                         81   Summary
SSLNP        DOWNSTREAM_CLOSE                      133   Summary
SSLNP        DOWNSTREAM_CLOSE_NEXT                  79   Summary
SSLNP        UPSTREAM_CLOSE                         84   Summary
SSLNP        UPSTREAM_CLOSE_NEXT                    79   Summary
SSLNP        FREE_CONN                              79   Summary
SSLNP        NEW_CONN_SERVER                        81   Summary
SSLNP        IN_PKTS_RX                            385   Summary
SSLNP        IN_PKTS_TX                            131   Summary
SSLNP        OUT_PKTS_RX                          9068   Summary
SSLNP        OUT_PKTS_TX                          9229   Summary
SSLNP        SESSIONS_CLEARED                        1   Summary
EmWeb        IN_PKTS                                 1   Summary
EmWeb        OUT_PKTS                                7   Summary
NPSHIM       READ_CTX_CLOSED                         2   Summary
NPSHIM       READ_NOBLOCK_NO_BUF                 12804   Summary
NPSHIM       READ_RECV                             521   Summary
NPSHIM       READ_EOF                                1   Summary
NPSHIM       SLCT_REQUEST                            7   Summary
NPSHIM       SLCT_EVENT                              5   Summary
NPSHIM       CTX_ALLOC                              85   Summary
NPSHIM       CTX_FREE                               77   Summary
VPIF         BAD_VALUE                             798   Summary
VPIF         NOT_FOUND                           27996   Summary
------------------ show history ------------------
  enable 15
  terminal width 0
  terminal length 0
  sh tech
------------------ show firewall ------------------
Firewall mode: Router
------------------ show running-config ------------------
: Saved
ASA Version 8.2(1)
hostname EscapeASA
enable password
passwd
names
interface Vlan1
description ##OutSide Interface Vlan##
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan5
no forward interface Vlan1
nameif DMZ-Escape
security-level 50
ip address 172.16.0.1 255.255.255.0
interface Ethernet0/0
description #***OutSide Internet***#
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
switchport access vlan 5
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
banner exec
boot system disk0:/asa821-k8.bin
boot system disk0:/Asa821-k8.bin
ftp mode passive
object-group service RDP tcp
port-object eq 3389
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group service CCTV tcp-udp
port-object eq 9000
object-group service 8080Web tcp-udp
port-object eq 8080
object-group service LEM9000 tcp
port-object eq 9000
access-list inside_access_in extended permit ip any any
access-list inside_access_in_1 extended permit icmp any any log disable
access-list inside_access_in_1 extended permit ip any any log disable
access-list outside_access_in extended permit icmp any any log disable
access-list outside_access_in extended permit tcp any interface outside object-group RDP log disable
access-list outside_access_in extended permit tcp any interface outside eq ftp-data
access-list outside_access_in extended permit object-group TCPUDP any interface outside eq www
access-list outside_access_in extended permit tcp any interface outside eq 4054
access-list outside_access_in extended permit udp any interface outside object-group CCTV inactive
access-list outside_access_in extended permit tcp any interface outside eq https log disable
access-list outside_access_in extended permit object-group TCPUDP any interface outside object-group 8080Web log disable
access-list outside_access_in extended permit tcp any interface outside eq pop3 log disable
access-list outside_access_in extended permit tcp any interface outside eq smtp
access-list 100 extended permit tcp any any eq www
access-list 100 extended permit tcp any any eq 3389
access-list 100 extended permit tcp any any eq ftp
access-list 100 extended permit tcp any any eq ftp-data
access-list 100 extended permit tcp any any eq smtp
access-list 100 extended permit tcp any any eq 8080
access-list 100 extended permit tcp any any eq https
access-list global_mpc extended permit ip any any
access-list UsmanTVPNGroup_splitTunnelAcl standard permit 192.168.1.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 192.168.168.0 255.255.255.248
pager lines 24
logging enable
logging host inside 192.168.1.222
logging host inside 192.168.1.28
logging host inside 192.168.1.202
logging host inside 192.168.1.46
logging debug-trace
logging flash-bufferwrap
logging class auth buffered emergencies history debugging monitor debugging mail emergencies asdm debugging
no logging message 106015
no logging message 313001
no logging message 313008
no logging message 106023
no logging message 710003
no logging message 106100
no logging message 101001
no logging message 100000
no logging message 302015
no logging message 302014
no logging message 302013
no logging message 302018
no logging message 302017
no logging message 302016
no logging message 302021
no logging message 302020
flow-export destination inside 192.168.1.80 2055
flow-export destination inside 192.168.1.222 2055
flow-export template timeout-rate 1
flow-export delay flow-create 15
mtu inside 1500
mtu outside 1500
mtu DMZ-Escape 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
asdm image disk0:/asdm-625.bin
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 192.168.1.0 255.255.255.0
nat (inside) 1 0.0.0.0 0.0.0.0
access-group inside_access_in in interface inside control-plane
access-group inside_access_in_1 in interface inside
access-group outside_access_in in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
aaa authentication telnet console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
snmp-server group Authentication&Encryption v3 priv
snmp-server user solarwinds Authentication&Encryption v3 encrypted auth md5 bf:31:cd:3b:65:da:4e:32:b3:5c:df:0b:34:b5:cf:f0 priv des bf:31:cd:3b:65:da:4e:32:b3:5c:df:0b:34:b5:cf:f0
snmp-server enable traps snmp authentication linkup linkdown coldstart
snmp-server enable traps syslog
snmp-server enable traps ipsec start stop
snmp-server enable traps entity config-change fru-insert fru-remove
snmp-server enable traps remote-access session-threshold-exceeded
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto ca trustpoint ASDM_TrustPoint0
enrollment terminal
subject-name CN=EscapeASA
crl configure
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
tunnel-group UsmanTVPNGroup type remote-access
tunnel-group UsmanTVPNGroup general-attributes
address-pool VPNPool
default-group-policy UsmanTVPNGroup
tunnel-group UsmanTVPNGroup ipsec-attributes
pre-shared-key *
class-map global-class
match access-list global_mpc
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
description Netflow_Export_Policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect esmtp
  inspect xdmcp
  inspect netbios
  inspect tftp
  inspect http
class global-class
  flow-export event-type all destination 192.168.1.80 192.168.1.222
service-policy global_policy global
smtp-server 192.168.1.13
prompt hostname context
Cryptochecksum:00b6cd89d8ee34eb02985530e58b3e88
: end
------------------ show startup-config errors ------------------
WARNING: BOOT variable added, but unable to find disk0:/asa821-k8.bin
*** Output from config line 49, "boot system disk0:/asa82..."
WARNING: Enabling the logging flash-bufferwrap feature could cause a
         depletion of all available memory under high syslog
         rates. Please adjust your buffered logging level
         appropriately
*** Output from config line 102, "logging flash-bufferwrap"
------------------ console logs ------------------
Message #1 : Message #2 :
Total SSMs found: 0
Message #3 :
Total NICs found: 10
Message #4 : 88E6095 rev 2 Gigabit Ethernet @ index 09Message #5 :  MAC: 0000.0003.0002
Message #6 : 88E6095 rev 2 Ethernet @ index 08Message #7 :  MAC: 8843.e112.0862
Message #8 : 88E6095 rev 2 Ethernet @ index 07Message #9 :  MAC: 8843.e112.0861
Message #10 : 88E6095 rev 2 Ethernet @ index 06Message #11 :  MAC: 8843.e112.0860
Message #12 : 88E6095 rev 2 Ethernet @ index 05Message #13 :  MAC: 8843.e112.085f
Message #14 : 88E6095 rev 2 Ethernet @ index 04Message #15 :  MAC: 8843.e112.085e
Message #16 : 88E6095 rev 2 Ethernet @ index 03Message #17 :  MAC: 8843.e112.085d
Message #18 : 88E6095 rev 2 Ethernet @ index 02Message #19 :  MAC: 8843.e112.085c
Message #20 : 88E6095 rev 2 Ethernet @ index 01Message #21 :  MAC: 8843.e112.085b
Message #22 : y88acs06 rev16 Gigabit Ethernet @ index 00 MAC: 8843.e112.0863
Message #23 :
Message #24 : Maximum Physical Interfaces  : 8
Message #25 : VLANs                        : 3, DMZ Restricted
Message #26 : Inside Hosts                 : 50
Message #27 : Failover                     : Disabled
Message #28 : VPN-DES                      : Enabled
Message #29 : VPN-3DES-AES                 : Enabled
Message #30 : SSL VPN Peers                : 2
Message #31 : Total VPN Peers              : 10
Message #32 : Dual ISPs                    : Disabled
Message #33 : VLAN Trunk Ports             : 0
Message #34 : Shared License               : Disabled
Message #35 : AnyConnect for Mobile        : Disabled
Message #36 : AnyConnect for Linksys phone : Disabled
Message #37 : AnyConnect Essentials        : Disabled
Message #38 : Advanced Endpoint Assessment : Disabled
Message #39 : UC Phone Proxy Sessions      : 2
Message #40 : Total UC Proxy Sessions      : 2
Message #41 : Botnet Traffic Filter        : Disabled
Message #42 :
Message #43 :
Message #44 : Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
Message #45 :                              Boot microcode   :  CN1000-MC-BOOT-2.00
Message #46 :                              SSL/IKE microcode:  CNLite-MC-SSLm-PLUS-2.03
Message #47 :                              IPSec microcode  :  CNlite-MC-IPSECm-MAIN-2.04
Message #48 :
Message #49 :
Message #50 :   ****************************** Warning *******************************
Message #51 :   This product contains cryptographic features and is
Message #52 :   subject to United States and local country laws
Message #53 :   governing, import, export, transfer, and use.
Message #54 :   Delivery of Cisco cryptographic products does not
Message #55 :   imply third-party authority to import, export,
Message #56 :   distribute, or use encryption. Importers, exporters,
Message #57 :   distributors and users are responsible for compliance
Message #58 :   with U.S. and local country laws. By using this
Message #59 :   product you agree to comply with applicable laws and
Message #60 :   regulations. If you are unable to comply with U.S.
Message #61 :   and local laws, return the enclosed items immediately.
Message #62 :
Message #63 :   A summary of U.S. laws governing Cisco cryptographic
Message #64 :   products may be found at:
Message #65 :   http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
Message #66 :
Message #67 :   If you require further assistance please contact us by
Message #68 :   sending email to [email protected].
Message #69 :   ******************************* Warning *******************************
Message #70 :
Message #71 : Copyright (c) 1996-2009 by Cisco Systems, Inc.
Message #72 :                 Restricted Rights Legend
Message #73 : Use, duplication, or disclosure by the Government is
Message #74 : subject to restrictions as set forth in subparagraph
Message #75 : (c) of the Commercial Computer Software - Restricted
Message #76 : Rights clause at FAR sec. 52.227-19 and subparagraph
Message #77 : (c) (1) (ii) of the Rights in Technical Data and Computer
Message #78 : Software clause at DFARS sec. 252.227-7013.
Message #79 :                 Cisco Systems, Inc.
Message #80 :                 170 West Tasman Drive
Message #81 :                 San Jose, California 95134-1706
Correct Answer
Favaloro. Wed, 07/24/2013 - 10:31
Here ya go.
http://jgit.ca/2d
Also, the problem seems to be related to logging, so, let's turn it off until the upgrade happens with a:
"no logging enable"
Haider Malik Thu, 07/25/2013 - 03:06
Thank you for all the help , I completly agreed i have already turned off all the logging including syslog / Traps / Rules . since then i have not seen any reboot yet . here is last reboot log
7/24/2013 3:58 PM                    EscapeASA rebooted at 24/07/2013 15:57:00
I was thinking may be i have overheated the device to send Syslogs / Traps to 3 destinations which might be causing the issue to handle sending large number of syslog / Traps to multiple destinations . also i have turned on all type of logging on the device . + Netflow turned for 2 destinations which is now disabled for one destination . I dont want to jump to any conclusion on this stage however so far so good the device is running as normally however i will test the device again putting the syslog / traps load back to confirm the root cause of the issue and update back.
Thank you for all the help .
Haider Malik Thu, 07/25/2013 - 11:15
Wanted to say Thanks to
Favaloro.
pointed me to correct direction and helped me to identify the root cause .
