887VA IPSEC Site to Site VPN (887VA to 877)
leebridgewater
I've been trying for the pas 8 hours to connect a new Cisco 887VA K9 VDSL router to an existing site to site VPN (The original 877 failed).
I simply cannot get the router to connect to the site to site VPN, I tried TFTP'ing the original config from the failed 877 but that didn't work.
Here is the outline of the network where this 887 will reside:
LAN IP address of the Cisco router is 192.168.10.254
LAN IP of the DHCP server on the LAN is 192.168.10.1
Client computers use the LAN with the subnet of 192.168.10.0 / 24 the DHCP server is a DC.
The client computers use an RDP session on the head office network using IP 192.168.1.5, the subnet of the remote network is 192.168.1.0 /24
Here is the config I have written so far on the new 887VA, I have internet access but no IPSEC Site to Site VPN.
=====[ start 887VA config ] ======
887VA#sh run
Building configuration...
Current configuration : 2476 bytes
! Last configuration change at 18:45:34 UTC Tue Jul 23 2013
! NVRAM config last updated at 17:50:28 UTC Tue Jul 23 2013
version 15.1
no service pad
hostname 887VA
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip source-route
ip cef
no ipv6 cef
license udi pid CISCO887VA-K9 sn XXXXXXXXXX
controller VDSL 0
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key cisco address XX.XXX.XXX.XXX
crypto ipsec transform-set tr-aes-sha esp-aes esp-sha-hmac
crypto ipsec transform-set tr-3des-sha esp-3des esp-sha-hmac
crypto map CMAP 10 ipsec-isakmp
set peer XX.XXX.XXX.XXX
set transform-set tr-3des-sha
match address NAT
crypto map cmap 10 ipsec-isakmp
! Incomplete
set transform-set tr-aes-sha
interface Ethernet0
no ip address
shutdown
no fair-queue
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly in
atm ilmi-keepalive
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
description LAN
ip address 192.168.10.254 255.255.255.0
ip nat inside
interface Dialer0
no ip address
interface Dialer1
description Interface for ADSL/VDSL
mtu 1492
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
ppp authentication pap chap ms-chap callin
ppp chap hostname businesshub@btbroadband.com
ppp chap password 0 bt
ppp ipcp address accept
no cdp enable
crypto map CMAP
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list NAT interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended NAT
permit ip 192.168.10.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line vty 0 4
login
transport input all
end
887VA#
=====[ end config ] =========
I'm usure as to what transform set I'm using at the peer, the peer is an 877 and I've got the following in the config on that device with
relation to transform set:
====[ Beging Peer config snippet ] =====
crypto ipsec transform-set tr-null-sha esp-null esp-sha-hmac
crypto ipsec transform-set tr-des-md5 esp-des esp-md5-hmac
crypto ipsec transform-set tr-3des-md5 esp-3des esp-md5-hmac
====[ end Peer config snippet ] =====
I'm desperate to get this sorted, I can't use SDM on the 887VA as it appears it's not supported : (
Any help and assistance would be appreciated, please let me know if you require any further info.
Many thanks in anticipation
Lee
0 Replies 0
