Warning message
Switch model advice
Answered Question
Jul 23rd, 2013
I have a Cisco 5520 firewall that I want to VLAN connect to a WLC and 5 AP's so I can separate into a inside corporate network and a guest network that will just have access to the Internet. I need a good PoE and layer 3 switch? Any recommenations? I will be connecting the switch and firewall via Gigabit Ethernet cable as I have no fiber module on the ASA.
Thank you
Carlos
Correct Answer by Reza Sharifi about 4 years 3 weeks ago
You can use a 3560X.  Usually 3560 is cheaper then 3750X if you don't need stacking.
Have a look:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/data_sheet_c78-584733.html
Overall Rating: 5 (1 ratings)
AQUALUNGAMERICA Wed, 07/24/2013 - 10:08
Reza,
         Thank you for the advice on the 3560. We are good to go here and are proceeding with the purchase and implementation.
Carlos
Leo Laohoo Wed, 07/24/2013 - 16:11
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
5 ports only?
Try an 8-port switch.  Do you want PoE or not, you can use the compact (fanless) switch here.
