7600 - 800Mbps Unsupported shaping rate
Jul 23rd, 2013
Dear all,
I'm running IOS 15.2(4)S1 on a 7609S. Configuring in the lab an egress policy for a service instance associated to a pseudowire on a ES+ card, I tried to apply the following QoS egress policy:
policy-map ChildPolicy_CustomerEgress_800Mbps
class Class_CustomerEgress
  shape average 800000000
policy-map Policy_CustomerEgress_800Mbps
class class-default
  shape average 10000000000
   service-policy ChildPolicy_CustomerEgress_800Mbps
The interface was configured in the following way:
interface GigabitEthernet7/14
no ip address
load-interval 30
no keepalive
service instance 10 ethernet
  encapsulation default
  service-policy input Policy_CustomerIngress_800Mbps
  service-policy output Policy_CustomerEgress_800Mbps
  xconnect 10.23.23.2 404 encapsulation mpls pw-class Tunnel-103
When I configured the output service-policy I received the following error message:
%X40G_QOS-DFC7-4-CFG: Unsupported shaping rate of 800000000, rounded to 131008000 in policymap ChildPolicy_CustomerEgress_800Mbps
I tried to find information about this restriction, but I was unable to find it. Do you know if there is really a restriction about the shaping rate configurable within a child policy?
Thanks in advance
Octavio
Dimitris Befas Thu, 02/27/2014 - 06:55
Hi Octavio,
One way to get this work is to remove the shaper from the clild policy and apply it to the parent only:
class class-default
The other way is to add a new child to current child:
policy-map dimitris
class class-default
    service-policy dimitris
class class-default
Sandip Rathod Sun, 03/02/2014 - 00:03
  • Cisco Employee,
If I look at parent egress policy, you have shaped it into 10 Gbps, while you you are appling this on 1Gig
Why are you appling shaping on both child and parent policy ?
Apply 800mbps only on egress parent policy map.
class class-default
Sandip
Dimitris Befas Wed, 03/05/2014 - 00:43
Hi Sandip,
What Octavio reports is valid. It seems like one more zero is added to his config snippet, but even if it was 1G instead of 10G, the same behavior is observed. This was probably a typo.
For example, you may check the config below that is not working as it will result to the "Unsupported shaping rate of 600000000, rounded to 131008000 in policymap test"
policy-map test
class class-default
  shape average 600000000 6000000 3000000
interface GigabitEthernet2/19
service-policy output test
%X40G_QOS-DFC2-4-CFG: Unsupported shaping rate of 600000000, rounded to 131008000 in policymap test
If you create a nested policy with the addition of a dummy map, it works:
policy-map dummy
class class-default
policy-map test
class class-default
service-policy dummy
The problem is that the above log is not cosmetic but it really limits the shaper to about 132Mbps.
Dimitris
