Warning message
CuciLync 9.2 -> registry key configuration does not work as expected
Jul 24th, 2013
according to the Administration Guide for CuciLync 9.2.2 some registry keys are supported to configure the client.
In the chapter 'Phone Parameters' there is a statement that four registry keys are supported:
CcmcipServer1
CcmcipServer2
TftpServer1
TftpServer2
In the next chapter 'CTI Load Balancing' there is an explanation that the registry key UseCUCMGroupForCti is also supported.
=> Does that mean that five registry keys are supported and not only four ?
My next questions leads to the possible values for these registry keys.
With CuciLync 8.6 it was possible to leave the registry keys for CcmcipServer empty.
In this case the IP addresses for CcmcipServer were automatically defined by downloading the config file.
And with UseCUCMGroupForCti these IP addresses were 'copied' to CtiServer.
That means with CuciLync 8.6 there was need to define CcmcipServer and CtiServer.
Only the TftpServers were configured by registry keys.
=> Is this also supported with CuciLync 9.2 ?
=> If no: In which future version do you plan to implement this ?
=> If yes: Are there any extra settings needed ? Because it does not work at the moment
Thanks for your feedback
Best Regards
Carsten Lucy
(Bayer Business Services)
Related Content
