I notice that when JabberVideo.exe is running and I terminate the process, some issues are introduced with a subsequent launch. When I right click on the JabberVideo icon in the notification area and select Exit, no issues exist.
Does anyone know how I can run the same exit request from a PowerShell script preferrably? If not, what other command line option do you have that I can try? Thanks
