Warning message
ISM with NAT44 - Need help with configuration
Answered Question
Jul 24th, 2013
Hello everyone,
I'm trying to set up NAT44 in the following scenario below and I'm having a hard time figuring out how to redirect the traffic. As you can see the big problem is that I have one single interface that connects to the internal network (10.0.0.0/8) and also to the tunnel destinations all in the same VRF. Can you guys give me a hand? The trafiic comes from network network 10.0.0.0/8 enters interface bundle-ether 2 (Now it needs to be translated), once it is translated, now it needs to reach the destination known via GRE tunnel.
Configurations
vrf NAT_IN
address-family ipv4 unicast
vrf BLUE
hw-module service cgn location 0/3/CPU0
interface Bundle-Ether2
description UPLINK TO METRO ETHERNET
interface Bundle-Ether2.2 l2transport
encapsulation dot1q 2
rewrite ingress tag pop 1 symmetric
interface GigabitEthernet200/0/0/43
description LINK TO METRO ETHERNET
bundle id 2 mode active
interface GigabitEthernet300/0/0/43
interface BVI2
description METRO
vrf BLUE
ipv4 address 100.0.0.10/24
interface tunnel-ip 101
description GRE_TUNNEL
vrf BLUE
ipv4 address 1.1.1.1/32
tunnel mode gre ipv4
tunnel source interface bvi 2
tunnel destination 200.0.0.1
interface BVI 100
vrf BLUE
ipv4 address [GATEWAY_100] [MASK_100]
interface BVI 200
vrf BLUE
ipv4 address [GATEWAY_200] [MASK_200]
interface BVI 300
vrf BLUE
ipv4 address [GATEWAY_300] [MASK_300]
interface ServiceApp1
vrf NAT_IN
ipv4 address 10.0.2.1 255.255.255.252
service cgn CGN service-type nat44
interface ServiceApp2
vrf BLUE
ipv4 address 10.0.2.2 255.255.255.252
interface ServiceInfra1
ipv4 address 10.0.3.1 255.255.255.0
service-location 0/3/CPU0
router static
vrf NAT_IN
0.0.0.0/0 ServiceApp1
10.0.0.0/8 vrf BLUE bvI 2 <NEXT HOP>
vrf BLUE
172.16.0.0/24 ServiceApp2
router ospf METRO
vrf BLUE
router-id [ROUTER_ID]
redistribute bgp 65500 metric 100
area 0
interface bvi 2
router ospf BLUE
vrf BLUE
router-id [ROUTER ID]
area 10
interface BVI100
interface BVI200
interface BVI200
router bgp 65500
address-family vpnv4 unicast
vrf BLUE
rd 65500:2
redistribute static
redistribute ospf BLUE
neighbor 1.1.1.2
remote-as 64512
ebgp-multihop 5
route-policy PASS in
route-policy PASS out
service cgn CGN
service-location preferred-active 0/3/CPU0
service-type nat44 nat44
portlimit 20000
inside-vrf NAT_IN
map outside-vrf BLUE address-pool 172.16.0.0/24
Thanks in advance,
Renato
Correct Answer by somnathr about 3 years 9 months ago
Hi Renato,
That's good to hear !  So, you're all set then, I would assume.
regards,
Somnath.
Correct Answer by Harold Ritter about 4 years 2 weeks ago
Hi Renato,
One way to solve this restriction would be to have two interfaces (physical or logical) connected to the network. One would be in teh VRF and the other in the global.
Correct Answer by somnathr about 4 years 2 weeks ago
Hi Renato,
This is what you have so far (for NAT):
bundle-ether 2 (NAT_IN) -- ISM -- bundle-ether 21 (NAT_OUT).
Now, if you want to send the NAT'ed traffic over a GRE tunnel, you need to do the following:
bundle-ether 2 (NAT_IN) -- ISM -- bundle-ether 21 (NAT_OUT) -- loopback cable(s) -- bundle-ether 22 (BLUE) -- Tunnel-IP 101 (BLUE)
This is because as I mentioned earlier, ISM traffic cannot be sent to / come from GRE tunnel directly.
Let me know if that works.
regards,
Somnath.
Correct Answer by somnathr about 4 years 3 weeks ago
Hi Renato,
The following error msg is coming for the same.
tunl_gre_ea[329]: %PLATFORM-TUNL_GRE_EA_PD-4-UNSUPPORTED_CONFIG : GRE Tunnel not supported on this linecard. Set the network topology to avoid this line card for GRE Tunnel packets
Yes, ISM supports traffic from/to bundle interface (along with physical i/f).
Now, as per your configuration, I see:
  • bundle-ether 2 is in NAT_IN VRF and will be receiving inside traffic for NAT. It contains following members:
    • GigabitEthernet200/0/0/43
    • GigabitEthernet300/0/0/43
  • bundle-ether 21 is in NAT_OUT and will be receiving outside traffic for NAT. It contains following members:
    • TenGigE0/0/0/21
    • TenGigE0/0/0/22
  • ServiceInfra configuration:
service-location 0/2/CPU0 -> should be 0/3/cpu0 (if you have ISM is slot 3)
  • From NAT perspective, the configuration looks fine.
  • bundle-ether 22 is in BLUE containing the following members. As you said, these are connected via loopback
    • TenGigE0/1/0/21
    • TenGigE0/1/0/22
BTW, which version of XR s/w are you using ? Have you installed the Linux install-kit s/w ?
If it is 4.3.x, you can also refer CGv6 Configuration guide, a CCO document, http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.3/cg_nat/configuration/guide/cgnat_43.html for installation and configuration steps.
regards,
Somnath.
Overall Rating: 5 (4 ratings)
somnathr Sat, 07/27/2013 - 04:59
  • Cisco Employee,
Hi Renato,
As I understood from your dscription, traffic for NAT enters the box via bundle-ether 2 interface and after NAT should go out via GRE tunnel (interface tunnel-ip 101).
First of all, there are 2 limitations that you should be aware of:
  • we don't support (on ISM) NAT traffic to come or go via GRE tunnel i/f (to / from ISM). Hence, one work-around could be to send it via any physical interface and use an external loopback cable and then ultimately send it via GRE tunnel i/f.
  • we don't support (on ISM) NAT traffic to come or go via BVI i/f (to / from ISM) as well (not sure, if you're planning to use it for NAT traffic or not).
Once the above 2 are sorted out, NAT configuration would be simple (which you have it almost right). Only thing, you need to have some interface in NAT_IN VRF through which inside NAT traffic enters ASR9K and some interface in BLUE VRF through which outside NAT traffic enters ASR9K.
Let me know if you have more questions.
regards,
Somnath.
Renato Fernande... Sat, 07/27/2013 - 08:16
Hi Somnath Roy,
First of all, thank you for your comments !
Now things are starting to get more clear to me and I guess due to this limitations you just mentioned I'm getting this log messages below, am I right?
: tunl_gre_ea[329]: %PLATFORM-TUNL_GRE_EA_PD-4-UNSUPPORTED_CONFIG : GRE Tunnel not supported on this linecard. Set the network topology to avoid this line card for GRE Tunnel packets
Can I use a L3 bundle-ether interface in place of a BVI, just in case I need to bundle some interfaces. Does ISM support it or I do have to use a physical interface?
I did another config using using loopback cable (Bundle-Ether21 e Bundle-Ether22), could you check this out?
vrf BLUE
vrf NAT_OUT
vrf NAT_IN
vrf NAT_IN
interface Bundle-Ether21
vrf NAT_OUT
ipv4 address 10.0.1.1 255.255.255.0
interface Bundle-Ether22
vrf BLUE
ipv4 address 10.0.1.2 255.255.255.0
interface TenGigE0/0/0/21
bundle id 21 mode on
interface TenGigE0/0/0/22
interface TenGigE0/1/0/21
bundle id 22 mode on
interface TenGigE0/1/0/22
vrf BLUE
tunnel source interface bundle-ether 2
interface BVI 100
vrf BLUE
interface BVI 200
vrf BLUE
interface BVI 300
vrf BLUE
vrf NAT_IN
ipv4 address 10.0.2.1 255.255.255.0
vrf NAT_OUT
ipv4 address 10.0.2.2 255.255.255.0
router static
vrf NAT_IN
vrf NAT_OUT
0.0.0.0/0 10.0.1.2
vrf BLUE
172.16.0.0/24 10.0.1.1
router ospf METRO
vrf NAT_IN
area 0
router ospf BLUE
vrf BLUE
area 10
interface BVI100
interface BVI200
interface BVI200
router bgp 65500
vrf BLUE
rd 65500:2
redistribute static
neighbor 1.1.1.2
remote-as 64512
ebgp-multihop 5
vrf NAT_IN
rd 65500:3
service cgn CGN
portlimit 20000
inside-vrf NAT_IN
map outside-vrf NAT_OUT address-pool 172.16.0.0/24
Thanks !
Renato
Correct Answer
somnathr Sun, 07/28/2013 - 07:40
  • Cisco Employee,
Hi Renato,
    • TenGigE0/0/0/21
    • TenGigE0/0/0/22
    • TenGigE0/1/0/21
    • TenGigE0/1/0/22
regards,
Somnath.
Renato Fernande... Sun, 07/28/2013 - 07:47
Hi Somnath,
Thank you ! I'm using version 4.3.1. I didn`t know I have to install it (haha), is it mandatory?
Thank you again !
Renato
somnathr Sun, 07/28/2013 - 08:37
  • Cisco Employee,
Hi Renato,
Yes, installing the Linux install-kit is mandatory as the crux of CGv6 application is part of it.
Please follow the instruction for installing Linux install-kit for 4.2in the CCO document I sent (specifically - http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.3/cg_nat/configuration/guide/cgnat43cgn.html#wp1015556). Method for 4.2.1 and above releases is the same.
regards,
Somnath.
Renato Fernande... Sun, 07/28/2013 - 08:52
Hi Somnath,
Is it necessary even when I'm using only NAT44? Do you know where I can find the information about the limitations of ISM you mentioned?
Thank you !
Renato
somnathr Sun, 07/28/2013 - 20:30
  • Cisco Employee,
Hi Reneto,
Yes, CGv6/CGN functionality is provided by same install-kit. So, you must install the same.
At present, CCO documents are the only external documentation. But, I do see that it does not list some of these limitations. We need to add it to the document.
regards,
Somnath.
Renato Fernande... Mon, 07/29/2013 - 10:01
Hi Somnath,
Thank you so much for your attention. I've installed the linux kit and now the module is in
APP-READY state.
Thank you very much again !
Renato
somnathr Mon, 07/29/2013 - 10:20
  • Cisco Employee,
You are welcome :-)
That's great ! Now, you can try with some NAT traffic.
Renato Fernande... Mon, 07/29/2013 - 10:25
Yeah, I'm going to test it as soon as possible. I'm also having some issue setting up a GRE tunnel on ASR9K, can you help with that or should I open another discussion?
Renato Reis
Harold Ritter Mon, 07/29/2013 - 11:32
  • Cisco Employee,
Hi Renato,
Could you pelase let us know what kind of issue you have in setting up the GRE tunnel?
Renato Fernande... Mon, 07/29/2013 - 12:36
Hi Harold,
I've configured a GRE tunnel between 2 ASR9K6 and I'm having the following issues:
1) The tunnel interface is UP but I can't ping the tunnels IP addresses, not even my own tunnel's interface IP address so that I never know if the tunnel is working properly.
2) I don't see the (tunnel vrf [VRF]) on IOS-XR, to tell that my tunnel interface is in VRF BLUE, but my tunnel destination is in VRF NAT_IN.
Configurations
ASR01
interface tunnel-ip101
description TUNNEL_1
vrf BLUE
ipv4 address 1.1.1.2 255.255.255.252
tunnel source Bundle-Ether2
keepalive 10 3
tunnel destination [TUNNEL IP DESTINATION]
ASR02
vrf BLUE
ipv4 address 1.1.1.1 255.255.255.252
tunnel source BVI2
keepalive 10 3
Thank you !
Renato
Harold Ritter Mon, 07/29/2013 - 13:14
  • Cisco Employee,
Hi Renato,
The VRF aware GRE tunnel currently only supports src/dst resolution in the global routing table. Support for src/dst resolution in a VRF is planned for 5.2.0.
Renato Fernande... Mon, 07/29/2013 - 13:59
Hi Somnath/Harold,
How can I address this issue? Once I need to have my GRE tunnel and interface BE (
inside NAT traffic enters) on the same routing table. Can't I use the global table as my NAT IN?
Renato
Harold Ritter Wed, 07/31/2013 - 07:00
  • Cisco Employee,
Hi Renato,
The inside interface must be in a VRF but the outside interface can be in the global routing table.
Correct Answer
somnathr Thu, 08/01/2013 - 01:14
  • Cisco Employee,
Hi Renato,
regards,
Somnath.
Renato Fernande... Thu, 08/01/2013 - 18:29
Hi Somnath,
Thank you for your attention again. Yes, that's the exactly the configurations I have, but the problem is, once
GRE tunnel currently only supports src/dst resolution in the global routing table and my
src/dst will be in routing table NAT_IN VRF, will I have to use MP-BGP to redistribute my
tunnel's src/dst from VRF NAT_IN to the global table?
Thanks in advance,
Renato Reis
Correct Answer
Harold Ritter Tue, 08/06/2013 - 14:06
  • Cisco Employee,
Hi Renato,
Renato Fernande... Sat, 08/10/2013 - 03:36
Hi Harold,
You hit the nail right on the head, that's the same solution we found. Now I'm gathering some thoubleshootong commands to check if it's working and test it on a production enviroment.
Thank you Harold and Somnath !!!
Renato
Renato Fernande... Wed, 08/14/2013 - 01:32
HiSomnath Roy,
Is there a command that shows me the inside address, like show ip nat translations on regular IOS? Could you provide me some troubleshooting commands for CGN on ISM?
Thank you !
Renato
somnathr Wed, 08/14/2013 - 01:43
  • Cisco Employee,
Hi Renato,
You can use the following command:
show cgn nat44 nat1 outside-translation protocol udp outside-address <100.200.2.75> port start <1> end <65535>
Other commands useful would be:
show cgn nat44 inside-translation ...
show cgn nat44 pool-utilization ...
show cgn nat44 statistics ...
CCO documentation for all commands are available at - http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.3/cg_nat/command/reference/b_cgnat_cr42crs_chapter_01.html.
Please use the commands related to NAT44 as that is what you're using.
regards,
Somnath.
Renato Fernande... Tue, 08/20/2013 - 03:19
Hi Somnath,
Hope you are doing well ! Is there any MIB that I can use to monitor the NAT sessions and statistics?
Thanks in advance,
Renato Reis
somnathr Tue, 08/20/2013 - 03:29
  • Cisco Employee,
Hi Renato,
We do not support any CGN MIB yet.
You can possibly use some scripts to capture CLI output periodically.
regards,
Somnath.
Renato Fernande... Tue, 08/20/2013 - 09:16
Thank you Somnath,
I have one more question, What is the impact of changing the [map outside-vrf NAT_OUT address-pool]? I'm asking that because I realized the router is using the network and also the broadcast address of the network I configured as my NAT pool as a valid IP address for translations, I guess I have to avoid it !
Thank you,
Renato
somnathr Tue, 08/20/2013 - 22:13
  • Cisco Employee,
Hi Renato,
Sorry, I could not get your question properly.
If you want to change the address pool while NAT traffic is going on, during the time you're changing the address, traffic will be dropped by CGv6 Application (with "No CGN Config" kind of message).
Once you configure new address pool, you may need to change your static route entry to divert O2I traffic properly.
It is ok to include .0 / .255 in the public IP pool (if that it what you're referring) - there should not be any issue.
regards,
Somnath.
Renato Fernande... Wed, 08/21/2013 - 03:36
Hi Somnath,
Thank you again ! Actually I wondering if using .0 / .255 could be an issue thats why I asked of changing the address pool would be a problem. I'm glad there is no problem using the network and broadcast address.
PS: I'd like to thank you for all your help, now we have GCN with ISM working on a production environment.
Renato
somnathr Wed, 08/21/2013 - 03:44
  • Cisco Employee,
Hi Renato,
That is a great news ! Congratulations !!
Glad to help you out !
It would be great if you can post the final configuration that you're using for your deployment here along with some of the "show" command output (like, 'show cgn ...', 'show interfaces service* [accounting]', etc.).
regards,
Somnath.
somnathr Wed, 08/21/2013 - 04:04
  • Cisco Employee,
One more question - Can I ask who is the customer here and also are you part of the customer organization or some other partner organization who is helping customer ?
Harold Ritter Wed, 08/21/2013 - 09:07
  • Cisco Employee,
Hi Renato,
Congratulations. You are very welcome. Let us know if you have any additional questions or concerns.
Renato Fernande... Fri, 09/20/2013 - 08:31
Hi Somnath.
I will post the configuration as soon as possible. I would like to know if is there any command to check what is the current version of the linux I'm using on the ISM module?
Thanks in advance,
Renato Reis
somnathr Fri, 09/20/2013 - 09:09
  • Cisco Employee,
Hi Renato,
You can use "show platform summary location " command
regards,
Somnath.
Renato Fernande... Fri, 09/20/2013 - 10:48
Thank you Somnath,
I'm still confused if the version that is being shown in the output below (IOS SW Ver : 4.3.1) is related to the linux kit or the IOS-XR itself.
:router#show platform summary location 0/3/CPU0
Fri Sep 20 17:45:50.010 UTC
     Platform Node : 0/3/CPU0 (slot 5)
               PID : A9K-ISM-100
         Card Type : Integrated Services Module
            VID/SN : V01 / FOC1710N5NX
        Oper State : IOS XR RUN
        Last Reset : N/A
                   : N/A
     Configuration : Power is enabled
                     Bootup enabled.
                     Monitoring enabled
        Rommon Ver : Version 1.2(20091201:235620)
        IOS SW Ver : 4.3.1
        Main Power : Power state Enabled. Estimate power 405 Watts of power required.
            Faults : N/A
     Platform Node : 0/3/CPU1 (slot 5)
         Card Type : Integrated Services Module (Service Engine)
        Oper State : APP-READY
   Last Start Time : Sun Sep  8 18:20:55 2013
   Last Ready Time : Sun Sep  8 19:53:01 2013
            Uptime : 285:52:49
          BIOS Ver : 0.17 (Thurley.3.60.18.0033)
            SW Ver : 1.0.1.0 (Built on May 3, 2012, from [email protected]/7)
        App Status : 8 CGv6 Application instance(s) is/are running
:router#
[]'s
Renato Reis
somnathr Fri, 09/20/2013 - 21:11
  • Cisco Employee,
Hi Renato,
We need to look at "CPU1" status as that is the Application CPU. "CPU0" is the XR CPU.
I see -
This gives the Application s/w version.
It looks like you need to upgrade the Linux part (install-kit) to 4.3.1. (it is running 421 now).
Procedure to upgrade the install-kit is in CCO.
regards,
Somnath.
Renato Fernande... Tue, 10/29/2013 - 10:40
Hi guys, It`s me again !
Could you guys help me with an ISM module stuck in the BRINGDOWN state?
RP/0/RSP0/CPU0:router#admin show platform
Tue Oct 29 10:34:32.782 UTC
Node            Type                      State            Config State
0/RSP0/CPU0     A9K-RSP440-TR(Active)     IOS XR RUN       PWR,NSHUT,MON
0/RSP1/CPU0     A9K-RSP440-TR(Standby)    IOS XR RUN       PWR,NSHUT,MON
0/FT0/SP        FAN TRAY                  READY
0/FT1/SP        FAN TRAY                  READY
0/0/CPU0        A9K-MOD160-TR             IOS XR RUN       PWR,NSHUT,MON
0/0/0           A9K-MPA-8X10GE            OK               PWR,NSHUT,MON
0/0/1           A9K-MPA-8X10GE            OK               PWR,NSHUT,MON
0/1/CPU0        A9K-MOD160-TR             IOS XR RUN       PWR,NSHUT,MON
0/1/0           A9K-MPA-8X10GE            OK               PWR,NSHUT,MON
0/1/1           A9K-MPA-8X10GE            OK               PWR,NSHUT,MON
0/3/CPU0        A9K-ISM-100(LCP)          BRINGDOWN        PWR,NSHUT,MON
0/PM0/SP        PWR-3KW-AC-V2             READY            PWR,NSHUT,MON
0/PM1/SP        PWR-3KW-AC-V2             READY            PWR,NSHUT,MON
0/PM2/SP        PWR-3KW-AC-V2             READY            PWR,NSHUT,MON
Thank you in advance,
Renato Reis
somnathr Tue, 10/29/2013 - 20:35
  • Cisco Employee,
Hi Renato,
Ok. In that case, as a recovery, you may want to try "hw-module reload loc ".
Can you please provide "sh logging" output which possibly would give more details on the issue(s) faced by the card ?
regards,
Somnath.
Renato Fernande... Wed, 10/30/2013 - 02:35
Hi Somnath,
I've opened a TAC and they recommended R|MA for this module, thank you for you attention.
Renato
Renato Fernande... Fri, 11/01/2013 - 11:22
Hi Somnath,
We replaced the module but the new one cant boot up either, here is the log message and the current state of the ISM module.
RP/0/RSP1/CPU0:router#admin show platform
Fri Nov  1 16:17:16.265 UTC
0/RSP0/CPU0     A9K-RSP440-TR(Standby)    IOS XR RUN       PWR,NSHUT,MON
0/RSP1/CPU0     A9K-RSP440-TR(Active)     IOS XR RUN       PWR,NSHUT,MON
0/3/CPU0        A9K-ISM-100(LCP)          IN-RESET         PWR,NSHUT,MON
0/3/SAM0        A9K-SAM-2TB               BOOTING          PWR,NSHUT,NMON
0/3/SAM1        A9K-SAM-2TB               FAILED           PWR,NSHUT,NMON
LC/0/3/CPU0:Nov  1 16:16:11.475 : apiv_srvr[115]: %PLATFORM-APIV-3-MODULE_INCOMPATIBLE : APIV module APIV_SI is incompatible
LC/0/3/CPU0:Nov  1 16:16:11.697 : vkg_l2fib_mac_cache[340]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: initializing L2 FIB MAC CAHE APIV modules.
LC/0/3/CPU0:Nov  1 16:16:11.705 : /pkg/sbin/sysmgr_log[65661]: %OS-SYSMGR-7-CHECK_LOG : /pkg/bin/sysmgr_debug_script invoked for: (fib_mgr) process did not signal EOI and for level:100 . Output is in harddisk:/sysmgr_debug/debug.node0_3_CPU0.442485
LC/0/3/CPU0:Nov  1 16:16:11.801 : vkg_l2fib_mac_cache[340]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: retrieving SysDB notifications ...
LC/0/3/CPU0:Nov  1 16:16:11.801 : vkg_l2fib_mac_cache[340]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: Starting of L2FIB MAC CACHE APIV version negotiation.
LC/0/3/CPU0:Nov  1 16:16:13.624 : canb_upg_agt[132]: %PLATFORM-UPGRADE_FPD-4-DOWN_REV : cbc instance 0 is down-rev (V18.05), upgrade to (V18.08). Use the "upgrade hw-module fpd" CLI in admin mode.
LC/0/3/CPU0:Nov  1 16:16:14.119 : l2fib[239]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: Initializing L2 FIB APIV modules.
LC/0/3/CPU0:Nov  1 16:16:14.192 : l2fib[239]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: retrieving SysDB notifications.
LC/0/3/CPU0:Nov  1 16:16:14.192 : l2fib[239]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: starting of APIV version negotiation.
LC/0/3/CPU0:Nov  1 16:16:14.784 : avsm_se_sm[125]: %PLATFORM-SIM_SE-6-STATE_CHANGE : Service Engine is in shutting down state.
LC/0/3/CPU0:Nov  1 16:16:14.790 : sis[307]: %PLATFORM-VKG_SIS-6-GENERIC_EVENT : sis event: Starting of SI APIV Deletion ...
LC/0/3/CPU0:Nov  1 16:16:15.420 : apiv_srvr[115]: %PLATFORM-APIV-5-API_INCOMPATIBLE : Message 8 in APIV module ISM_L2FIB_APIV is incompatible (reason: Not supported on the remote side)
LC/0/3/CPU0:Nov  1 16:16:15.420 : apiv_srvr[115]: %PLATFORM-APIV-3-MODULE_INCOMPATIBLE : APIV module ISM_L2FIB_APIV is incompatible
LC/0/3/CPU0:Nov  1 16:16:16.421 : avsm_agent[124]: %ISM_L2_UFA-3-ERR :  L2UFA: apiv/ipcp init failed
LC/0/3/CPU0:Nov  1 16:16:21.641 : avsm_agent[124]: %SAM_OIR-3-SAM_ERR_FPD : SAM/1: Unable to initialize. Error in FPD of device(s):CPLD. Detailed message -23:Unable to connect to socket:/tmp/fpdinfra_socket  -23 111:Connection refused
RP/0/RSP1/CPU0:Nov  1 16:16:21.647 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/3/SAM1, state: FAILED
LC/0/3/CPU0:Nov  1 16:16:24.704 : fib_mgr[172]: %PLATFORM-PLAT_FIB-3-ERR_STR_NEGO_FAIL : CGN fib apiv ipcp init: Failed to negotiate the apiv version.: UNKNOWN (12293)
LC/0/3/CPU0:Nov  1 16:16:30.695 : fib_mgr[172]: %ROUTING-FIB-3-TABLE : table operation failed during Invalid table create failed: Resource temporarily unavailable  : pkg/bin/fib_mgr : (PID=434279) :  -Traceback= 4002b9cc 4001426c 40014630 400019f4 4ba73a44 4ba71554 400003f0 40014a78 4bada400
RP/0/RSP1/CPU0:Nov  1 16:16:37.142 : shelfmgr[387]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/3/CPU0 A9K-ISM-100 state:IOS XR RUN
RP/0/RSP1/CPU0:Nov  1 16:16:37.144 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/3/CPU0, state: IOS XR RUN
LC/0/3/CPU0:Nov  1 16:16:47.370 : avsm_se_sm[125]: %PLATFORM-SIM_SE-6-STATE_CHANGE : Service Engine is in reset(Service Engine Software) state.
RP/0/RSP0/CPU0:Nov  1 16:16:47.418 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , Power Cycle (0x05000000)
RP/0/RSP0/CPU0:Nov  1 16:16:47.418 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , PLDREQ Sreset (0x0b000000)
RP/0/RSP1/CPU0:Nov  1 16:16:47.424 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , Power Cycle (0x05000000)
RP/0/RSP1/CPU0:Nov  1 16:16:47.424 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , PLDREQ Sreset (0x0b000000)
RP/0/RSP1/CPU0:Nov  1 16:16:47.425 : shelfmgr[387]: %PLATFORM-SHELFMGR-0-MAX_RESET_BRINGDOWN : Can not boot node 0/3/CPU0 A9K-ISM-100 due to multiple resets, putting it IN_RESET state. The probable cause is an unexpected event on the node or a failure in communication with the node. Please refer to the Cisco ASR 9000 System Error Message Reference Guide for further information if needed.
RP/0/RSP1/CPU0:Nov  1 16:16:47.425 : shelfmgr[387]: %PLATFORM-SHELFMGR-6-NODE_CPU_RESET : Node 0/3/CPU0 CPU reset detected.
RP/0/RSP1/CPU0:Nov  1 16:16:47.427 : shelfmgr[387]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/3/CPU0 A9K-ISM-100 state:IN-RESET
RP/0/RSP1/CPU0:Nov  1 16:16:47.434 : mibd_entity[324]: %HA-HA_EM-7-FMFD_CONNECTION_FAIL : Could not connect to /dev/fm/fd_wdsysmon.d/node0_3_CPU0 : No such file or directory
RP/0/RSP0/CPU0:Nov  1 16:16:47.548 : ce_switch_srv[53]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 7 (LC_Slot_3) is down
RP/0/RSP1/CPU0:Nov  1 16:16:47.683 : ce_switch_srv[53]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 7 (LC_Slot_3) is down
RP/0/RSP1/CPU0:Nov  1 16:16:48.436 : mibd_entity[324]: %HA-HA_EM-7-FMFD_CONNECTION_FAIL : Could not connect to /dev/fm/fd_wdsysmon.d/node0_3_CPU0 : No such file or directory
RP/0/RSP1/CPU0:Nov  1 16:16:50.437 : mibd_entity[324]: %HA-HA_EM-7-FMFD_CONNECTION_FAIL : Could not connect to /dev/fm/fd_wdsysmon.d/node0_3_CPU0 : No such file or directory
RP/0/RSP1/CPU0:Nov  1 16:16:54.439 : mibd_entity[324]: %HA-HA_EM-7-FMFD_CONNECTION_FAIL : Could not connect to /dev/fm/fd_wdsysmon.d/node0_3_CPU0 : No such file or directory
Renato Reis
somnathr Fri, 11/01/2013 - 20:38
  • Cisco Employee,
Hi Renato,
Couple of things:
  • You do not need SAM modules on ISM (for CGN/CGv6 application). So, you can remove those.
  • What is the version that ISM module is running ? Can you pl. capture 'show platform summary loc ' output ?
    • If it is older one (I see some API-V mismatch message), you may want to upgrade the Linux install-kit (pl. use the CCO configuration guide link)
regards,
Somnath.
Renato Fernande... Sat, 11/02/2013 - 05:57
Hi Somnath,
I guess the ISM's software version is up to date. How can I disadle the SAM modules?
RP/0/RSP1/CPU0:router#admin show platform summary location 0/3/CPU0
Sat Nov  2 10:57:05.277 UTC
               PID : A9K-ISM-100
            VID/SN : V01 / FOC151984LQ
        Oper State : IN-RESET
        Last Reset : N/A
                   : N/A
                     Bootup enabled.
                     Monitoring enabled
        IOS SW Ver : 4.3.2
        Main Power : Power state Disabled.
            Faults : N/A
RP/0/RSP1/CPU0:router#admin show install active summary
Sat Nov  2 10:57:11.659 UTC
Default Profile:
  SDRs:
    Owner
  Active Packages:
    disk0:asr9k-mini-px-4.3.2
    disk0:asr9k-9000v-nV-px-4.3.2
    disk0:asr9k-doc-px-4.3.2
    disk0:asr9k-fpd-px-4.3.2
    disk0:asr9k-k9sec-px-4.3.2
    disk0:asr9k-mgbl-px-4.3.2
    disk0:asr9k-mpls-px-4.3.2
    disk0:asr9k-services-px-4.3.2
LC/0/3/CPU0:Nov  1 17:24:54.895 : avsm_agent[124]: %PROCMGR-3-PROCESS_CRASH : process avsm_sia crashed, restarting it...
LC/0/3/CPU0:Nov  1 17:24:54.896 : avsm_agent[124]: %PROCMGR-2-SE_RESTART : process avsm_sia restart too many times, Service Engine is going to reboot.
LC/0/3/CPU0:Nov  1 17:24:54.959 : apiv_srvr[115]: %PLATFORM-APIV-5-API_INCOMPATIBLE : Message 24 in APIV module APIV_SI is incompatible (reason: Not supported on the remote side)
LC/0/3/CPU0:Nov  1 17:24:54.959 : apiv_srvr[115]: %PLATFORM-APIV-3-MODULE_INCOMPATIBLE : APIV module APIV_SI is incompatible
LC/0/3/CPU0:Nov  1 17:24:56.642 : canb_upg_agt[132]: %PLATFORM-UPGRADE_FPD-4-DOWN_REV : cbc instance 0 is down-rev (V18.05), upgrade to (V18.08). Use the "upgrade hw-module fpd" CLI in admin mode.
LC/0/3/CPU0:Nov  1 17:24:57.241 : l2fib[239]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: Initializing L2 FIB APIV modules.
LC/0/3/CPU0:Nov  1 17:24:57.313 : l2fib[239]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: retrieving SysDB notifications.
LC/0/3/CPU0:Nov  1 17:24:57.313 : l2fib[239]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: starting of APIV version negotiation.
LC/0/3/CPU0:Nov  1 17:24:58.033 : avsm_se_sm[125]: %PLATFORM-SIM_SE-6-STATE_CHANGE : Service Engine is in shutting down state.
LC/0/3/CPU0:Nov  1 17:24:58.035 : sis[307]: %PLATFORM-VKG_SIS-6-GENERIC_EVENT : sis event: Starting of SI APIV Deletion ...
LC/0/3/CPU0:Nov  1 17:24:58.840 : apiv_srvr[115]: %PLATFORM-APIV-5-API_INCOMPATIBLE : Message 8 in APIV module ISM_L2FIB_APIV is incompatible (reason: Not supported on the remote side)
LC/0/3/CPU0:Nov  1 17:24:58.840 : apiv_srvr[115]: %PLATFORM-APIV-3-MODULE_INCOMPATIBLE : APIV module ISM_L2FIB_APIV is incompatible
LC/0/3/CPU0:Nov  1 17:24:59.842 : avsm_agent[124]: %ISM_L2_UFA-3-ERR :  L2UFA: apiv/ipcp init failed
LC/0/3/CPU0:Nov  1 17:25:05.063 : avsm_agent[124]: %SAM_OIR-3-SAM_ERR_FPD : SAM/1: Unable to initialize. Error in FPD of device(s):CPLD. Detailed message -23:Unable to connect to socket:/tmp/fpdinfra_socket  -23 111:Connection refused
RP/0/RSP1/CPU0:Nov  1 17:25:05.065 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/3/SAM1, state: FAILED
LC/0/3/CPU0:Nov  1 17:25:07.897 : fib_mgr[172]: %PLATFORM-PLAT_FIB-3-ERR_STR_NEGO_FAIL : CGN fib apiv ipcp init: Failed to negotiate the apiv version.: UNKNOWN (12293)
LC/0/3/CPU0:Nov  1 17:25:13.838 : fib_mgr[172]: %ROUTING-FIB-3-TABLE : table operation failed during Invalid table create failed: Resource temporarily unavailable  : pkg/bin/fib_mgr : (PID=442471) :  -Traceback= 4002b9cc 4001426c 40014630 400019f4 4ba73a44 4ba71554 400003f0 40014a78 4bada400
RP/0/RSP1/CPU0:Nov  1 17:25:20.654 : shelfmgr[387]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/3/CPU0 A9K-ISM-100 state:IOS XR RUN
RP/0/RSP1/CPU0:Nov  1 17:25:20.656 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/3/CPU0, state: IOS XR RUN
LC/0/3/CPU0:Nov  1 17:25:32.631 : avsm_se_sm[125]: %PLATFORM-SIM_SE-6-STATE_CHANGE : Service Engine is in reset(Service Engine Software) state.
RP/0/RSP1/CPU0:Nov  1 17:25:32.678 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , Power Cycle (0x05000000)
RP/0/RSP1/CPU0:Nov  1 17:25:32.678 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , PLDREQ Sreset (0x0b000000)
RP/0/RSP1/CPU0:Nov  1 17:25:32.678 : shelfmgr[387]: %PLATFORM-SHELFMGR-0-MAX_RESET_BRINGDOWN : Can not boot node 0/3/CPU0 A9K-ISM-100 due to multiple resets, putting it IN_RESET state. The probable cause is an unexpected event on the node or a failure in communication with the node. Please refer to the Cisco ASR 9000 System Error Message Reference Guide for further information if needed.
RP/0/RSP1/CPU0:Nov  1 17:25:32.679 : shelfmgr[387]: %PLATFORM-SHELFMGR-6-NODE_CPU_RESET : Node 0/3/CPU0 CPU reset detected.
RP/0/RSP0/CPU0:Nov  1 17:25:32.681 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , Power Cycle (0x05000000)
RP/0/RSP0/CPU0:Nov  1 17:25:32.681 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , PLDREQ Sreset (0x0b000000)
RP/0/RSP1/CPU0:Nov  1 17:25:32.681 : shelfmgr[387]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/3/CPU0 A9K-ISM-100 state:IN-RESET
RP/0/RSP1/CPU0:Nov  1 17:25:32.689 : mibd_entity[324]: %HA-HA_EM-7-FMFD_CONNECTION_FAIL : Could not connect to /dev/fm/fd_wdsysmon.d/node0_3_CPU0 : No such file or directory
RP/0/RSP1/CPU0:Nov  1 17:25:32.702 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , Power Off (0x0a000000)
RP/0/RSP0/CPU0:Nov  1 17:25:32.705 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , Power Off (0x0a000000)
RP/0/RSP0/CPU0:Nov  1 17:25:32.917 : ce_switch_srv[53]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 7 (LC_Slot_3) is down
RP/0/RSP1/CPU0:Nov  1 17:25:32.922 : ce_switch_srv[53]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 7 (LC_Slot_3) is down
RP/0/RSP1/CPU0:Nov  1 17:25:33.691 : mibd_entity[324]: %HA-HA_EM-7-FMFD_CONNECTION_FAIL : Could not connect to /dev/fm/fd_wdsysmon.d/node0_3_CPU0 : No such file or directory
RP/0/RSP1/CPU0:Nov  1 17:25:35.693 : mibd_entity[324]: %HA-HA_EM-7-FMFD_CONNECTION_FAIL : Could not connect to /dev/fm/fd_wdsysmon.d/node0_3_CPU0 : No such file or directory
RP/0/RSP1/CPU0:Nov  1 17:25:39.694 : mibd_entity[324]: %HA-HA_EM-7-FMFD_CONNECTION_FAIL : Could not connect to /dev/fm/fd_wdsysmon.d/node0_3_CPU0 : No such file or directory
Renato
somnathr Sun, 11/03/2013 - 22:50
  • Cisco Employee,
Hi Renato,
SAM modules can be physically removed from the ISM card.
As it is in IN-RESET state, the "show platform summary location 0/3/CPU0" is not able to get App-side version number.
But, as I see the following msg:
"LC/0/3/CPU0:Nov 1 17:24:54.959 : apiv_srvr[115]: %PLATFORM-APIV-5-API_INCOMPATIBLE : Message 24 in APIV module APIV_SI is incompatible (reason: Not supported on the remote side) "
I'm suspecting that the install-kit is not updated properly.
You may need to follow the instructions under http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.3/cg_nat/configuration/guide/cgnat43cgn.html#wp1015556.
(I'm assuming Services pie is already installed and only Linux install-kit needs to be installed)
Step 1:
RP/0/RSP0/CPU0(admin)# hw-module location reload
Step 2:
RP/0/RSP0/CPU0(admin)#debug sim reload-disable location
Step 3:
(Assuming install-kit is already copied to RP)
RP/0/RSP0/CPU0(admin)# download install-image from
to
regards,
Somnath.
Renato Fernande... Mon, 11/04/2013 - 01:43
Hi Somnath,
Thank you for your attention. Actually, the FPDs of the new ISM were out of date so that the ISM coudn`t boot up. What I did was shutdown the fib manager process on the card and it no longer reloaded the ISM due to the version incompatibility and then I could upgrade the FPDs and reload the module.
proc mandatory OFF fib_mgr location 0/3/CPU0
proc SHUTDOWN fib_mgr location 0/3/CPU0
Mon Nov  4 07:41:48.669 UTC
0/3/CPU0        A9K-ISM-100(LCP)          IOS XR RUN       PWR,NSHUT,MON
0/3/CPU1        A9K-ISM-100(SE)           APP-READY
Thank you so much,
Renato
Correct Answer
somnathr Mon, 11/04/2013 - 04:38
  • Cisco Employee,
Hi Renato,
regards,
Somnath.
Renato Fernande... Mon, 11/04/2013 - 08:57
Hi Somnath,
I just wanna ask if you have any extra material about the SAM modules? How can I use them?
Renato Reis
somnathr Mon, 11/04/2013 - 19:23
  • Cisco Employee,
Hi Renato,
SAM module is already EOLed (http://www.cisco.com/en/US/prod/collateral/routers/ps9853/end_of_life_notice_c51-721386.html).
You do not need those for running CGv6 application - those are not used by CGv6 application software.
Details about how to handle / OIR SAM module are available at http://www.cisco.com/en/US/docs/routers/asr9000/hardware/ism_line_card/installation/guide/ismiginstalling.html#wp865031.
regards,
Somnath.
Renato Fernande... Wed, 12/18/2013 - 03:17
Hi Somnath,
Let's see if you can help with this new scenario. I want to extend this NAT configuration to a new site (BO1), but instead of using this entire setup with ASR9K, etc, I just want to use ASR9000v module and have this AS9K + ISM as the host. The first problem I see in this scenario is that I have the same 10.0.0.0/8 network in both sites, network which will access the same resources as the devices in the 10.0.0.0/8 in the main site.
1) Do you think if I create a new inside VRF [NAT_IN1] would address this issue?
2) Can I use the same outside VRF?
Here is the configurations.
!! IOS XR Configuration 4.3.1
vrf NAT_IN
  import route-target
   65500:2
   65500:3
  export route-target
   65500:3
vrf RED
  import route-target
   65500:1
  export route-target
   65500:1
vrf NAT_OUT
  import route-target
   65500:4
  export route-target
   65500:4
vrf SATELLITE
vrf BLUE
  import route-target
   65500:2
  export route-target
   65500:2
ipv4 access-list ABF
5 permit ospf any any
10 permit ipv4 any 10.200.0.0 0.0.255.255 nexthop1 vrf NAT_IN ipv4 10.0.2.2
20 permit icmp any any
interface Bundle-Ether3
description Uplink (BE3 - VRF NAT_IN) - VLAN 20
vrf NAT_IN
ipv4 address 1.1.1.1 255.255.255.0
ipv4 access-group ABF ingress
description LOOPBACK CABLE NAT_OUT
vrf NAT_OUT
interface Bundle-Ether23
description LOOPBACK CABLE BLUE
vrf BLUE
interface 6
description Uplink  (BE6 - Global) - VLAN 20,51,80-82
interface 6.2
ipv4 address 1.1.1.2 255.255.255.0
interface 6.51 l2transport
description EFP - BE6 - VLAN 51
encapsulation dot1q 51
interface 6.80 l2transport
description EFP - BE6 - VLAN 80
encapsulation dot1q 80
interface 6.81 l2transport
description EFP - BE6 - VLAN 81
encapsulation dot1q 81
interface 6.82 l2transport
description EFP - BE6 - VLAN 82
encapsulation dot1q 82
interface Bundle-Ether100
description Bundle to Satellite 100
vrf SATELLITE
ipv4 point-to-point
ipv4 unnumbered Loopback0
nv
  satellite-fabric-link satellite 100
   remote-ports GigabitEthernet 0/0/0-43
interface Bundle-Ether200
description Bundle to Satellite 200
vrf SATELLITE
ipv4 point-to-point
nv
  satellite-fabric-link satellite 200
interface Bundle-Ether300
description Bundle to Satellite 300
vrf SATELLITE
ipv4 point-to-point
nv
  satellite-fabric-link satellite 300
   remote-ports GigabitEthernet 0/0/0-35
interface Loopback0
description MGMT SATELLITE
vrf SATELLITE
ipv4 address 10.0.0.254 255.255.255.0
interface tunnel-ip31101
description BLUE-TUNNEL01
vrf BLUE
ipv4 address 10.200.253.90 255.255.255.252
tunnel source 6.2
tunnel destination 13.13.13.13
interface tunnel-ip31102
description BLUE-TUNNEL02
vrf BLUE
ipv4 address 10.200.253.94 255.255.255.252
tunnel source 6.2
tunnel destination 14.14.14.14
interface tunnel-ip31103
description RED-TUNNEL03
vrf RED
tunnel source 6.2
interface tunnel-ip31104
description RED-TUNNEL04
vrf RED
tunnel source 6.2
interface TenGigE0/0/0/0
description LINK TO SATELLITE 100
bundle id 100 mode on
interface TenGigE0/0/0/1
description LINK TO SATELLITE 200
bundle id 200 mode on
interface TenGigE0/0/0/3
interface TenGigE0/0/0/4
description LINK TO SATELLITE 300
vrf SATELLITE
ipv4 point-to-point
nv
   remote-ports GigabitEthernet 0/0/36-43
interface TenGigE0/0/0/5
bundle id 300 mode on
interface TenGigE0/0/0/16
description UPLINK  (BE6 - GLOBAL) - VLAN 20,51,80-82
bundle id 6 mode active
interface TenGigE0/1/0/16
interface TenGigE0/0/0/17
description UPLINK  (BE3 - VRF NAT_IN) - VLAN 20
bundle id 3 mode active
interface TenGigE0/1/0/17
description LOOPBACK CABLE TE0/1/0/22
interface TenGigE0/0/0/23
description LOOPBACK CABLE TE0/1/0/23
interface TenGigE0/1/0/0
interface TenGigE0/1/0/3
interface TenGigE0/1/0/4
interface TenGigE0/1/0/5
description LOOPBACK CABLE TE0/0/0/22
bundle id 23 mode on
interface TenGigE0/1/0/23
description LOOPBACK CABLE TE0/0/0/23
interface BVI30
vrf RED
ipv4 address 10.200.25.193 255.255.255.192
interface BVI31
vrf BLUE
ipv4 address 10.200.1.1 255.255.255.248
interface BVI32
vrf BLUE
ipv4 address 10.200.25.129 255.255.255.224
interface BVI33
vrf BLUE
ipv4 address 10.200.25.1 255.255.255.128
interface BVI36
vrf BLUE
ipv4 address 10.200.237.145 255.255.255.240
interface BVI51
vrf RED
ipv4 address 192.168.7.12 255.255.255.0
interface BVI80
vrf RED
ipv4 address 10.200.26.169 255.255.255.224
interface BVI81
vrf BLUE
ipv4 address 10.200.25.164 255.255.255.240
interface BVI82
vrf BLUE
ipv4 address 10.200.25.180 255.255.255.240
description NAT_IN
vrf NAT_IN
description NAT_OUT
vrf NAT_OUT
ipv4 address 10.0.2.5 255.255.255.252
description ISM
prefix-set PS_ROUTES
  10.200.0.8,
  10.200.5.40/29,
  10.200.1.0/29,
  10.200.5.32/29,
  10.200.0.144/28,
  10.200.106.0/28,
  10.200.106.16/28
end-set
prefix-set PS_BGP_BLUE_OUT
  10.200.24.192/26,
  10.200.5.40/29,
  10.200.240.0/25,
  10.200.1.0/29,
  10.200.25.128/27,
  10.200.25.0/25,
  10.200.5.32/29,
  10.200.26.0/25,
  10.200.0.144/28,
  10.200.27.128/27,
  10.200.27.0/25,
  10.200.106.0/28,
  10.200.106.128/25,
  10.200.106.16/28,
  10.200.107.128/25
end-set
route-policy RP_DENY_ALL
  drop
end-policy
route-policy RP_PASS_ALL
  pass
end-policy
route-policy RP_BGP_BLUE_OUT
  if destination in PS_BGP_BLUE_OUT then
    pass
  endif
end-policy
route-policy RP_PASS_ROUTES
  if destination in PS_ROUTES then
    pass
  endif
end-policy
router static
  0.0.0.0/0 1.1.1.20
vrf NAT_IN
vrf RED
vrf NAT_OUT
   0.0.0.0/0 10.0.1.2
   10.200.24.192/26 ServiceApp2
vrf BLUE
   10.200.24.192/26 10.0.1.1
router ospf
log adjacency changes
vrf NAT_IN
  router-id 1.1.1.1
  disable-dn-bit-check
  redistribute bgp 65500 metric 5 metric-type 2 route-policy RP_PASS_ROUTES
  area 7
router ospf RED
vrf RED
  router-id 10.200.26.169
  redistribute bgp 65500 metric 10 metric-type 2
  area 11
   interface BVI30
   interface BVI80
router ospf BLUE
vrf BLUE
  router-id 10.200.25.164
  redistribute static
  area 0
   interface BVI81
   interface BVI82
  area 2
   interface BVI31
   interface BVI32
   interface BVI33
   interface BVI36
router bgp 65500
vrf NAT_IN
  rd 65500:3
  bgp router-id 1.1.1.1
   route-target download
vrf RED
  rd 65500:1
  bgp router-id 10.200.253.90
   network 10.200.25.192/26
   network 10.200.26.128/27
   network 10.200.26.192/27
   network 10.200.27.192/26
   network 10.200.104.128/27
   network 10.200.104.160/27
  neighbor 10.200.253.89
   remote-as 64512
   ebgp-multihop 5
   update-source tunnel-ip31103
    route-policy RP_PASS_ALL in
    route-policy RP_PASS_ALL out
    soft-reconfiguration inbound
  neighbor 10.200.253.93
   remote-as 64512
   ebgp-multihop 5
   update-source tunnel-ip31104
vrf BLUE
  rd 65500:2
   network 10.200.0.144/28
   network 10.200.1.0/29
   network 10.200.5.32/29
   network 10.200.5.40/29
   network 10.200.24.192/26
   network 10.200.25.0/25
   network 10.200.25.128/27
   network 10.200.26.0/25
   network 10.200.27.0/25
   network 10.200.27.128/27
   network 10.200.106.0/28
   network 10.200.106.16/28
   network 10.200.106.128/25
   network 10.200.107.128/25
   network 10.200.240.0/25
   remote-as 64512
   ebgp-multihop 5
   update-source tunnel-ip31101
    route-policy RP_BGP_BLUE_OUT out
   remote-as 64512
   ebgp-multihop 5
   update-source tunnel-ip31102
l2vpn
load-balancing flow src-dst-ip
bridge group VLAN30
  bridge-domain VLAN30
   routed interface BVI30
bridge group VLAN31
  bridge-domain VLAN31
   routed interface BVI31
bridge group VLAN32
  bridge-domain VLAN32
   routed interface BVI32
bridge group VLAN33
  bridge-domain VLAN33
   routed interface BVI33
bridge group VLAN36
  bridge-domain VLAN36
   routed interface BVI36
bridge group VLAN51
  bridge-domain VLAN51
   routed interface BVI51
bridge group VLAN80
  bridge-domain VLAN80
   interface 6.80
   routed interface BVI80
bridge group VLAN81
  bridge-domain VLAN81
   interface 6.81
   routed interface BVI81
bridge group VLAN82
  bridge-domain VLAN82
   interface 6.82
   routed interface BVI82
nv
satellite 100
  type asr9000v
  ipv4 address 10.0.0.1
satellite 200
  type asr9000v
satellite 300
  type asr9000v
  ipv4 address 10.0.0.3
service cgn CGN
  portlimit 20000
  inside-vrf NAT_IN
   map outside-vrf NAT_OUT address-pool 10.200.24.192/26
Thanks in advance,
Renato
Related Content
