why does cisco887 get reloaded?
Jul 24th, 2013
Hi guys,
I have a router  Cisco 887
c870-advsecurityk9-mz.124-15.XY3.bin
When I am connecting to the router using Cisco VPN client and trying to ping any host from private range 192.168.0.0/24 except the cisco's ip address 192.168.0.254 the router gets reloaded after the first ping.
It all worked before and this started happening at some point though I did not make any changes in configuration.
Can you help me what might be the problem?
Here is my config:
thanks guys!
Building configuration...
Current configuration : 10632 bytes
version 12.4
no service pad
hostname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa authentication login default local
aaa authentication login vpn_xauth local
aaa authentication login sslvpn local
aaa authorization network vpn_group local
aaa session-id common
crypto isakmp policy 1
encr aes 256
authentication pre-share
group 2
crypto isakmp policy 2
encr aes 256
hash md5
group 2
crypto isakmp client configuration group ciscogroup
key ciscogroup
pool VPN-Pool
acl 196
max-users 5
crypto isakmp profile vpn-ike-profile-1
   match identity group ciscogroup
   client authentication list vpn_xauth
   isakmp authorization list vpn_group
   client configuration address respond
   virtual-template 2
crypto ipsec transform-set encrypt-method-1 esp-3des esp-sha-hmac
crypto ipsec profile VPN-Profile-1
set transform-set encrypt-method-1
crypto pki trustpoint TP-self-signed-2379352192
enrollment selfsigned
ip-address cef
subject-name cn=IOS-Self-Signed-Certificate-2379352192
revocation-check none
rsakeypair TP-self-signed-2379352192
ip cef
archive
log config
  hidekeys
class-map type inspect match-all cmap-in-outa-base
match protocol tcp
match protocol udp
match protocol sip
class-map type inspect match-all cmap-outa-in-base
match access-group 191
class-map type inspect match-any cm_vpnin
match access-group name FOR_VPNCLIENTS
class-map type inspect match-any cm_invpn
class-map type inspect match-all cmap-outa-out-permit
match access-group 195
class-map type inspect match-any cmap-in-out-base
match protocol http
match protocol https
match protocol pop3
match protocol dns
match protocol smtp
match protocol icmp
match protocol pptp
match protocol sip
match access-group 193
class-map type inspect match-any cmap-out-in-base
match protocol http
match protocol ftp
match protocol smtp
match protocol pop3
match protocol lotusnote
match access-group 192
class-map type inspect match-any cmap-out-in-itng
match access-group 10
match access-group 100
class-map type inspect match-any cmap-in-out-excp
match access-group 190
class-map type inspect match-any cmap-out-self-base
match access-group 197
policy-map type inspect pm_vpnin
class type inspect cm_vpnin
  pass
class class-default
policy-map type inspect pm_invpn
class type inspect cm_invpn
  pass
class class-default
policy-map type inspect pmap-in-outa-base
class type inspect cmap-in-outa-base
  inspect
class class-default
policy-map type inspect pmap-outa-in-base
class type inspect cmap-outa-in-base
  inspect
class class-default
policy-map type inspect pmap-out-self-base
class type inspect cmap-out-self-base
  inspect
class class-default
policy-map type inspect pmap-in-out-base
class type inspect cmap-in-out-excp
  pass
class type inspect cmap-in-out-base
  inspect
class class-default
policy-map type inspect pmap-out-in-base
class type inspect cmap-out-in-base
  inspect
  pass
class type inspect cmap-out-in-itng
  inspect
class class-default
policy-map type inspect pmap-out-out-a-base
class type inspect cmap-outa-out-permit
  inspect
class class-default
  pass
zone security in
description ZONE_INTERNAL
zone security out
description ZONE_EXTERNAL
zone security out-a
zone security VPN
description For VPN users
zone-pair security zpair-out-self source out destination self
service-policy type inspect pmap-out-self-base
zone-pair security zpair-out-in source out destination in
service-policy type inspect pmap-out-in-base
zone-pair security zpair-out-out-a source out destination out-a
service-policy type inspect pmap-out-out-a-base
zone-pair security zpair-out-a-out source out-a destination out
zone-pair security zpair-in--out source in destination out
service-policy type inspect pmap-in-out-base
zone-pair security zpait-in-outa-base source in destination out-a
service-policy type inspect pmap-in-outa-base
zone-pair security zpair-outa-in source out-a destination in
service-policy type inspect pmap-outa-in-base
zone-pair security zp_vpnin source VPN destination in
service-policy type inspect pm_vpnin
zone-pair security zp_invpn source in destination VPN
service-policy type inspect pm_invpn
interface Loopback10
ip address Y 255.255.255.255
ip nat outside
ip virtual-reassembly
zone-member security out-a
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
  encapsulation aal5snap
  protocol ppp dialer
  dialer pool-member 1
dsl operating-mode auto
hold-queue 224 in
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Virtual-Template2 type tunnel
ip unnumbered Dialer0
zone-member security VPN
tunnel mode ipsec ipv4
tunnel protection ipsec profile VPN-Profile-1
interface Vlan1
description all-one-gateway
ip address 192.168.0.254 255.255.255.0
ip nat inside
zone-member security in
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname
ppp chap password 0
interface Dialer1
no ip address
ip local pool ippool 192.168.181.1 192.168.181.254
ip local pool VPN-Pool 192.168.90.20 192.168.90.25
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map nonat interface Dialer0 overload
ip nat inside source static tcp 192.168.0.11 88 X.X.X.X 88 extendable
ip nat inside source static tcp 192.168.0.11 110 X.X.X.X 110 extendable
ip nat inside source static tcp 192.168.0.11 8080 X.X.X.X 8080 extendable
ip nat inside source static tcp 192.168.0.10 20 X.X.X.X 20 extendable
ip nat inside source static tcp 192.168.0.10 21 X.X.X.X 21 extendable
ip nat inside source static tcp 192.168.0.11 25 X.X.X.X 25 extendable
ip nat inside source static tcp 192.168.0.10 80 X.X.X.X 80 extendable
ip nat inside source static tcp 192.168.0.11 81 X.X.X.X 81 extendable
ip nat inside source static tcp 192.168.0.101 443 X.X.X.X 443 extendable
ip nat inside source static tcp 192.168.0.11 1352 X.X.X.X 1352 extendable
ip nat inside source static tcp 192.168.0.10 1723 X.X.X.X 1723 extendable
ip nat inside source static tcp 192.168.0.10 3389 X.X.X.X 3389 extendable
ip nat inside source static tcp 192.168.0.11 3389 X.X.X.X 3390 extendable
ip nat inside source static tcp 192.168.0.72 5700 X.X.X.X 5700 extendable
ip nat inside source static tcp 192.168.0.11 5900 X.X.X.X 5900 extendable
ip nat inside source static tcp 192.168.0.72 6631 X.X.X.X 6631 extendable
ip nat inside source static tcp 192.168.0.56 6900 X.X.X.X 6900 extendable
ip nat inside source static tcp 192.168.0.10 3389 X.X.X.X 53389 extendable
ip nat inside source static 192.168.0.12 X.X.X.X
ip access-list extended FOR_VPNCLIENTS
permit ip any 192.168.0.0 0.0.0.255
permit ip 192.168.0.0 0.0.0.255 any
access-list 10 permit X.X.X.X
access-list 100 permit icmp any host 192.168.0.12
access-list 100 permit ip any host 192.168.0.12
access-list 100 permit ip 192.168.90.0 0.0.0.255 any
access-list 102 permit tcp any host X.X.X.X eq 1352
access-list 102 permit tcp any host X.X.X.X eq 8080
access-list 102 permit tcp any host 192.168.0.11 eq 81
access-list 102 permit tcp any host 192.168.0.10 eq 1723
access-list 102 permit ip any host 192.168.91.1
access-list 110 deny   ip 192.168.0.0 0.0.0.255 192.168.181.0 0.0.0.255
access-list 110 deny   ip 192.168.0.0 0.0.0.255 192.168.90.0 0.0.0.255
access-list 110 permit ip 192.168.0.0 0.0.0.255 any
access-list 120 permit ip 192.168.0.0 0.0.0.255 192.168.181.0 0.0.0.255
access-list 190 permit gre any any
access-list 191 permit tcp any host X.X.X.X eq 3389
access-list 192 permit tcp any host X.X.X.X eq 1352
access-list 192 permit tcp any host X.X.X.X eq 8080
access-list 192 permit tcp any host 192.168.0.11 eq 81
access-list 192 permit tcp any host 192.168.0.10 eq 1723
access-list 192 permit ip any host 192.168.91.1
access-list 192 permit tcp any host 192.168.0.11 eq 3389
access-list 193 permit tcp host 192.168.0.10 any
access-list 193 permit tcp host 192.168.0.11 any
access-list 193 permit ip any 192.168.90.0 0.0.0.255
access-list 193 permit ip host 192.168.91.1 any
access-list 193 permit tcp host 192.168.0.121 any
access-list 193 permit tcp host 192.168.0.101 any
access-list 193 permit tcp host 192.168.0.102 any
access-list 194 permit ip host X.X.X.X any
access-list 194 permit ip 192.168.0.0 0.0.0.255 any
access-list 194 permit ip 192.168.91.0 0.0.0.255 any
access-list 195 permit ip any any
access-list 195 permit icmp any any
access-list 196 permit ip 192.168.0.0 0.0.0.255 any
access-list 197 permit udp any any eq isakmp
access-list 197 permit ahp any any
access-list 197 permit esp any any
access-list 197 permit udp any any eq non500-isakmp
no cdp run
route-map nonat permit 10
match ip address 110
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
transport input telnet ssh
scheduler max-task-time 5000
webvpn cef
webvpn context Default_context
ssl authenticate verify all
no inservice
end
Leo Laohoo Wed, 07/24/2013 - 23:49
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Post the output to the command "sh version".
glebpe185 Wed, 07/24/2013 - 23:55
Sure
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(15)XY3, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 23-May-08 10:08 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YI3, RELEASE SOFTWARE
exe02991863 uptime is 1 hour, 38 minutes
System returned to ROM by reload
System image file is "flash:c870-advsecurityk9-mz.124-15.XY3.bin"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 877 (MPC8272) processor (revision 0x200) with 118784K/12288K bytes of memory.
Processor board ID FHK111412XA
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ATM interface
128K bytes of non-volatile configuration memory.
28672K bytes of processor board System flash (Intel Strataflash)
Leo Laohoo Thu, 07/25/2013 - 23:19
  • Hall of Fame,
    2017 LAN, Wireless
Someone issued the "reload" command.
glebpe185 Thu, 07/25/2013 - 23:28
No it reboots without issuing any commands otherwise I would not have posted the message here.
