Warning message
CUCM Warning tone for long duration calls
Answered Question
Jul 25th, 2013
Good afternoon everyone,
My client asked me if it is possible to set a warning tone to let users know that the call is taking too long. I know the call duration can be set up, is this related to that?
Thanks for the help in advance.
Bruno
Correct Answer by Jonathan Schulenberg about 4 years 3 weeks ago
You could do this with a TCL script on the voice gateway though. Since it already has a DSP invoked for the call that would be the easiest spot to inject audio.
http://www.cisco.com/en/US/docs/ios-xml/ios/ios_tcl/configuration/12-4t/nm-script-tcl.html
Please remember to rate helpful responses and identify helpful or correct answers.
Correct Answer by Jaime Valencia about 4 years 3 weeks ago
No, CUCM doesn't have any feature like that.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (2 ratings)
Correct Answer
Jonathan Schulenberg Fri, 07/26/2013 - 04:34
  • Cisco Designated VIP,
    2017 IP Telephony
Bruno Mauricio ... Wed, 08/07/2013 - 08:34
Thanks for the help Jonathan. It helps a lot.
Related Content
