Warning message
Cisco 6945 Phone Display issue
Jul 25th, 2013
                   Dear All,
I have a one problem in Cisco 6945 series phone...
Nothing is showing on display..but phone is registered with CUCM and working fine...
Kindly let me know the solution....
Thanks in advance
Overall Rating: 3 (1 ratings)
Jonathan Schulenberg Fri, 07/26/2013 - 03:43
  • Cisco Designated VIP,
    2017 IP Telephony
Probably a simple hardware failure. If the phone is still under warranty or you have SMARTnet on it, you could have Cisco replace it.  Also possible that some joker turned the contrast all the way down on you.
Please remember to rate helpful responses and identify helpful or correct answers.
ciscovoipsupport Fri, 07/26/2013 - 03:47
- make sure you are looking at the same MAC address on both CPE and Phone.
- If the phone does not show anything when it boots then what Jonathan said is right, it could a simple hardware failure.
