B200 M3 blade & Windows 2012 Server
Jul 26th, 2013
Does any has been able to install Windows server 2012 On a B200 M3 blade running 2204XP As fex with VIC 1240 card installed in blade.
I am running 2.0(4b) On B 200 M 3 blades & while trying to install Windows 2012 . It installed succesfully since i am using local disk's But it;s not picking up HBA and NIC drivers . The support Bundle under download link on cisco;s website is missing the drivers for 1240 . It has for 1280 and MK811 KR & Mlom. Just cruious does Cisco supports intallation of Windows 2012 on B200 M3 blade with VIC 1240 adapters. I downloaded whole of 1.0 GB Iso containing Driver Only to see the VIC 1240 Drivers missing from the ISO .
Docuemtation On below link says " it;s Not supported "
http://www.cisco.com/en/US/docs/unified_computing/ucs/interoperability/matrix/r_hcl_B_rel2.04.pdf
Page no 53 Point no 14 under notes.
Sushil
padramas Fri, 07/26/2013 - 06:28
  • Cisco Employee,
Hello Sushil,
UCSM 2.0.4b is not tested for W2K12 and so it is not qualified for support.
However, W2K12 will be able to install  on B200 M3 + VIC 1240 hardware and once you upgrade UCSM + firmware, you will be in supported config scenario.
VIC 1240 is also known as MLOM. You can install drivers published under MLOM folder.
Padma
skumar286 Fri, 07/26/2013 - 06:38
HI
Thanks Padma . excellent to see you active here as well.. it;s been quite some time now . I have opened a Support request as well with you guys as 626787149 .
So what;s the Supported UCSM Firmware version for the  VIC 1240 to Work with windows 2012 ?? .we are running 2.0 (4b ) at the moment .
will appreciate if you could post the relevant official link here and the nearest supported firmware for it to work & yes, I can see Drivers for Mlom in that downloaded ISO. Has downloaded t twice thinking that 1240 is supported.
Sushil
padramas Fri, 07/26/2013 - 06:45
  • Cisco Employee,
Hello Sushil,
I just checked HCL and Windows 2012 is supported in UCSM 2.0.4 release .
http://www.cisco.com/en/US/products/ps10477/prod_technical_reference_list.html
http://www.cisco.com/web/techdoc/ucs/interoperability/matrix/matrix.html
Recommended driver version are
FNIC ( HBA )  2.2.0.9
ENIC ( NIC )   2.2.0.8
MLOM is aka VIC 1240. You should be able to install the drivers under MLOM folder.
Padma
skumar286 Fri, 07/26/2013 - 07:02
That;s the Problem. The windows 2012 Drivers i just downloaded do have those MLOM drivers but it;s not picking up those drivers . Hence I delved into compatibility stuff. If you check the PDF link on forst post , and read into Notes, Point no 14 mentions below
The
2104XP
fabric
extender
is
not
compatible
when
the
1240
and
1280
or
1240
and
VIC
Port
Expander
are
combined
on
the
same
blade.
Applies
to
B22
M3
and
B200
M3
as
well
as
B420
with
1240
and
adapter
slot
populated
padramas Fri, 07/26/2013 - 07:07
  • Cisco Employee,
You mentioned 2204 as IOM model in the initial post.
That note applies only when you have 2104 IOM + MLOM ( VIC 1240 ) + 1280 or Port expander in mezz slot.
If the blade has just VIC 1240 ( MLOM ) , it is not an issue.
Please make sure you install the drivers from Device manager.
skumar286 Fri, 07/26/2013 - 07:33
Correct, I have 2204 IOM + VIC 1240 . is there any way i can find out that Mezz slot has Port expander via UCSM ??
Don;t have physical access to blade at the moment .
I am trying to install drivers via device manager only ....
skumar286 Fri, 07/26/2013 - 08:37
So finally, I was able to get correct drivers and make them work. Strange that i could not find them publicly.  Attaching the drivers Below
Thanks for the Help Padma . It;s becuase of people like you that i always receive excellent support.
Related Content
