Warning message
Default Route is not redistributed in vrf
Jul 26th, 2013
i have some problems with redistributing my default route through my mpls cloud. I think the problem is because it is not in the bgp table. But i don't see why. Any ideas?
thanks in advanced
Alex
Here is config of my PE router.
==== OSPF ====
router ospf 110 vrf IAS
router-id 172.22.25.241
capability vrf-lite
redistribute bgp 65000 subnets
network 172.22.25.0 0.0.0.7 area 0
network 172.22.25.241 0.0.0.0 area 0
default-information originate
==== BGP ====
router bgp 65000
bgp log-neighbor-changes
neighbor RR-COLO1 peer-group
neighbor RR-COLO1 remote-as 65000
neighbor RR-COLO1 update-source Loopback1
neighbor 172.16.128.252 peer-group RR-COLO1
neighbor 172.16.130.252 peer-group RR-COLO1
address-family ipv4
  neighbor 172.16.128.252 activate
  neighbor 172.16.130.252 activate
exit-address-family
address-family vpnv4
  neighbor RR-COLO1 send-community both
  neighbor RR-COLO1 route-reflector-client
exit-address-family
address-family ipv4 vrf IAS
  redistribute connected
  redistribute ospf 110
show ip route vrf IAS
Gateway of last resort is 172.22.25.6 to network 0.0.0.0
O*E2  0.0.0.0/0 [110/1] via 172.22.25.6, 00:21:36, FastEthernet0/1.110
show ip ospf database external 0.0.0.0
                Type-5 AS External Link States
  Routing Bit Set on this LSA in topology Base with MTID 0
  LS age: 1391
  Options: (No TOS-capability, DC)
  LS Type: AS External Link
  Link State ID: 0.0.0.0 (External Network Number )
  Advertising Router: 10.0.25.254
  LS Seq Number: 80000001
  Checksum: 0x3759
  Length: 36
  Network Mask: /0
        Metric Type: 2 (Larger than any link state path)
        MTID: 0
        Metric: 1
        Forward Address: 0.0.0.0
        External Route Tag: 1
show ip bgp vpnv4 vrf IAS
BGP table version is 622, local router ID is 172.16.137.252
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, x best-external, f RT-Filter
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 65000:110 (default for vrf IAS)
*> 10.0.25.0/24     172.22.25.6              2         32768 ?
r>i172.22.16.0/29   172.16.128.252           0    100      0 ?
r>i172.22.16.241/32 172.16.128.252           0    100      0 ?
r>i172.22.16.242/32 172.16.128.252           2    100      0 ?
r>i172.22.18.0/29   172.16.130.252           0    100      0 ?
r>i172.22.18.241/32 172.16.130.252           0    100      0 ?
r>i172.22.18.242/32 172.16.130.252           2    100      0 ?
*> 172.22.25.0/29   0.0.0.0                  0         32768 ?
*> 172.22.25.232/29 172.22.25.6              2         32768 ?
*> 172.22.25.241/32 0.0.0.0                  0         32768 ?
*> 172.22.25.242/32 172.22.25.6              2         32768 ?
*> 172.22.26.0/29   172.22.25.6              3         32768 ?
*> 172.22.26.241/32 172.22.25.6              4         32768 ?
*> 172.22.26.242/32 172.22.25.6              3         32768 ?
alex.dersch Fri, 07/26/2013 - 13:30
i found the problem, i had to add match internal external 2 under the address family bgp configuration
  redistribute ospf 110 match internal external 2
thanks anyways
Alex
