Warning message
how to upgrade CUCM 6.0.1a to 6.1.2
Jul 26th, 2013
Hey
We are trying to upgrade a MCS 7800 running CUCM 6.0.1 to CUCM 6.1.2. I did some research and found that it can directly upgrade, but the upgrade file is so big it is in two parts. We have tried this command:
cat UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part1of2 UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part2of2 > UCSInstall_UCOS_6.1.2.1000-13.sgn.iso
But it say "<" invalid anyone else has this problem ?
Overall Rating: 5 (1 ratings)
acampbell Fri, 07/26/2013 - 15:31
  • Green, 3000 points or more
Dwayne,
Have you downloaded the 2 files to a windows machine ?
Alex.
Please rate useful posts.
dwayne rattan Fri, 07/26/2013 - 16:17
ok I got though with this for and one else having trouble combining these files use the windows cmd and follow the commands in the img
Jonathan Schulenberg Sat, 07/27/2013 - 04:41
  • Cisco Designated VIP,
    2017 IP Telephony
The release notes show a different command:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/rel_notes/6_1_2/cucm-rel_note-612.html#wp553371
COPY /B UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part1of2+UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part2of2 UCSInstall_UCOS_6.1.2.1000-13.sgn.iso
Please remember to rate helpful responses and identify helpful or correct answers.
dwayne rattan Mon, 08/05/2013 - 11:28
ok I left out a step in the cmd but here is all
This is for windows
c:\user\name> cd..
c:\user>cd..
c:\> cd c:\ name of folder
c:\name of folder> COPY /B UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part1of2+UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part2of2 UCSInstall_UCOS_6.1.2.1000-13.sgn.iso
like jonathan said use that command to combine the both files, which will be in the folder <> that you will create on the C drive
