Warning message
Help with RegEx to extend (?!.*@%localdomains%).*
Jul 27th, 2013
  • Silver, 250 points or more
Hi All,
I have been looking over some previous discussions (such as https://supportforums.cisco.com/message/3758886#3758886), documentation (such as https://supportforums.cisco.com/docs/DOC-25084 - which is very good BTW), and RegEx sites to see if I can com up with something to work for us.
The RegEx :
is used on the VSC-E search rule to forward URI lookups that do NOT have a SIP domain configured on the VCS. This is great but assumes that the search string is in a URI format usually accomplished by a transform in the VCS-E. At the moment we don't apply this transform as (in general), we route using the E.164 via the Global Dialling Scheme. In addition, the VCS-E is used as a traversal server to many VCS-C and potentially will host many SIP domains - so which one do I transform to?
The problem I have that without this domain conversion transform, the above RegEx actually matches non URI strings and the DNS search rule will be invoked. A DNS look for such a non domain would obviously fail but is pointless and time/resources consuming.
So I was wondering if ther was a way to construct the RegEx to not only fail when a string contains a domain as configured on the VCS (as above), but ALSO only to succeed when a valid URI is detected - i.e. some thing with an @ in it. I did come up with the following:
     ((?!.*@%localdomains%).*)|(.+@.+\..+)
but unfortunately this name overrides the main part of the RegEx as, of course, the configured domain used in a URI will also have an @ in them.
E.g. We have two domains configured on the VCS - mydom.com and otherdom.com
I need to ensure that the RegEx is ONLY true when a string contains a valid URI, but does NOT end in either mydom.com and otherdom.com
So:
     [email protected] -                Fail
     [email protected] -                     Success
     0123456  -                              Fail
Perhaps (and to maybe answer my own question), I should just add a transform anyway and turn all non URI searches into a configured dummy domain (i.e. dummy.com). I can essentially ignore and strip this if the string contains a transformed E.164 number and route as normal, yet the DNS search rule will be prevented from firing.
Anyhow, thoughts welcome.
Chris
Overall Rating: 5 (1 ratings)
Chris Swinney Sat, 07/27/2013 - 14:23
To answer my own question (2), if I can out the OR in the RegEx above, it all works.
     ?!.*@%localdomains%).*)(.+@.+\..+)
Danahh
Paulo Souza Sat, 07/27/2013 - 14:59
  • Gold, 750 points or more
Hi Cris,
I didn't even have time to suggest you anything... rsrs.
Five stars to you for answering your own question.   =)
Paulo Souza
Please rate replies and mark question as "answered" if applicable.
