Warning message
Help using Redirect on Aironet Access Point please :)
Jul 28th, 2013
I am setting up wireless access points for a Church.
I acquired a couple of 1131AG access points, and flashed them into Autonomous mode successfully. I used the CLI to configure them to provide WiFi, 1 SSID only (it's just for parishoner access; the office will remain on a separate, existing WiFi network). It uses WPA2 encryption. An existing router will provide DHCP.
We want to redirect to a Welcome page when parishoners connect. I know that "Enable IP Redirection on this SSID" exists on the access point, but I'm unclear how to use it, and an extensive search (of the Support Community and the general Internet) didn't help.
Can anyone direct me as to how to do this? The Church has a website (hosted externally), and I could put a page there; alternately we could use a service (preferably free; we don't have much money). We don't run any servers at the Church building right now, and I'd rather not install one if I can avoid it.
Thanks in advance for the help!
-David
George Stefanick Mon, 07/29/2013 - 08:18
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Hi David,
When I do guest networks and point the wifi to the guest box I use the ip address of the guest box as the gateway for that SSID. Although it sound like you want to redirect to a external website. You may want to look at a guest box to handle this. It will make your life a lot easier.
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
davidbayne Mon, 07/29/2013 - 09:00
George:
Are you referring to the product "Guest Box"? Or some alternate server? I'm interested in your idea, and would love to hear more about what product you use.
Thanks!
George Stefanick Mon, 07/29/2013 - 09:42
David,
The boxes Ive used for customers come at a higher cost. I know your poisiton working with a church. Ive donated my time for similar causes setting up wireless networks. Check out this link or google wireless guest hotspots .. They have several portal options to handle your redirects.
http://www.networkworld.com/slideshow/92979/hottest-hotspot-gateways.html#slide3
Related Content
