802.1x multi-domain 3560catalyst nortel ip phone ntdu92
Ivan Levadnyi
Hello everyone!
I have 3560 catalyst ios 12.2(55)SE5
I need to authorize PC and IP phone on this port. 212 data vlan 500 voice vlan, vlan 111 - Unauthorized VLAN with 256 kbit/sec INTERNET without any local resourses. IP phone authorizes by mab.
#sh mac address-table interface fastEthernet 0/2
212    001a.4b7b.0394    STATIC      Fa0/2
500    001b.bafb.7c1c    STATIC      Drop
#sh running-config interface fastEthernet 0/2
interface FastEthernet0/2
switchport access vlan 212
switchport mode access
switchport voice vlan 500
authentication event fail action authorize vlan 111
authentication event no-response action authorize vlan 111
authentication host-mode multi-domain
authentication port-control auto
authentication violation replace
mab
dot1x pae authenticator
dot1x timeout quiet-period 5
dot1x timeout server-timeout 5
dot1x timeout tx-period 10
dot1x timeout supp-timeout 3
dot1x max-reauth-req 3
storm-control broadcast level 7.00 3.00
storm-control multicast level 15.00 10.00
storm-control action shutdown
no cdp enable
spanning-tree portfast
spanning-tree guard root
end
#sh logging
Jul 29 11:11:03: %DOT1X-5-FAIL: Authentication failed for client (001b.bafb.7c1c) on Interface Fa0/2 AuditSessionID
Jul 29 11:11:03: %AUTHMGR-7-RESULT: Authentication result 'no-response' from 'dot1x' for client (001b.bafb.7c1c) on Interface Fa0/2 AuditSessionID 0A32FF150000006025C481C2
Jul 29 11:11:03: %AUTHMGR-7-FAILOVER: Failing over from 'dot1x' for client (001b.bafb.7c1c) on Interface Fa0/2 AuditSessionID 0A32FF150000006025C481C2
Jul 29 11:11:03: %AUTHMGR-5-START: Starting 'mab' for client (001b.bafb.7c1c) on Interface Fa0/2 AuditSessionID 0A32FF150000006025C481C2
Jul 29 11:11:03: %MAB-5-SUCCESS: Authentication successful for client (001b.bafb.7c1c) on Interface Fa0/2 AuditSessionID 0A32FF150000006025C481C2
Jul 29 11:11:03: %AUTHMGR-7-RESULT: Authentication result 'success' from 'mab' for client (001b.bafb.7c1c) on Interface Fa0/2 AuditSessionID 0A32FF150000006025C481C2
Jul 29 11:11:03: %AUTHMGR-5-SECURITY_VIOLATION: Security violation on the interface FastEthernet0/2, new MAC address (001b.bafb.7c1c) is seen.AuditSessionID  0A32FF150000006025C481C2
Jul 29 11:11:03: %AUTHMGR-5-MACREPLACE: MAC address (001a.4b7b.0394) on Interface FastEthernet0/2 is replaced by MAC (001b.bafb.7c1c) AuditSessionID 0A32FF150000005F25C42541
Jul 29 11:11:04: %AUTHMGR-5-SUCCESS: Authorization succeeded for client (001b.bafb.7c1c) on Interface Fa0/2 AuditSessionID 0A32FF150000006025C481C2
Jul 29 11:11:06: %AUTHMGR-5-START: Starting 'dot1x' for client (001a.4b7b.0394) on Interface Fa0/2 AuditSessionID 0A32FF150000006125C52D87
Jul 29 11:11:06: %DOT1X-5-SUCCESS: Authentication successful for client (001a.4b7b.0394) on Interface Fa0/2 AuditSessionID
Jul 29 11:11:06: %AUTHMGR-7-RESULT: Authentication result 'success' from 'dot1x' for client (001a.4b7b.0394) on Interface Fa0/2 AuditSessionID 0A32FF150000006125C52D87
Jul 29 11:11:06: %AUTHMGR-5-SECURITY_VIOLATION: Security violation on the interface FastEthernet0/2, new MAC address (001a.4b7b.0394) is seen.AuditSessionID  0A32FF150000006125C52D87
Jul 29 11:11:06: %AUTHMGR-5-MACREPLACE: MAC address (001b.bafb.7c1c) on Interface FastEthernet0/2 is replaced by MAC (001a.4b7b.0394) AuditSessionID 0A32FF150000006025C481C2
Jul 29 11:11:07: %AUTHMGR-5-SUCCESS: Authorization succeeded for client (001a.4b7b.0394) on Interface Fa0/2 AuditSessionID 0A32FF150000006125C52D87
What is necessary for collaboration PC+IP phone at the same time.
Thanks for your help.
Nicholas Poole
Multi domain means that one device is in the DATA domain and the other, the IP Phone is in the VOICE domain.  Is your ISE box sending the correct authorization to the IP Phone to be in the VOICE domain?
Without this working you will just have 2 devices contending within the same data domain whcih isnt what you want.
Nicholas Poole
Good afternoon. Thanks for Your advice. The problem was the following: forgot to add the command
aaa authorization network default group radius
Now everything is working.
Fa0/2      001b.bafb.7c1c  mab      VOICE    Authz Success  0A32FF15000000B6500A0895
Fa0/2      001a.4b7b.0394  dot1x    DATA     Authz Success  0A32FF15000000C353ADA437
Thanks to all.
I would like to verify that in my case, I did not authorize the phone for the voice domain in an authorization rule as the root of this same problem I was facing.
To fix this, I created an authorization result that simply had the "voice domain permission" checked and used that in an authorization rule to authorize profiled IP-Phones. I did not use dynamic vlan assignment since we are in the very early stages and have the voice vlan already on the switchports.
