Scanners are deauthenticating randomely
Jul 29th, 2013
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
Hello Everyone,
I have around 12 production machine connected ro wireless bridge and these bridge are connected to Cisco APs.
Problem:
1. these machine are disconnecting after radnodem intervel.
2. I am Not able to see DHCP lease IP address in Controller>Internal DHCP server>DHCP Allocated Lease.
Can anyone help in this.
George Stefanick Mon, 07/29/2013 - 07:38
  • Community Spotlight Award,
    Best Publication, October 2015
Can you post the WLAN config that these devices connect to ?
There are a number of timers you should be aware of.
Session timeout is found under the ADVANCE tab of the WLAN. This is set to 1800 seconds by default. There is also a user idle timeout that is under the CONTROLLER tab and this is set to 300 seconds.
Also make sure client load balance is disabled.
These are typical trouble makers.
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Sandeep Choudhary Tue, 07/30/2013 - 00:27
    2017 Wireless
Hi Geoge,
I unchecked the Enable Session Timeout , user idle timeout is 300seconds(as u said it by default).
Client Load balance is disabled.
Sandeep
Scott Fella Tue, 07/30/2013 - 03:56
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 Wireless
Post your show WLAN
Sandeep Choudhary Tue, 07/30/2013 - 04:25
    2017 Wireless
Hi Scott,
Here is the output of sh wlan 1:
(Cisco Controller) >show wlan 1
WLAN Identifier.................................. 1
Profile Name..................................... BDE
Network Name (SSID).............................. BDE
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Number of Active Clients......................... 14
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. Infinity
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ bde
Multicast Interface.............................. Not Configured
--More or (q)uit current module or to abort
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver (best effort)
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Enabled
         TKIP Cipher............................. Enabled
         AES Cipher.............................. Enabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
                                                               Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT(802.11r)............................. Disabled
         FT-PSK(802.11r)......................... Disabled
FT Reassociation Timeout......................... 20
FT Over-The-Air mode............................. Enabled
FT Over-The-Ds mode.............................. Enabled
CCKM tsf Tolerance............................... 1000
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   H-REAP Local Switching........................ Disabled
   H-REAP Local Authentication................... Disabled
   H-REAP Learn IP Address....................... Enabled
   Client MFP.................................... Optional
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
Scott Fella Tue, 07/30/2013 - 04:36
  • Hall of Fame,
    2017 Wireless
You need to use either WPA v1 with TKIP or WPA v2 with AES. Don't use both and don't mix and match. Sonic your scanners support WPA v2 with AES, make sure you set your WLAN to that only. If they don't support it, then use WPA v1 with TKIP.
Sandeep Choudhary Tue, 07/30/2013 - 04:51
    2017 Wireless
Thanks for quick reply.
Ok I changed it to WPA1/tkip ..let me monitor it for few hours.
I will let u know the result of these
Sandeep Choudhary Tue, 07/30/2013 - 05:05
    2017 Wireless
But Can you please tell me: Why I am not able to see the DHCP Allocated Lease in WLC.
Scott Fella Tue, 07/30/2013 - 05:46
  • Hall of Fame,
    2017 Wireless
Well... the clients need to be connected properly first and then also as long as the WLC is the only dhcp server, then any address that the WLC issues will show up on the dhcp lease.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
Abhishek Abhishek Tue, 07/30/2013 - 14:39
  • Gold, 750 points or more
As per your query i can suggest you the following solution-
An access point may not log events related to client association and deauthentication during a client roam. The reassociation event will be missing in the logs on the access point to which the client roamed and the deauthentication event will be missing in the logs on the access point from which the client roamed. The behavior may be seen for a period of several minutes.
Hope this will help you.
Sandeep Choudhary Tue, 07/30/2013 - 22:59
    2017 Wireless
HI Abhishek,
All client are stationary
There is no roaming issue but all the scanner are connected to wireless bridge(WET200).
