Warning message
ACS not connecting to domain.
Jul 29th, 2013
I have two ACS boxes that I use here at work.  The primary is working fine, but lately the secondary stopped to working.  I checked it today and it is saying that the AD connectivity status is DISCONNECTED.  I tested the connection and it is succesful.  I checked the time settings and name servers as well and they all seem to be good.  Anyone have any idea where else I should look to find the issue?  They are using version 5.3.0.40
Thanks.
Jatin Katyal Mon, 07/29/2013 - 14:00
  • Cisco Employee,
If you have already checked the basic stuff then we can jump to adclient debugs to see whats happening.
From the ACS CLI
acs/admin# acs-config
Escape character is CNTL/D.
Username: GUI-USERNAME
Password:  GUI-PASSWORD
acs/admin(config-acs)#
acs/admin(config-acs)# debug-adclient enable
Duplicate the issue and run the below listed command to see the live logs
show acs-logs filename ACSADAgent.log
~BR
Jatin Katyal
**Do rate helpful posts**
ivan.martin Mon, 07/29/2013 - 14:13
Hi Bryan Roth
Try to update the two ACS 5.3.0.40.4 or higher version by installing a patch. There is a bug fixed in this version you indicated which resolves operating problems with Active Directory.
To rule out problems like a bug would be a good advice.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.3/release/notes/acs_53_rn.html#wp223684
