Warning message
ISE installation - reimaging issue
Jul 29th, 2013
Today I was installing ISE on 3355 appliances those will run all services (standalone), when  installation completed I was not able to login to the CLI. I think the  keyboard I used had issue (typed extra charachter or something). This was a pre-loaded OS.
I downloaded (ise-ipep-1.2.0-899.i386.iso) and tried password recovery booting appliance with (ise-ipep-1.2.0-899.i386.iso), after changing the password I saved configs and tried  logging using the new password. But I could not login again.
Then I tried to re-install ISE using (ise-ipep-1.2.0-899.i386.iso).  After the installation was completed, I entered setup command and an error  poped up on the screen. "input/output errors occured while installation".
Question 1: Is the following iso only for a posture node installation or I could use this for ISE standalone deployment?
Cisco Identity Services Engine Software Version 1.2.0 full  installation (IPN functionality only). This ISO file can be used for  installing ISE IPN (Inline Posture Node) on ISE-33x5 and NAC-33x5  Appliances, SNS-3415 server and CSACS-1121.
Question:2 What could have caused "input/output errors occured while installation". And how should I proceed with the installation?
I am in really bad situation, your help and support will be highly appreciated.
Ravi Singh Mon, 07/29/2013 - 18:59
  • Cisco Employee,
Yes you are right the ise-ipep-1.2.0-899.i386.iso is used for installing ISE IPN. Might be you are using the corrupt software for Cisco Identity Services Engine. please download the latest software again. I installed the same and it’s working.
Mudasir Abbas Tue, 07/30/2013 - 10:19
Hi Ravi, Thanks for the reply but my questions were following..
Can I use this ise-ipep-1.2.0-899.i386.iso for fresh installation on 3355 appliance?
Answer: Download the latest version 1.2 and check the MD5 checksum.
Ravi Singh Wed, 07/31/2013 - 01:18
  • Cisco Employee,
Hello Mudasir,
I am checking that you will be able to deploye it in standalone mode or not. I will update the thread as soon as possible.
Venkatesh Attuluri Thu, 08/29/2013 - 06:41
  • Cisco Employee,
If you wish to do a standlone deployment use
Cisco  ISE Software Version 1.2.0 full installation(no IPN functionality).This  ISO file can be used for installing ISE on ISE-33x5, NAC-33x5  Appliances, SNS-34x5 Servers and CSACS-1121 as well as a VM installation  on VMWare ESX/ESXi 4.x/5.x
ise-1.2.0.899.x86_64.iso
Related Content
