Warning message
Direction of NAT from Destination to Source
Answered Question
Jul 29th, 2013
Hi Everyone,
When  on ASDM  we have  this under
Original Packet
Source  Inside_hosts
Destination  Outside_hosts
Then we have
Translated Packet  with
Source  Inside_hosts_natted
Destination Outside_hosts_natted
So NAT is bidirectional  and when packet comes       back from Destination to source then Source IP  which is Destination Real source will be
Outside_hosts_natted?
We can also write this in format below
inside_ hosts  inside_hosts_natted    Outside_hosts  Outside_hosts_natted
which is equal to
inside local  inside global   outside gloabl  outside local?
MAhesh
Correct Answer by Jouni Forss about 4 years 3 weeks ago
Hi Mahesh,
It depends on the actual configuration.
If its a Dynamic NAT or Dynamic PAT then it is not bidirectional because destination hosts cannot initiate connections towards the source hosts in the NAT configuration
If its a Static NAT / Static PAT / Identity NAT / NAT0 configuration then its naturally bidirectional in the sense that both source and destination can initiate the connection.
Though in the case of Dynamic type of NAT/PAT, naturally the return traffic will flow from the destination back to the source using this same translation. So in that sense it bidirectional BUT connections cant be initiated from the destination networks defined in the NAT configuration.
Though I would imagine there are some exception to this depending how the ACLs are configured and what kind of translations are active before the destination network attempts to open a connection. Some existing translation together with the destination interface ACL might make it possible for some connectivity. But in normal situation it wouldnt really be bidirectional.
- Jouni
Overall Rating: 5 (1 ratings)
Correct Answer
Jouni Forss Mon, 07/29/2013 - 18:40
Hi Mahesh,
- Jouni
mahesh18 Mon, 07/29/2013 - 19:00
Hi Jouni,
You expalined everything very good.
Got it now.
Best regards
MAhesh
