Warning message
UCS firmware upgrade
Answered Question
Jul 30th, 2013
Hi All,
What would be the recommended route to upgrade UCS firmware on a environment current running 1.4.3x ?
would it be better to go from 1.4.3x to 2.0, then to 2.1.
or go straight from 1.4.3x to 2.1x ?
Kass
Correct Answer by Robert Burns about 4 years 2 weeks ago
Kass,
Since you're currently at 1.4 you can directly upgrade to 2.1(2) - latest release if you wish.  This process can be made especially easier using the Firmware Auto Install feature of 2.1.
Review the full upgrade procedure, but essentially you'll first download the new 2.1(2) "A" and "B" bundles to your UCS system, then activate the UCS Manager image first to the new 2.1(2) version.  After UCSM restarts you be able to use the Firmware Auto Install feature to upgrade the rest of the Infrastructure (IOMs, and FIs) and then the Server endpoints firmware.
Robert
Overall Rating: 5 (1 ratings)
AmbryTodd Tue, 12/10/2013 - 11:53
We are on 2.0(3). so we can upgrade to the latest with an easy auto-install?. I think latest is 2.1(3).
Correct Answer
Robert Burns Tue, 07/30/2013 - 06:17
  • Cisco Employee,
Kass,
Robert
Related Content
