VSS Dual-Active concept doubt
Jul 30th, 2013
Hi All
My doubt is about the need of each switch connected to the VSS using L2 or L3 MEC to be ePagp trustable for Dual-Active Detection.
If just one or two of my switches are configured with ePagp and are trustable for Dual-Active Detection, is this enough to the entire VSS realize that it´s in Dual-Active condition and take the action required to stablish the whole enviroment (all switches) ?
Or,
Each switch must have a Dual-Active Detection mechanism in implemented on it, so it can keep working when Dual-Active condition ocour?
Can i use ePagp for some switches and BFD for others (3750 stack) ?
Rafael Giuri
Reza Sharifi Tue, 07/30/2013 - 17:16
  • Cisco Designated VIP,
    2017 LAN
You just need to enable ePAGP dual active detection on one portchannel that connects to one of your access switch..
dual-active detection pagp trust channel-group xx
Also, you usually run only one method for dual active detection and not ePAGP and BFD as the same time.
They are different, BFD is a direct connection between the 2 VSS switches, but ePAGP uses the access switch.
Simon Leigh Wed, 07/31/2013 - 02:58
I would also recommend using fast hello as a back up detection for dual active detection.
You can use upto 4 Ethernet connections for this.
I use 2 copper ports in my VSS for this.
