Warning message
Can you use the range command for T1's?
Answered Question
Jul 30th, 2013
I'm trying to reset roughly a few dozen T1's.....This might take a while, is there a range command that I can use similar to the int range command for interfaces?
Correct Answer by Aman Soi about 4 years 2 weeks ago
Hi Ricci,
I do not think so.
You need to individually enter into controller port and do the shut/no shut or if T1s are coming from a single card of MUX of SP, then, that card could be reset.
regds,
aman
Overall Rating: 5 (1 ratings)
Correct Answer
Aman Soi Tue, 07/30/2013 - 18:59
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
Hi Ricci,
I do not think so.
regds,
aman
