How to continuously reboot a router until condition clears?
Alex Goldney
   We have an issue where certain carrier conditions appear to require a reboot (or a reset of the interface) to bring the device back online.
We have tested the following script and it works OK (we can also modify this to reset the interface, rather than the more drastic reboot, but the same problem will remain as explained later)
ip sla 1
icmp-echo 1.1.1.1
frequency 10
ip sla schedule 1 life forever start-time after 00:10:00
track 100 ip sla 1 reachability
delay down 180
event manager applet Missed_3_pings
event track 100 state down
action 10 reload
So - ping an ip address every 10 seconds and if it remains un-pingable for 180s conecutively reload the router.
This works fine, except that after the router reboots, the fact that the tracked object was already down is remembered, and thus no new event is generated if the address is still un-pingable.
So my question is - is there any way to ignore the fact that that the object is already down and just restart the delay counter again once the scheduler starts?
           Alex.
Joe Clarke
Try adding:
default-state up
Under the track configuration.  This will force the object to be up by default, thus triggering a transition if it is then found to be down.
