Warning message
Dual Hubs & Single DMVPN
Aug 1st, 2013
Hi, i AM FACING PROBLEM . When i close the connection of existing spoke and hub router 1 it must get connected to hub router 2. But un-fortunately its not working. Any clue
HUB ROUTER 1 Configuration:
interface Tunnel10
description $FW_INSIDE$
bandwidth 1024
ip address 192.168.10.100 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1400
ip nbar protocol-discovery
no ip next-hop-self eigrp 1
ip flow ingress
ip flow egress
ip nat inside
ip nhrp authentication abc_vpn
ip nhrp map multicast dynamic
ip nhrp network-id 99
ip nhrp holdtime 300
ip nhrp nhs 192.168.10.100
ip nhrp server-only
ip virtual-reassembly
ip tcp adjust-mss 1380
no ip split-horizon eigrp 1
delay 1000
qos pre-classify
tunnel source GigabitEthernet0/1
tunnel mode gre multipoint
tunnel key 100000
interface gigabitethernet0/1
ip address 86.96.196.xxx 255.255.255.240
HUB ROUTER 2 Configuration:
interface Tunnel10
bandwidth 1000
ip address 192.168.10.95 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1400
ip flow ingress
ip flow egress
ip nhrp authentication arco_vpn
ip nhrp map multicast 86.96.196.xxx
ip nhrp map 192.168.10.100 86.96.196.xxx
ip tcp adjust-mss 1360
delay 1000
qos pre-classify
tunnel key 100000
ip address 78.93.203.xx 255.255.255.252
SPOKE ROUTER  Configuration:
interface Tunnel10
bandwidth 512
ip address 192.168.10.74 255.255.255.0
no ip redirects
ip mtu 1500
ip flow ingress
ip flow egress
ip nhrp map multicast 78.93.203.XX
ip nhrp map 192.168.10.95 78.93.203.XX
ip nhrp map 192.168.10.100 86.96.196.XXX
ip nhrp map multicast 86.96.196.XXX
ip nhrp nhs 192.168.10.95
delay 1000
qos pre-classify
tunnel source GigabitEthernet0/0
tunnel key 100000
omerpal1190 Fri, 08/02/2013 - 02:15
Anyone who knows
malshbou Sat, 08/03/2013 - 01:53
  • Cisco Employee,
Do you have dynamic routing to fallback between the tunnels ?
Mashal Alshboul
Related Content
