Warning message
ASA 8.4 - Static NAT configuration ignoring outside ACL
Answered Question
Aug 1st, 2013
I have an inside host configured with it's own external IP (not the outside IP), that seems to be ignoring the ACL configured for the outside interface. All traffic is passing.
My config looks like this:
interface Vlan1
nameif inside
security-level 100
ip address 172.16.33.253 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address XXX.XXX.XXX.1 255.255.255.248
object network host-dunstable-blackberry
host 172.16.33.213
nat (inside,outside) static XXX.XXX.XXX.2
access-list acl-outside-in extended deny tcp any object host-dunstable-blackberry eq ssh
access-group acl-outside-in in interface outside
XXX.XXX.XXX.2 falls within XXX.XXX.XXX.1 255.255.255.248
Even so, I'm still able to SSH from an unrelated IP, to XXX.XXX.XXX.2, and access my server.
Does anybody have any ideas? Is this by design? If so, how can I restrict access to this machine?
Any help would be greatly appreciated,
John
Correct Answer by Jouni Forss about 4 years 2 weeks ago
Can you provide us with the output of the following command (Naturally fill in the actual public IP)
packet-tracer input outside tcp 1.1.1.1 12345 x.x.x.2 22
This should probably tell us what is allowing the traffic.
- Jouni
Overall Rating: 5 (1 ratings)
Correct Answer
Jouni Forss Thu, 08/01/2013 - 08:20
- Jouni
hateusernames Fri, 08/02/2013 - 08:27
Hi Jouni,
Thanks for taking the time to look at this. Performing the packet-trace shows that the traffic being blocked by the implicit deny on the outside interface.
Attempting to connect again showed that this was indeed the case.
I have no idea what was happening before, but everything seems to be working fine. It must be user error, but I'm certain I tested correctly initially... very confusing!
Thanks again,
John
Related Content
