TMS provision directory export
ulambaday
I want to export TMS users to a txt file so that I can give that file to another business unit, but I am not able to find much info on that.
Any help is much appreciated.
Patrick Sparkman
Taken from the TMS online help, as well as located in the TMS admin guide as well....
You can set up the File Based Phone Book  source to use for exporting phone book contacts to a file on a directory on your  Cisco TMS server or another web server.  Cisco TMS will then create a tab delimited  file.
  1. Create a phone book .
  2. Click Connect for this phone book.
  3. Select the sources you want to export contacts from.
  4. For Update Type for these sources,  select either Import to Cisco TMS or Import to Cisco TMS and  Export to phone book source.
  5. Now select the File Based Phone Book  source you want to export to.
  6. For Update Type for this source,  select Import to Cisco  TMS and Export to Phone Books Source.
There is also a few discussion on this already in the forums, here is one in particular.
https://supportforums.cisco.com/message/3808508
