Warning message
Howto define a full tunnel cryptomap ipsec?
Answered Question
Aug 2nd, 2013
Hi out there
I am trying to do a full tunneling of all traffic - eg guide all traffic trough a crypto map based ipsec tunnel.
The crypto map acls defines my traffic pattern and as long as it is side to side it works fine - but if I try to do a f.ex:
Permit 10.14.35.0 0.0.0.255 any I cannot get the tunnel up - I could use a SVTI instead but I would prefer to do it through a cryptomap ipsec - is this not possibly?
Br ti
Sent from Cisco Technical Support Android App
Correct Answer by Lei Tian about 4 years 2 weeks ago
Hi, thanks for the update! Yes, a static default in VRF will do the trick.
Lei Tian
Ok, now I understand it. I have never seen using RRI injects default route, and I think it is not supported.
HTH,
Lei Tian
Overall Rating: 5 (2 ratings)
Lei Tian Fri, 08/02/2013 - 15:33
  • Cisco Employee,
What's the ACL on the other end? Are the ACL mirror image between both ends?
HTH,
Lei Tian
tiwang Sat, 08/03/2013 - 01:12
Hi again
Yes they are "mirrored" - ex:
Permit 10.144.38.0 0.0.0.255 172.17.4.0 0.0.0.255
And the other end:
Permit 172.17.4.0 0.0.0.255 10.144.38.0 0.0.0.255
This works ok - but if I use "any" :
Permit 10.144.38.0 0.0.0.256 any
Other end:
Permit any 10.144.38.0 0.0.0.255
Then I cannot get the tunnel up. At the headend I use rri for route adding and I can see that I don't get a "default" route added in that vrf neither
Ideas? Suggestions?
Best regards to
Lei Tian Sat, 08/03/2013 - 04:23
  • Cisco Employee,
Is ISAKMP SA not up, or is IPSec SA not up?
tiwang Sat, 08/03/2013 - 12:39
Hi again
It must be the ipsec part which fails . I have it in a gns3 lab which I could upload if interested?
Anyway - if I just extend my ACL with the any statements the tunnel comes fine up but I doesn't get a default route added in the i-vrf so there must be a trick somehow to get all traffic into the tunnel - hmmm ?
Lei Tian Sun, 08/04/2013 - 10:55
  • Cisco Employee,
So the tunnel is up? Route injection will install the destination route in routing table, not the source. Yes, sharing your configs would help.
HTH,
Lei Tian
Correct Answer
Lei Tian Sun, 08/04/2013 - 19:02
  • Cisco Employee,
HTH,
Lei Tian
tiwang Sun, 08/04/2013 - 22:34
hi again
No you are completely right - got just confused because some of the setup did work (the "local" routing through RRI) and some not (the default gw through RRI) - when I tried to open the tunnel by pinging a remote destination it didn't open the tunnel becuase of the missing route - I didn't realised this and digged in the ipsec instead - where I couldn't find some errors but of course it is just a problem with that default gw. The ACL's work as expected if I add the default route to the vrf cvrf3881 and the packets are forwarded correctly - thanks
The only needed extra config line is
ip route vrf cvrf3881 0.0.0.0 0.0.0.0 195.41.38.10
on edge01
best regards /ti
Correct Answer
Lei Tian Mon, 08/05/2013 - 04:36
  • Cisco Employee,
Lei Tian
