Warning message
Traceroute but Cant Ping
Will like to share that am able to traceroute with specfic IP but cant ping is there any bug in router. There is no access list levied on any destined or originated host.
In below post am able to reach the destined router even that router able to reach but why cant i ping?
R1#traceroute 192.168.2.1
Tracing the route to 192.168.2.1
VRF info: (vrf in name/id, vrf out name/id)
  1 10.1.1.17 0 msec 0 msec 4 msec
  2 10.1.1.34 32 msec *  32 msec
R1#ping 192.168.2.1
Sending 5, 100-byte ICMP Echos to 192.168.2.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
R1#sh run | i 192.168.2.0
ip route 192.168.2.0 255.255.255.0 10.1.1.17
There is no vrf defined
paul driver Sat, 08/03/2013 - 01:19
  • Green, 3000 points or more
Hello
The router may be prohibiting Icmp (ping)
Res
Paul
Lei Tian Sat, 08/03/2013 - 04:30
  • Cisco Employee,
Hi Amit,
Do 'debug IP icmp' on the source and destination router will help you find the problem.
HTH,
Lei Tian
jawad-mukhtar Sat, 08/03/2013 - 13:29
  • Silver, 250 points or more
Ping using Source Interface or use extended Ping
Jawad
John Blakley Sat, 08/03/2013 - 14:34
  • Purple, 4500 points or more
In addition to what others have stated, also make sure the 192.168.2.0/24 subnet has a route to get back here. Sourcing the ping from a subnet that the 192 subnet knows about could resolve the issue....
HTH,
John
*** Please rate all useful posts ***
Dinesh Kumar Ma... Sat, 08/03/2013 - 22:52
is  this configured with vrf, then you have to ping through vrf only Ping try this and let me know..
markeelen Tue, 08/06/2013 - 12:51
Hi Amit,
This is something I learned on a CCNP course recently, Traceroute actually uses UDP not ICMP on certain Unix like systems. Worth checking if you've got an access list preventing this.
Cheers
Mark
