fan noise in UCS 6248
Aug 4th, 2013
I noticed the fans on 6248 FIs are extremely loud. The GUI shows then rotating between 11k and 15k rpm.
Is this normal operation?
The FIs are really loud, even louder then a chassis full of blades.
This bothers some of my customers with smaller data enters.
Thanks.
padramas Sun, 08/04/2013 - 23:27
  • Cisco Employee,
Hello Alex,
Hope you verified the enviornmental factors like temperature, air flow etc of the installed site for FI
Can you please share the output of following commands ?
connect nxos a
show version
show env
show env fan detail
exit
connect nxos b
show version
show env
show env fan detail
exit
Padma
Keny Perez Mon, 08/05/2013 - 09:58
  • Blue, 1500 points or more
Alex,
In addition to the commands above, could you please also attach the following:
FABRIC# sh fabric-interconnect inventory expand
FABRIC# connect nxos a
FABRIC-A(nxos)# sh diagnostic result all
FABRIC-A(nxos)# exit
-Kenny
alex.veber Mon, 08/05/2013 - 11:34
The enviorment is properly air conditioned and there is nothing blocking the air flow.
       logs attached.
Keny Perez Mon, 08/05/2013 - 12:22
Alex,
Please open a TAC case, we might need to take a look at nxos logs and others, it will be faster and easier for everybody.
The logs provided were helpful but did not show that much besides the fans in the FI at 15K RPMs. I checked quickly on a 61xx and the RPMs are around 3K less, but that does not mean much cause the models are different and we dont know if you and me, are running same firmare.
-Kenny
Michael Reiner Tue, 12/10/2013 - 23:49
Did this get resolved?
We have the same problem. Fans are running at full speed the whole time and are insanely loud.
