Warning message
not able to integrate UCCX 7.x with CUCM 7.X (lab purposes)
Aug 5th, 2013
I am not able to integrate uccx with cucm.
I successfully installed uccx on a windows 2003 running wel.
I am able to reach the webpage of uccx with Administrator/ciscocisco setup goes fine.
But after the setup completes
I get a popup which says that "
the selected service providers cannot be accessed, because the AXL service on these serverscould not be enabled or the host servers are not available"
I did al the steps that were neccary.
created in cucm application user ( uccxadmin)
assigned this user the neccary access and roles ( standard api axl access and cti )
created a end user in cucm
I have also activated axl web service and cti in cucm.
I have rebooted both the cucm and uccx machine in vmware workstation.
This all with no success
yahsiel2004 Mon, 08/05/2013 - 05:21
  • Gold, 750 points or more
Did you try assiging the AXL user with the "SUper User" role?
Yosh
monasir81 Tue, 08/06/2013 - 00:45
Hi i've tried to give application user super user role.
Unfortunately with no success.
I also disabled my windows firewall in case something is blocked.
Also no success.
Aman Soi Tue, 08/06/2013 - 05:35
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
did u follow the link which I have marked?
regds,
aman
monasir81 Tue, 08/06/2013 - 07:09
hi amonso,
yes i did follow the steps.
unfortunately no success.
Aman Soi Tue, 08/06/2013 - 20:07
    2017 IP Telephony
Can u try recreating AXL user and then,check?
regds,
aman
