DHCP on 3825 for Specific VLAN
Aug 5th, 2013
Hello all,
I am trying to configure a 3825 as a DHCP server but I only want it to hand out IP addresses to clients on a specific VLAN.  Is that possible and if so can someone send me a link?
Thanks in advance!  Replies rated.
Overall Rating: 3.8 (4 ratings)
cadet alain Mon, 08/05/2013 - 08:16
  • Purple, 4500 points or more
just create a scope for the specific subnet of that VLAN and also if other subnets(VLANs), don't forget to add a route for the IP address of the DHCP relay interface on that VLAN because the router will send a unicast offer  to the Relay agent which then will unicast or broadcast the offer.
Alain
John Blakley Mon, 08/05/2013 - 08:18
Are the vlans on a l3 switch that you're routing for, or is this router configured as router on a stick?
If you have a l3 switch, you'd create your dhcp server on the router and then point the svi to the router to pull addresses from:
On the router:
ip dhcp excluded-address 192.168.10.1-192.168.10.99
ip dhcp pool ForVLAN10
network 192.168.10.0
default-router 192.168.10.5
dns-server 4.2.2.1
On L3 Switch:
int vlan 10
ip address 192.168.10.5 255.255.255.0
ip helper-address 192.168.1.1 <---router address
The request will match the 192.168.10.0/24 subnet.
If you have it configured on the router with subinterfaces for router-on-a-stick:
dns-server 4.2.2.1
int fa0/0
int fa0/0.10
encapsulation dot1q 10
ip addres 192.168.10.1 255.255.255.0
You won't have to do anything more other than add the dhcp pool at the top.....
HTH,
John
*** Please rate all useful posts ***
Scott Hanson Mon, 08/05/2013 - 10:15
the switches are Layer 2.  Are you both saying I need to configured the DHCP on the router?  I can do that no problem.  How do I restrict it into only handing out IP addresses for that 1 particular VLAN?
cadet alain Mon, 08/05/2013 - 10:35
how is your dhcp server configured and what device is this ? what is your topology ?
Alain
Scott Hanson Mon, 08/05/2013 - 11:28
per the problem description I would like to make a 3825 router the DHCP server.  That router is plugged into a 2960 switch that is part of a stack.  I have LWAPs hanging off trunk ports on the switches.  My goal is to make 1 particular SSID an "Internet Only" SSID so that it gets an IP address from the router instead of the internal DHCP server.  I also want to segment the traffic as "Internet Only" so that they don't touch the Internals network.
John Blakley Mon, 08/05/2013 - 12:57
Scott,
Do you currently have subinterfaces configured on the router now to support your vlans?
HTH,
John
Scott Hanson Mon, 08/05/2013 - 14:07
Hello JOhn,
I do curently have sub-interfaces.  I configured a new one for this "Internet-Only" VLAN
John Blakley Mon, 08/05/2013 - 14:11
Okay. All you need to do then is create a pool that corresponds to your subinterface that you want users to be able to get the address from like in my first post.
dns-server 4.2.2.1
int fa0/0
int fa0/0.10
Your other users will land on an interface that probably has a helper configured on the interface for the other vlans minus the one that your dhcp server is actually on.
HTH,
John
