Warning message
Struggling with Vlan ACL's
Aug 5th, 2013
Looking at this configuration:
vlan access-map GUEST_ACCESS_VACL 10
action forward
match ip address HTTP_AND_HTTPS
vlan access-map GUEST_ACCESS_VACL 20
action drop
match ip address ALL_IP
vlan filter GUEST_ACCESS_VACL vlan-list 60
ip access-list extended ALL_IP
permit ip any any
ip access-list extended HTTP_AND_HTTPS
permit tcp any any eq www
permit tcp any eq www any
permit tcp any any eq 443
permit tcp any eq 443 any
These are called vlan ACL's but where in any of this does it tell me what vlan this applies to?
John Blakley Mon, 08/05/2013 - 17:33
  • Purple, 4500 points or more
Having the vacl configured doesn't automatically apply it. From your configuration however, the line
"vlan filter GUEST_ACCESS_VACL vlan-list 60"
is how it's applied. It's applied to vlan 60.
HTH,
John
*** Please rate all useful posts ***
Steven Williams Mon, 08/05/2013 - 17:45
Ahhh. I was looking more at this:
thinking it was being applied to vlan 10, but when connfiguring this in the switch it returned this:
SW1(config)#vlan access-map GUEST_ACCESS_VACL ?
  <0-65535>  Sequence to insert to/delete from existing vlan access-map entry
Which told me this is not how its applied to the vlan. I guess I would expect to see the vlan map applied under the SVI of the vlan that it is applied to.
Reza Sharifi Mon, 08/05/2013 - 17:50
  • Cisco Designated VIP,
    2017 LAN
You create the map with "vlan access-map" and apply it to vlan with "vlan filter" command.
This is just for layer-2 vlans. You don't apply vlan filter to SVIs.
John Blakley Mon, 08/05/2013 - 18:03
In addition to what Reza stated, vlan acls are used for L2 intra-vlan traffic when you want to block a host from another host in the same vlan. L3 SVIs use standard acls to block inter-vlan traffic when one host is needing to be blocked from another in a different vlan.
So:
Block host in vlan 1 from accessing another host in vlan 1 - Use vacl
Block host in vlan 1 from accessing another host in vlan 20 - Use normal acl on the SVI
HTH,
John
Steven Williams Tue, 08/06/2013 - 17:36
action forward
action drop
permit ip any any
Ok is the specific order that VACL's need to be configured? Could I essentially make the ip access-list's first then tie them to the map, then assign the map to the filter for the specific vlan? This kind of reminds me of route maps.
Also why do you have to do the rules like they are for the HTTP_AND_HTTPS ACL? permit tcp any any eq www, but then to have to permit tcp any eq www any?
I have never seen an ACL like that before, why would permit tcp any any eq www take care of all port 80 traffic in both directions?
